Question about Chevrolet Vehicle Parts & Accessories
How to perform Oil Change on '11 Chevy HHR - Chevrolet Vehicle Parts & Accessories
  • 33 Answers
If you do not know how to change the oil-you probably should not be doing it.
basics-find proper filter
buy it
buy correct amount of synthetic motor oil in the viscosity reccomended by your car manual.
find drain plug
drain oil
replace drain plug
switch out filter
fill with at least 4 quarts of oil.
start engine.
stop engine quickly
re-check oil and fill to proper level.
close hood.
Posted on Aug 28, 2014
Would not come out of park
HHR CHEVY STUCK IN PARK SOLUTION - YouTube
? 4:12
www.youtube.com/watch?v=t4IqT1kTMPM
Nov 13, 2013 - Uploaded by Ed Allyn THE SHIFT LEVER WILL NOT MOVE OUT OF PARK BECAUSE ... HHR CHEVY STUCK IN PARK SOLUTION .... Chevy Trailblazer center console - remove, reinstall, and repair - Duration: 17:11. by MAY03LT 56,346 views.
Sep 22, 2015 | Cars & Trucks
Camshaft position timing over advanced for a 2010 chev hhr
DTC P0011: Intake Camshaft Position (CMP) System Performance .
Do you change your oil regularly ?
Do you chan TOYOTA LEXUS 3 LITER VVT FAULT AND REPAIR
Apr 16, 2015 | 2010 Chevrolet HHR
How remove oil pan chevy 2006 hhr
Auto Talk site online type in question start with oil pan removal.also ck youtube videos.
Aug 29, 2014 | 2006 Chevrolet HHR
My 2006 hhr has a rattle when shifting in automatic transmission
What you are hearing is referred to as "chatter," and is a first warning of transmission trouble. If your vehicle has over 50,000 miles, and the transmission fluid and filter have never been changed, the fluid likely has lost its viscosity or has become contaminated, and the internal seals in the transmission have begun to leak. Check the fluid: It should be semi-transparent, the color of blood, and should have approximately the viscosity of lightweight lubricating oil. If it is gray, tan, dark brown, watery, or if it has the odor of kerosene, it bad. Eventually, the transmission will fail.
You may start by having a transmission "service" performed, where they will replace the fluid and filter/screen. If that does not eliminate the chatter, it may be time to consider having your transmission rebuilt.
Aug 10, 2014 | 2006 Chevrolet HHR
My 2006 chevy hhr is in between oil changes and two courts low and time to change oil again.
First thing,don't let the manufacture tell you that you can 5000 to 6000 mile without an oil change.Next thing they want you to use oil that is much too thin.They don't want the engine to last too long because they can't sell you a new car that often.City driving you need to change your oil at least every 3000 mile and highway every 4000 mile.The biggest problem is having you oil changed at a quick change that uses BULK oil.If they don't offer oil from a jug,next time bring you own oil if you have to.Use 10w30 in the winter months and 10w40 in the Summer.It don't hurt to put in a can of STP after each change.
May 03, 2014 | 2006 Chevrolet HHR
Just had an oil change. how do I reset the oil life on 2006 Chevy HHR LT?
1. Turn Ignition to Run, with engine OFF
2. Press info and reset buttons at same time to get to personalization menu
3. After that; press info button to scroll through menu until you see OIL LIFE RESET
4. Press and Hold reset button until shows ACKNOWLEDGED
5. turn the key to lock
There is apparently another way also, where you turn on the ignition without starting, and pump the gas pedal three times with 7 sec or something like that.
Mar 26, 2010 | 2007 Chevrolet HHR Special Edition
How do you replace the front turn signal lights for a chevy hhr
how do you change the front turn signal light on chevy hhr 2006
Oct 02, 2009 | 2006 Chevrolet HHR
Where is the oil dipstick located in a 2006 Chevy HHR???
go to http://www.extendedgmwarranty.com/owners-manual/chevrolet/2006-Chevrolet-HHR.pdf if you have adobe reader you will see a picture in pdf format. look at the letter F on the picture. that is where your dipstick is located. now go to your car and look for it by following this picture. good luck
Jul 08, 2009 | 2006 Chevrolet HHR
2006 chevy hhr transmission fluid and filter change
usually a pan under the trans. anywhere from 10 to 22 bolts. filter inside. some vehicles have an oil style filter on the externally, but i don't think that this is one.
Sep 20, 2008 | 2006 Chevrolet HHR
Vehicle Parts & Accessories Logo
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
