Question about Blenders
Blade replacement for blender food network HA-3258EA
  • 10865 Answers
SOURCE: Need replacement blade for Russell Hobbs hand mixer
go to this page http://www.russell-hobbs.com/parts.shtml and order what you need directly from Russel Hobbs.
Please mark this answer as a fixya! thanks
Posted on Mar 18, 2009
SOURCE: Can't find replacement parts for my Thunderstick Pro blender
I can sell you part of mine. I getting a new one to replace a part for mine.
Posted on Jun 10, 2009
  • 5 Answers
SOURCE: Blade won't turn in Cuisinart Duo Blender -- not motor
You have to unscrew and disassemble the blades - pretty easy, just take two rags and grab the blades with one (so you don't cut yourself), and then turn the rubber piece on the other side COUNTER CLOCKWISE, opposite of what you would do to loosen. the rod that runs in the middle that's connected to the blades on mine was all corroded, so I sprayed it down with WD-40, took my Dremel to it and smoothed out the corrosion, added some fresh grease ($2 tube goes a long way), washed the other parts with some Dawn and dried completely, reassembled and it runs much better! Not sure how long it will last, but I have a feeling that one time I ran the blender for a long time instead of pulsing, and the grease that came with it couldn't handle the heat from it turning so long. Anyway good luck!
Posted on Jan 15, 2010
SOURCE: need replacement parts for foodnetwork bobby flay "bobby blender", model no. BF-9349
My food network blender has seized. The power is working but the blades do not move.Please advise. Thanks!
Posted on Aug 21, 2010
  • 110 Answers
SOURCE: I have a Bobby Blender
Return the item to Kohl's - There are so many users with problems with this unit, and parts are not available. Please read below:
Shop With Confidence - Kohl's Industry-Leading Return Policy
  • Kohl's industry-leading return policy gives customers a quick, convenient and "no questions asked" experience.
  • Customers returning merchandise with receipts or items purchased with Kohl's Charge cards are eligible to receive full refunds or even exchanges.
  • Customers with gift receipts will be granted an even exchange or Kohl's merchandise credit for returned items.
  • No receipt? No problem. Customers without a receipt will get a merchandise credit good toward anything in the store. Or, if a customer paid with a Kohl's Charge or other credit card, Kohl's can look up the purchase and give a full refund or even exchange.
  • Kohls.com customers have the option to return items to either Kohls.com or at any Kohl's store nationwide.
  • Hassle-free returns on any item with no time limit.
Posted on May 03, 2011
Testimonial: "Thanks for the tip. At this point, it seems that your solution will be the only way for me to solve my problem."
Where can I get a lid for my sensio blender model HA 3258EA
-Check the manufacture that make it.
Good Luck
mai
Dec 19, 2014 | Blenders
Can you repack the blade bearing on Vitamix Blenders?
On the Vitamix blender models we have here in NZ it is not possible to repack the bearings, you just purchase a new blade assembly complete with bearings and the driving clutch.
Nov 11, 2013 | Vitamix Super 5000 Work Top Blender
Ninja blender blade wont turn with food in container.
make sure blade is pressed tightly onto shaft... should click into indent. if not then you need a new blade piece.- stripped
Aug 18, 2012 | Blenders
Blender does not blend, only buzzes. So I took the blender jar off the motor base and tried running it. It ran just fine. Put the jar back on the base and it only buzzed. Figured a piece of frozen fruit...
Smart move. The blade assembly is almost frozen and the motor does not have enough torque.. You need to remove the blade assembly and completely clean out the bearing and reassemble after the Mr. clean operation. A lite dab of oil is also called for.
Sep 10, 2017 | Oster 006832000000 10Speed Blender
Blender container leaks even though gasket is in place
Hey, I know this is an old thread but just had the same problem and solved it. With the blender container upside down, place the gasket on the jar hole, put the blade through the hole on top of the gasket, then screw the plastic base on top of that.
The way I had done it before was to pop the blade into the bottom of the plastic base first then screw it onto the gasket and jar but it goes on the gasket, not under the bottom of the base. Hope that helps anyone else in the future.
Also just read the manual instructions like I didn't, clear as day right there but I never bothered to read them ha
Oct 18, 2009 | Cuisinart CB-600 Blender
Need replacement parts for foodnetwork bobby flay "bobby blender", model no. BF-9349
May 04, 2009 | Blenders
Mar 23, 2009 | Blenders
Mar 18, 2009 | Russell Hobbs RH-HB3 Handheld Blender
Need to order parts for food processor for stainless steel blende
I neede a new blade unit for my phillips smoothie maker, I just googeld the model number + spare part and was redirected to the websites! Eventually you fine it!!
Feb 20, 2009 | Ultrex 834-334 Die Cast Work Top Blender
Blenders Logo
294 people viewed this question
Top Blenders Experts
eyecam
Are you a Blender Expert? Answer questions, earn points and help others
