Question about Casio FX9750GII Graphic Calculator
How do I put casio fx9750gii graphing calculator in degree mode?
SOURCE: i can't find an antilog function in my calculator .
Anti log will be shown as 10^x (10 raised to power x) For natural log it's e^x I think it's shift > log
Posted on Jun 03, 2009
  • 7993 Answers
SOURCE: how do you put casio fx-300MS in degrees mode?
To change the default angle unit, you press the [MODE] button a certain number of times until display shows a rectangle inside which Deg Rad Grad appear on the top line and 1 2 3 on bottom line, with 1 under Deg, 2 under Rad, and 3 under Grad.
Press the number key corresponding to your case, 1. All angle values you feed the trigonometric functions will be considered to be in degrees. If you use the inverse trigonometric functions to find angles, the results will be in degrees.
Hope it helps.
Thank you for using FixYa and do not forget to rate this free solution.
Posted on Dec 06, 2009
  • 7993 Answers
SOURCE: Degree and radian function Casio fx-9750GA Plus
Press MENU, then select RUN and press EXE.
Press SHIFT MENU to access the SetUp.
Move cursor to highlight Angle.
In the botton of screen you see the Deg TAB. Activate it by pressing F1.
Here is a screen capture.
Posted on May 06, 2010
Testimonial: "Omg thank you sooooooooo much !!!!!! =) Now I can do my homework =) "
  • 7993 Answers
SOURCE: How do I change radians
Posted on Oct 19, 2010
  • 457 Answers
SOURCE: How do I put Casio FX9650GII in degree mode
  1. Press [AC/ON].
  2. Press [SHIFT] [MENU]
  3. Press [v] [v] [v] [v] [F1]
  4. Press [EXIT] [AC/ON]
Try out: [SIN] 45 [EXE], result should be 0.5.
Posted on Jan 10, 2011
How do i graph a circle in parametric mode?
The simplest way is
X1=cos(T)
Y1=sin(T)
Set angle unit to radians,
Set the Zoom window to SQR (square), otherwise your circle will look like an ellipse.
Sep 04, 2014 | Casio FX9750GII Graphic Calculator
Can the FX9750GII derivate? please answer quickly tanks
Can it differentiate functions? Yes it can. More specifically, it can evaluate the 1st and 2nd derivatives of a given function at a given point (Numerical differentiation).
On any graphed function you can configure the calculator to display the first derivative. When tracing the curve, the 1st derivative is also shown at the trace point.
For any function, not graphed
Jan 23, 2014 | Casio FX9750GII Graphic Calculator
How do I zoom in and out on graphs?
Use the Zoom function. After a graph is displayed press the F2 :Zoom function. You have the BOX, FACT(or), IN, OUT, Auto. You can also specify the WINDOW dimensions: With graph being displayed press F3:Window to set the values.
Apr 10, 2013 | Casio FX9750GII Graphic Calculator
How to put a calculator fx-9750GII in degrees
  1. Turn calculator ON.
  2. If you see no icons, press Menu then 1 to go to main calculator screen Run>Mat.
  3. In Run>Mat screen press SHIFT MODE to enter SetUp.
  4. Move the highlight to the line ANGLE. Press the F1 tab at the lower left of screen to select Degree.
  5. Press EXE to exit the SetUp screen.
Jun 17, 2012 | Casio FX9750GII Graphic Calculator
Hi, i need help with seeing the graph on my calculator
OK! Have you tried pressing the graph button to see the graph?
Sep 15, 2011 | Casio FX9750GII Graphic Calculator
How do you turn frequency on when in the stats table mode on a casio fx-9750gii?
There is no such thing as turning the frequency on on the Casio calculators. Just enter your data in lists. Choose one List where you put the frequency information. When you want to GRAPH or perform CALCulations you have a TAB labeled SET corresponding to key F6:SET. When you press F6, a new screen open where you assign the list to the variables.
Here are a few screen captures to help you.
Press F2:CALC (or F1 Graph). The Tab SET appears at the bottom of screen
Press F6:SET
Higlight the line 1-Var Freq (or 2-Var Freq). The bottom of screen shows F1:1 and F2:LIST. If frequencies are not equal to 1, press F2:LIST to assign the frequency list. I entered 2.
List2 is now the frequency list.
Press EXE to perform stats.
See that n=19.
May 19, 2011 | Casio FX9750GII Graphic Calculator
How do you graph inequalitys on the graphing calculator
Press the MENU key
Select 5:Graph and press EXE
In the Y= editor window, press F3:TYPE
Press F6 to access other graph types.
Select the inequality symbol you want and enter the right member of the inequality, then press EXE.
You are returned to the Y= screen.
When done entering your expressions to graph, press F6 Draw.
Jan 22, 2011 | Casio FX9750GII Graphic Calculator
  1. Press [AC/ON].
Jan 09, 2011 | Casio FX9750GII Graphic Calculator
How do you put this calculator in degree mode?
Open the [Run] application screen.
Press [SHIFT][MODE] to enter (SetUp)
Use down arrow key repeatedly un til you see the line Angle:
Press the F1 key to select Degree as angle unit.
Dec 06, 2010 | Casio FX9750GII Graphic Calculator
Casio FX9750GII Graphic Calculator Logo
13 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
