Hotpoint WDD8640 my hotpoint washer-dryer WDD 8640 shows "F15" on the display. it takes water with any program, but then it shows F15 and the water runs ~1 minute until it stops. with "Pump Out" the water gets pumped out and then "F15" is shown again... Please help!!!
  • 183 Answers
SOURCE: fisher & paykel GWL08 washer
faulty pcb Regards Advisor
Posted on Aug 22, 2007
  • 10 Answers
SOURCE: wf340 hotpoint washer
it will be to do with the pressure switch it may be faulty, but more often than not there is a blockage in the pressure chamber which is located at the bottom of the outer drum, check the chamber and the tube that goes up to the pressure switch to see if they are blocked if they are clear of obstruction then test the pressure switch,to do this unclip the pressure switch from the side of the machine but dont take the wires off once off pull the tube off that goes down to the pressure chamber once off blow in to the nossle on the pressure switch, you should hear it click and then when you release it should click again, if it doet click twice then that is your problem, hope that helps.
Posted on Feb 22, 2008
SOURCE: washer stops and start button blinks
The solution is pretty simple. there is a filter located right before the water pump.
* Remove the lower panel (lower as if you were looking at the front of the machine)
* Remove the 3 screws (it is easy if you have the lower drawer unit .. you will have to 'get low' if you don;t have it)
* You will see a 3" cap right facing you (in the center)
* GET A POT. and place it below the cap (foul water will come out when you remove the cap)
* remove the cap (finger tight)
* I found coins, hair, lint, dollar bills .. etc (about the size of a roll of cookie dough)
* Take CLEAN water and dump it into the washing machine (this will clean out the tube/hose)
* replace cap
* run machine BEFORE you put the cover back on (make sure it doesn;t leak)
* replace cover/screws
Posted on Jul 09, 2008
barkencoa
  • 3463 Answers
SOURCE: water constantly in the drum of the washer dryer
It is possible that the inlet valve is sticking,open
Pull the dispenser drawer right out, and see if you can see water trickling in after it has finished.
If you can, then the valve is not shutting off properly, and you will have to replace it.
The other thing you can do is to remove the top cover, and remove one by one the black hoses that go from the valve to the dispenser, and see if you can see water coming through, if you can then replace valve.
The other possibility is that the valve is getting a permanent feed from the board/timer, to check this you would need a meter to test for voltage.
Plz rate my solution.
Thanks.
Posted on Jan 16, 2009
SOURCE: my hotpoint aquarius wd440 has flashing lights
First of all try cleaning the filter inside the back as described by others if this does not work there is a filter in the top. how you clean this is quite easy. all you do is remove the top of the machine by undoing the 2 screws at the back then pull top top backwards when you have removed the top you well see a large metal casing on the left if you are looking from the the back of the machine the filter is in there to remove the casing you pull the small pipe off then undo 5 star headed screws then gently pull the casing off noteing that there is a large pipe at the front when you have remover the casing you will see the filter (the small pipe you removed at the start fits on this filter) clean the filter then put it all back together.
Posted on May 17, 2009
I have a hotpoint ultima wf860 it was all fine then all of a sudden its saying the error code f-18 how can I fix this please as I havent enough money for a newone yet. many thanks x
Hi, The link below is a user manual for a hotpoint ultima wf860 and below that are the error codes, I wish you all the best......CHEERS...
file:///C:/Users/Steve/Desktop/4992cbf9-f956-4127-bdab-caa958e02377.pdf <---"NEED TO COPY AND PASTE"
Hotpoint Washer Error CodesF01 - Electronic circuit board fault
F02 - Motor circuit fault
F03 - Temperature sensing fault
F05 - Waste pipe blockage or pump issue
F06 - Door lock fault
F07 - Electronic circuit board fault / heating circuit fault
F08 - Heater fault
F09 - Software fault
F11 - Pump circuit fault
F12 - Electronic control fault
F13 - Dryer temperature sensing fault (washer dryers only)
F15 - Heater control fault (washing machines and washer dryers)
F16 - Drum lock position sensor fault (top loading machines only)
F18 - Internal data error
F19 - Fan motor or heating fault (washer dryers only)
Apr 01, 2016 | Hotpoint Washing Machines
My washer displays an F15. What is the malfunction and how do I correct it?
Really need to know the washers make and model number. If a Hotpoint washer F15 signifies water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked.
Nov 21, 2015 | Washing Machines
Washer stops working and displays F6
hotpoint?
"EVO1 Washing Machines and Washer Dryers" open="0" style="2"]
  • F01 - Short circuit motor triac*
  • F02 - Motor jammed tacho detached*
  • F03 - Wash thermistor open/short circuit*
  • F04 - Pressure switch jammed on empty*
  • F05 - Pressure switch jammed on full*
  • F06 - Program selector error*
  • F07 - Heater relay stuck*
  • F08 - Heater relay cannot be activated*
  • F09 - Incompatible eeprom*
  • F10 - Pressure switch not sensing correctly*
  • F11 - Pump cannot be activated*
  • F12 - Communication error*
  • F13 - Dryer fan or dryer thermistor faulty*
  • F14 - Dryer element faulty*
  • F15 - Dryer element relay faulty*
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock*
Aug 24, 2015 | Washing Machines
Hotpoint aquarius super silent WF630 FAULT CODE F02
[/spoiler] [spoiler title="EVO1 Washing Machines and Washer Dryers" open="0" style="2"]
Error Codes Hotpoint Service
Aug 24, 2015 | Hotpoint Washing Machines
Hotpoint aquarius VDT60 fault F-15 keeps
F15 - Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked.
May 15, 2010 | Hotpoint Dryers
Hotpoint CTD85A F15 error not drying clothes
Hi
f15 means heater relay on pcb is welded closed
which basically means the pcb has failed and needs replacing.
regards
Mar 22, 2009 | Hotpoint Dryers
I have an e15 code on the lcd display
Are you sure it is E15 and not F15?
F15 on an lcd display washer/dryer indicates dryer element faulty. this being the case then it will probably require a new element fitting.
Hope this helps
Dec 05, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint wd72
It is f15, and it means you have a draining problem. check pump, and hose
Nov 18, 2008 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
