Question about Ruud Rheem Enclosed Fan Relay 42-25104-06 Za2900-1c-24a
When i wire transformer it burn
J14-03245-012
    Genius:
  • Ruud Master
  • 1,363 Answers
Something is either shorted or you are wiring the wrong wire on primary. they have different wire colors for different voltages. also install a 3 amp fuse in transformer wire & it wont burn up.
Posted on Aug 11, 2015
I install a new limit switch and now something keep burning out the transformer i replace it also and something keep burning it out what the problem could be
All transformer comes with a current limit specification in terms of VA units. For example a 24 v secondary coil with 6 VA specification only can hold a current of of 4 amps for a short period of time. So to prevent that it burned out you only pass an 80% of that current, then it really can hold 3.2 amps continuously.
Other possibles causes for burning the transformer are:
1. Accidentally connecting the primary and secondary reversed, the secondary can not manage the voltage and current of the primary .
2. A coil or device that is connected to the secondary is demanding to much current because is shorted or stuck in a position causing an increase on current.
3. The primary have multiple taps to operate on different voltages and the combination is wrong.
3. Faulty wiring. Some times the insulation of the wires became worm, cracked or melted, with the wires torches the metal a short is produced and the transformer burns. Check the wires carefully.
Hope these tips help,.
Jan 08, 2016 | Heating & Cooling
Transforer has three places to hook up wires instead of two
This will be for different output voltages.
Use multimeter set to ohms to test which wires have continuity.
If you connect Hot and neutral to wrong wires, it will burn up the transformer.
Copy following lind for illustration showing Intermatic 4-wire low voltage pool transformer:
http://waterheatertimer.org/images/PX-600-wiring-diagram-900.jpg
Jun 09, 2012 | Intermatic Malibu 300W Power Pack...
I have a HE265Ahumidifier it keep burning out transformer whats wrong
Hello, usually the transformer will burn up when the amp rating of the transformer is being exceded or if there is a short in the low voltage wiring
Dec 09, 2011 | Honeywell HE360A1027 Whole House...
I have the ML300RTW can I use 16 guage wire with this unit ? I will be having [4] four lights . Thank You
16 gauge wire is fine.
Check if wire gets hot.
Make sure bulb wattage matches 300Watt output of transformer.
If you have less than 300Watts, then bulbs will burn out faster and transformer will burn out.
Replace bulbs as soon as they burn out.
Open following link for troubleshoot and tips:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Jul 31, 2011 | Malibu Intermatic Inc. ML300RTW 300-Watt...
I have a intertherm electric furnace model #FEH=015HA=03 w/ an A coil for my AC. Date code 870902 . It burns out the transformer. It did it about a month ago and it was replaced by a certified electrician....
There is a short in the low voltage wiring somewhere...this type of thing can be very hard to track down and is probably a wire rubbed through somewhere...
Have the electrician install a 5 amp. automotive type fuse in the low voltage wiring right after the transformer to keep from burning up anymore transformers...I would do this even if you think you find the problem...
heatman101
Mar 23, 2011 | Heating & Cooling
I cleaned my io breeze quadra plates with rubbing alcohol reinserted and turned it on, it made some crackling noises and started emmiting a burning smell like a hot transformer pulled insert plates found...
You will need to take unit apart to check both the and bottom. Start either at top or bottom go over the circuit path of hi voltage grid wire check for more burn marks. Insure hi voltage insulated wire coming from transformer is not broken. This will be located at bottom of unit you will have to take top pc board off and control transformer to get to hi voltage transformer, then when that is removed you will see the hi voltage connector I was talking about. That wire is soldered on and is a very delicate connection. Make sure wiring soldered. Hi voltage transformer should be ok if you did not leave unit on for a long time while you had your loose connection in the grid wire.
Dec 14, 2010 | Sharper Image Professional Plus Ionic...
Hello! I have a Malibu transformer for my outdoor lighting. Last night, we had a severe rain storm. During the storm, my outdoor lighting went out. When I went to check the transformer box this...
My malibu transformer has a reset button on the back near the terminal connections. If the transformer is on (time displays on the panel) but the light fixtures are not lit, look for the reset button on the back and depress it.
Oct 07, 2010 | Malibu Hardware & Accessories
Will a short/ground in the thermostat wires cause a model(-) HQA to burn up the 24 volt transformer
If the transformer wires are shorted together, this will burn up the transformer. Normally transformers on the LV side (24 volt) are not grounded, but the solenoids that they control could be grounded, and a t-stat wire that is unintentionally grounded could burn up the transformer, but its not likely.
Jul 09, 2009 | Ruud Heating & Cooling
Wiring transformer
You have a "Multi-Tap" transformer, and should have a white label on it with wiring.
May 04, 2009 | Heating & Cooling
Ruud Rheem Enclosed Fan Relay 42-25104-06 Za2900-1c-24a Logo
56 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
