Question about Husky HUS-CN15 Wine Chiller
Not getting warm its stuck on 11 degrees - Husky HUS-CN15 Wine Chiller
I have Kitchen Aid french door fridge with large temp fluctuation. Please help
Clean your coils first, if they are dirty from dog hair or lint in general it will overheat compressor and cause temps to fluctuate
Oct 17, 2016 | Refrigerators
Air not blowing through vents
Yippee. Some little actuator pulled off it's connection, 'cause the little door was stuck from the cold. When I have this kind of problem, I Google it. See if other folks have experience, to tell where you should look. Chasing duct problems is real tough.
Nov 22, 2013 | Dodge Nitro Cars & Trucks
I just a 2002 Ford Expedition last week. The front and rear heaters were working fine, til this afternoon? The rear still gets heat (not hot, but @ least warm) the front doesnt blow at all? There is no...
it could be the blower went out, the heater core but most of the time it will leak water in the passenger floor board before that goes out, it could even be the thermostate is getting stuck or has shut completely. hope this helps
Dec 23, 2012 | Cars & Trucks
Heater and defroster don't work well
Connie this sounds like your thermostat in the engine is stuck open not letting the water stay in the engine block to heat up. The fix is to replace the thermostat with a new one that will allow the water to stay in the block to warm up. The typical symptoms of a stuck open thermostat is that the air will blow somewhat warm but never hot in the winter time, but it will take a few miles for the air to warm up at all. I would check with the dealership and find out what degree thermostat to replace it with. I run a 180 degree in the summer and a 195 degree thermostat in the winter just to have hot heat in the winter. I hope this helps
Nov 20, 2011 | 1992 Honda Accord
2001 S10 2.2 flexfuel engine coolant will not warm up
the thermostst is most likly stuck in the open position letting the coolant flow freely through the engine and keep recuirculating not giving it a chance to stay in the engine block to warm up. i would replace the thermostat
Jan 12, 2010 | 2001 Chevrolet S-10
Overheating in 11 degree weather
Your thermostat has failed and is stuck in the closed position, thereby not letting the coolant circulate through the radiator.
Dec 09, 2009 | 1991 Nissan Stanza
Noticed water coming out of refrigerator is very warm and not getting cold at all. Also, middle of the fridge where the doors close all of the sudden is very hot as well. What should I do?
check temp inside of fridg it should be 0 degrees on freezer and 33 to 36 degrees on fridg section.. If not the defrost timer could be stuck.. if stuck you need to find defrost timer and manually turn till it shuts off and then turn again till it starts running. if it sticks again you will need to replace it..........
Jul 29, 2009 | Refrigerators
My subzero 650 fridge part is too warm , stuck at 53 degrees
Hi There I Have a Digital Video Creator DM-4200 Video Capturewhen i was moving my cds got cracked along all others how can i get software back for a back up..
Feb 04, 2009 | Sub-Zero 650/SRH Stainless Steel
2002 Cadillac Escalade
might have a stuck relay you could just pull it out and see if the heater turns off its on a diffarant line it the adjuster so the adjustment still works
Feb 14, 2008 | Baby Gear
Husky HUS-CN15 Wine Chiller Logo
21 people viewed this question
Top Husky Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Husky Refrigerator Expert? Answer questions, earn points and help others
