Question about Dell XPS 18
Dell XPS 18 Battery wont charge - Dell XPS 18
Samsung tab 3 10.1 CE0168 Wont charge or come on ?
have you tried a hard reset?, take battery out and disconnect from power supply then hold power button for thirty second then replace battery and try to power up else hold power button and volume down for 30 secs need to keep battery in for this one, if they dont work you need to contact samsung to get it repaired.
Feb 06, 2017 | Samsung Tablets & eReaders
Why wont my dell streak 7 turn on
Hello.
You can check if the battery had somehow got out of it's place.
Also it may be a software related issue, as a fix you can first try to plug it using the usb cable to your computer.
Hope it helps
Jul 23, 2014 | Dell Streak 7 Tablet Android
I shutdown my dell venue 8 tablet and now it wont turn on tried the hold button thing that not working help please
Check whether the battery have enough charge. If it has below 40% of the total power needed, the tab won't start up. Recharge it fully and try. http://electronicshelponline.blogspot.com/
Jul 08, 2014 | Dell Venue 8 Pro Tablet Computer
My dell streak 7 wont charge
i can fix that pls.go to santy cellphone repair shop at greenhills shoping center
Feb 03, 2013 | Dell Streak 7 Tablet Android
Le pan tablet wont charge how to reset
Le pan tablet not charging after all night does not show battery when plugged in.tablet does turn on battery level about 30%?
Apr 28, 2012 | Tablets & eReaders
I have a Dell Inspiron 1525. I bought it in August, 2008. It has been working fine until recently. Now the problem is that it only charges upto 32%. and then it says "Plugged in, charging" but it does not...
How long does the battery last, when you use your computer WITHOUT the AC adapter connected?
Did you purchase a 1-year, 2-year, or 3-year warranty?
If the latter, you could exercise the warranty, and get the battery replaced.
Do you have any friends with a compatible laptop?
Does their battery charge to 100% in your computer?
Does your battery charge to 100% in their computer?
Have you looked on eBay to purchase a replacement battery?
Or, there is a company in Seattle that takes your battery,
opens it up, replaces the cells, closes it, and ships it back to you.
This could be less expensive than buying a new genuine-DELL battery.
Sep 01, 2010 | Dell Tablets & eReaders
Dell XPS 18 Logo
81 people viewed this question
Top Dell Tablets & eReaders Experts
Michael Vincent Cruz
brian soufane
Tiffany Tosh
Level 1 Expert
Are you a Dell Tablet and eReader Expert? Answer questions, earn points and help others
