Question about Canon imageRUNNER C3200 Copier
I have a IR6870 Canon color copier and have error code E000020-0390 what does this mean
  • 163 Answers
SOURCE: Error Code
the high voltage board of your machine is abnormal,check and clean all corona wires or charging roller if problem not go repair or replace the board
Posted on Sep 14, 2007
  • 3 Answers
SOURCE: Error Code
check the registration motor and right door or door switch
Posted on Dec 12, 2008
PATHAMPAD
  • 25 Answers
SOURCE: Printing double sided color copies.
CHANGE YOUR DUPLEX PAPER SELECTION MOTOR
Posted on Oct 31, 2009
  • 3 Answers
SOURCE: error code canon copier
this error code it shows that there some particle onside the machine you need to clean and to change cyna developer
Posted on Mar 06, 2010
  • 3 Answers
SOURCE: error e -070 in canon ir -3100 color copier
Its an error with the senor for the transferring belt. Try going into the additional functions-adjustments/ cleaning-gradation adjust- full adjustment. And follow the prompts on the screen. If this doesn't work and you feel comfortable trying you can clean the sensor. Remove the front covers, waste bottle and the drum. The sensor is located inside the chassy where the drum was at, in the middle (front to rear) on the left Do not use a vacuum on the sensor it can be damaged easily. After cleaning and reassmbling retry the gradation adjustment.
Posted on Jun 04, 2010
Error code 2 148 0?
Go to www.canon.com and go on the support tab, find your printer and you can get the meaning of the error codes from Canon.
Aug 02, 2013 | Canon PIXMA MX320 Color USB InkJet Printer
What does error E000003-0002 mean
The error code means you have a fixing unit problem. I take it you have a Canon machine. It may be rest, but whats the model of the copier? There are to many different models and ways to rest the code.
Jul 16, 2013 | Office Equipment & Supplies
E070
getfile.asp?rid=1258 April 12, 2007 getfile.asp?rid=3215 Product : iR6800
iR6870 Title : E070 Problem :
E070 error code.
Sensor reflectors on the inside of the ITB become dirty and do not reflect the light properly from the home position sensors.
Note* - If the equipment is not properly serviced, in regard to filters, the equipment filters can clog up and cause stray toner to build up in the ventilation area. If this occurs, there is a chance that HVT2 can become contaminated and copy quality issues will occur.
Additionally, soiling the white ITB patch may also occur causing E070 error code.
Solution :
Clean the reflective surface inside the ITB or replace ITB.
In regards to filters - Be sure ALL 6 Filters are replaced and/or cleaned at it's proper intervals. If ALL 6 filters are not addressed, poor ventilation will occur and toner can contaminate HVT2. If contamination of HVT2 happens replace HVT2.
HVT2 = FM2-0528-000
ITB = FC5-1658-000 Canon USA, Inc. Systems & Technical Support Division
Dec 22, 2010 | Canon imageRUNNER C6800 Copier
Hi i am getting E061 0127 on canon clc1000, what is this error means? thanks
Basicly the code means that one of the 4 drums is not charging correctly. You may have to change the post charge wires and or one of the drums
Apr 02, 2010 | Canon CLC 1000 Color Copier
CLC 1150 Color Coiper E020 0142 What does this
Toner feed error, possibly clogged up in a feed tube, or in between hopper and developer.
Will most likely need a service technician to fix.
Dec 04, 2009 | Canon CLC 1150 Color Copier
Error Code
Called local service technician.
Mar 26, 2008 | Canon imageRUNNER C3200 Color Printer
E15 showing In MP160
According to:
http://printertools.blogspot.com/2007/10/canon-mp150-reset-codes.html
E15 means the Ink cartridge is not installed.
Both a black and color cartridge need to be properly inserted to clear this error.
Jan 16, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Clc 1150 error 350
Normally only the canon service center will tel you what the error codes means. Suggest you call them .
May 18, 2007 | Canon CLC 1150 Color Copier
Canon imageRUNNER C3200 Copier Logo
16 people viewed this question
old marine
old marine
