Question about Briggs & Stratton Electrical Supplies
Briggs and stratton portable generator won't start
mamicheddy
  • 79 Answers
SOURCE: I have a Generac portable generator 5000 watts, won't start!
I am assuming the generator worked fine before the oil change. Now that you have done the oil change the genset does not start. These generators have a safety switch, which is basically an oil pressure switch that keeps the engine from running when there is not enough oil in the engine. Make sure that there is enough oil and if there is, look for a wire that runs along side of the engine to a round component. disconnect that wire and try starting. If it does not start then try to ground out the wire to the engine block. If this does not work, then there is other engine problems.
Posted on May 08, 2009
  • 58 Answers
SOURCE: I just got a used Briggs & Stratton 8550/5550
here is the link that you can view and print the owners manual from...
http://www.briggsandstratton.com/maint_repair/manual_and_more/docmanualdetails.aspx?showpdf=030253_0EFS1CS_LO.pdf
please rate this answer if it helps..... :)
Posted on Sep 24, 2009
ROMOAS
  • 97 Answers
SOURCE: Genarac Briggs and Stratton Engine Family
http://www.partstree.com/parts/
hope this helps
Posted on Aug 30, 2010
SOURCE: I have a Briggs & Stratton Generator 5550Watt model 030253 That is showing an output of only 4.6 V
Have the same generator. Shows only 3 Volts. I took the generator apart and found that the stator winding was burned. Can buy a replacement stator for about $250.00.
Posted on Sep 22, 2010
  • 190 Answers
SOURCE: HOW MUCH OIL AND WHAT TYPE FOR BRIGGS STRATTON
imogenerhode-
This engine takes a four cycle engine oil. SAE 30 weight should work fine. Any oil made for lawnmowers would do.
You may find the troybilt manual for this unit at: Link
The briggs and stratton manual can be found at their website at: Link. To look find the correct manual you will need to find the model and revision number from the inner side of frame, next to the engine. The model number will be a six digit number and the revision number should be two digits.
If you have found this helpful please take a moment to give me four thumbs up.
Regards,
DIYpro
Posted on May 01, 2011
Gasoline generator homelite 4400 watt will not run getting gas spark plug is fireing but will not start..
If it has sat for a while, empty the carb. float chamber, flush out with clean fresh petrol. Make sure fresh petrol is in the tank and try again.
May 13, 2014 | Briggs & Stratton Briggs and Stratton...
Model o3o319 portable generator not getting gas or air has spark
your filter inside tank may be clogged take aome air and blow in the out let of gas to see if it maybe dirty. check the fuel line itself maybe weak inside and collaisping and not allowing fuel.
May 10, 2014 | Briggs & Stratton Briggs and Stratton...
Briggs & Stratton Briggs Stratton 6200 Watt Portable Generator voltage adjust
Usually the cause of slightly low voltage like this is that the engine is not running at full operating RPM. Find the high speed adjusting screw on the govenor linkage and adjust the engine RPM until the output is 220V - 240V
Dec 09, 2013 | Briggs & Stratton Briggs Stratton 6200...
Generator won't start
model# 1971 starts on first pull runs about 3 minutes and cuts off
Jun 30, 2011 | Briggs Stratton H7159 & StrattonĀ® 5500,...
I have a Briggs and Stratton Elite series5500 watt portable generator. I cannot get it started. It has gas and oil but will not start. What could be the problem
Ensure choke is turned on while starting.
Ensure spark lead is fully pushed onto plug.
Remove spark plug and check there is a spark by keeping spark plug against body of engine and cranking engine, if no spark check there are no broken wires in ignition circuit.
Turn off gas tap if present. Remove the float bowl while holding a container under it to collect any gas. Turn on tap and check the fuel flows freely.
Check the air filter is clean. If it has foam elements these can be washed with warm water and detergent, rinsed and then oiled with a teaspoon of oil evenly distributed through the foam.
May 01, 2011 | Briggs & Stratton Briggs and Stratton...
ENGINE RUNS GREAT DOES NOT PRODUCE ANY AC CURRENT
It seems that the "generator is burn".The generator is one thing and the gen. is other.
Oct 13, 2010 | Briggs & Stratton Briggs Stratton 6200...
The pull cord is locking up and wont allow it to turn over
you need to remove the front cover where the pull start Cord is and check for anything that is blocking the Cord a broken spring under the Cord wheel can cause this as well
Sep 23, 2010 | Briggs & Stratton Briggs Stratton 6200...
How much oil is required for 6.75 hp briggs and stratton engine on a 3750 generator?
Probably about 750cc / near 3/4 of a quart. Make sure generator is on level surface, add oil in small amounts and check using dipstick until shows full.
Jun 09, 2010 | Briggs & Stratton Power Products 5,550...
Electrical Supplies Logo
44 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Craig Butler
Craig Butler
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
