Question about Panasonic DVD-RV32 DVD Player
DVD RV32 displays H07
After loading a disk, the machine displayed H07 and then STOP
SOURCE: Troubleshooting -- Displays H07 code
While stopped, press and hold REWIND and PAUSE on the unit and then also press and hold OPEN/CLOSE on the unit until Initialized appears from the display. Turn the unit off and on again. If it is still not working, Panasonic Consumer Support recommends having the product checked by an authorized Panasonic service center.
Posted on Dec 26, 2005
ravichetty
  • 158 Answers
SOURCE: trouble with panasonic dvd rv32
REPLACE THE SPINDLE MOTOR
Posted on Jul 27, 2009
ravichetty
  • 158 Answers
SOURCE: panasonic dvd cv 52
ravichetty
  • 158 Answers
SOURCE: when selecting play, dvd player acts like reading
replace the spindle motor
Posted on Jul 31, 2009
  • 8457 Answers
SOURCE: code h07 comes up
This is the major deffect design in the spindle motor.
Take the cover out put some WD40 in the spindle motor,leave it soak for about 20-30 mins.should work,after the motor it oil up.
Posted on Oct 19, 2009
I read elsewhere that HO7 ("HOT") means that the spindle motor is getting shut down because it's too hot. This may be because it's become dried out.
I unplugged my power*, opened it up, (6-7 screws in the back and sides), then removed two screws to remove the soft disk weight that sits on top of the DVD to keep it firmly against the spindle. I also flipped a plastic switch I could see down through the platter, which allowed me to manually slide open the carousel. After that, I had access to the spindle motor. I gently turned the gears to move the laser back out of the way, then put a little WD40 where the shaft enters the motor. I manually turned the spindle about 30 times to help it seep in. It didn't help the first few times I fired it back up, but after about 3 re-boots it actually worked! That was last night, so no guarantees--and no confidence that WD40 is the appropriate lubricant for longevity, but hey, it was on it's way to the dumpster because of one stupid error, so I'm a happy camper. BTW, to test it, I only replaced the disk-weight assembly (2 screws in the plastic part covering the disk and laser).
Disclaimer: I'm not a professional. This is my experience, this is not a tutorial or recommendation. Yes, you can cut, shock, or kill yourself. Capacitors can hold a charge even when a unit is not plugged in. I have no idea what lubricant to use. Get professional help if you're not one.
Feb 12, 2014 | Panasonic DVD-RV32 DVD Player
Dvd rv32 keeps saying hot and wolnt play dvds
I think you mean the front display shows 'H07' which means the laser/spindle motor assembly (as one part - also known as a traverse unit) has failed. H07 is a common error code with the Panasonic series of DVD playback decks. Because the traverse unit is a multi-operation device, and because the player is a budget model, the repair/replacement of this part to restore your player back to fully functional condition as well as labour costs could prove expensive - hardly worthwhile. It seems Panasonic have been using substandard components within their products for years now, designed to fail just outside their minimum warranty period.
Feb 10, 2011 | Panasonic DVD-RV32 DVD Player
DVD stops spinning displays code H07. Repair procedure?
H07 is the error code for Disk not Spinning. Open the case, open the DVD rack. Put 2 drops of 3-in-1 Oil on a Q-tip and rub the side of the spindle (located under the optical "eye"). Don't drip! Then close the DVD-rack with a DVD in it. Work the DVD in clockwise direction. Hopefully it will start to spin again.
hope this helps
john
Jan 21, 2011 | Panasonic DVD-RV32 DVD Player
My Panasonic dvd-rv32 player (8 years old) functioned perfectly for last 8 years and I cannot get it to PLAY again. I inserted another DVD tonight (actually 3 DVD'S in case the DVD's were defective) and...
Spindle motor/laser assembly is faulty. This part is not repairable - it has to be replaced by an authorised service centre. It may not be economical via this route, since the unit is not a DVD recorder. H07 is an indication of the above issue. Cheaper to buy a new DVD player or recorder than trying to get the faulty one repaired outside warranty.
Jan 19, 2011 | Panasonic DVD-RV32 DVD Player
Player "reads" the DVD and then the display says "H07" and ends.
The "H07" is an error code, this particular error code refers to the dvd spindle drive motor. Effectively the spindle motor that spins the DVD isn't turning correctly and on occassion this can be that the spindle & bearings need lubricating due to partial siezure. But really this should only be done by somebody with a bit of technical know-how to avoid further damage to the machine or indeed an electrical injury to the person under taking the task. I can only suggest that you contact a Panasonic repair shop and to see if it is cost effective to repair.
Hope this helped,
James
May 02, 2010 | Panasonic DVD-RV32 DVD Player
I am getting an H07 code
If memory serves me well, code H07 means that spindle motor has to be replaced. It is ease enough to test, remove top cover from the unit, load DVD disk, when disk is loaded try to give it clockwise push. If unit starts and works - spindle motor is the problem, if it will not start then spindle motor plus driver IC has to be replaced.
Nov 14, 2009 | Panasonic DVD-RV32 DVD Player
Code h07 comes up when i insert a disk. i have the panasonic dvd-rv32
Oct 03, 2009 | Panasonic DVD-RV32 DVD Player
Panasonic DVD-RV32 DVD Player Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
