Question about Frigidaire 27" Electric Stacked Laundry Center - White
Frigidaire dryer made loud noise and stopped spinning
WonderTech
  • 268 Answers
SOURCE: Frigidaire Dryer making loud thumping noise in back.
Some things to check.
Worn rear drum rollers, idler pulley, or drum front slide kit.
Click here for illustrations.
Hope this helps.
Posted on Aug 12, 2009
  • 3074 Answers
SOURCE: Frigidaire dryer FERB5700DS0 loud vibrating
drum glides, drum rollers or idler assemblage which is next to motor. This website will explain how to open dryer and the glide/rollers, Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Posted on Nov 28, 2010
SOURCE: loud squeaking noise coming from back center when drum tumbles
I am having the SAME issue. I try to put up with it, but the sound is horrific!!
FDE216RES2
Posted on Feb 12, 2011
rohdd
  • 283 Answers
SOURCE: My Frigidaire Affinity AEQ7000EGO dryer
Could be one of 4 problems:
  1. Worn or loose drum drive belt (Looks like a large fan belt) (New belt cost $12)
  2. The rear bearing(s) is bad and needs replacing (part cost $18)
  3. The front bearing guide(Sleeve) is worn (Part cost 2@$18.00
  4. Possible that the fan is loose from the motor and hitting housing.
All of the above are easy do at home repairs if you re handy. You should be able to get a good idea of what is wrong just by turning the dryer drum by hand. If the problem is the front bearing or guides, you will hear a grinding noise in the front at the top of the door.
Below is a link to diagrams and parts for your dryer. - J
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5156927
Thanks for using FixYa - a 4 THUMBS rating and POSITIVEComment is really appreciated for the FREE answering of your question.
Capt. Spock said: "An ancestor of mine maintained, that if you eliminate the impossible, whatever remains, however improbable, must be the truth."
Posted on Mar 07, 2011
heatman101
  • 43501 Answers
SOURCE: Gas frigidaire dryer makes a loud thumping noise,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Apr 02, 2011
My dryer starts making noise after a min. and gets louder as it go's
Hello friend, thanks for your inquiry!
From my understanding your Frigidaire dryer is making a loud noise as it continues to go through the cycles. It could be an issue within the drum not properly being balanced and the load is now rubbing against the wall of your dryer.
It is also possible that the belt is not securing the dryer and it is not properly spinning. I would suggest seeking assistance from a professional to come out and properly diagnose your appliance to avoidany unnecessary part purchases. -Matt
Sep 29, 2014 | Frigidaire Dryers
Machine Starts filling then spins 3 turns and a loud noise and stops?
Hey friend, I appreciate your post!
From my understanding you Frigidaire washer will fill with water, spin three times, make a loud noise, and then stop. You could possibly be seeing an issue with your control panel or motor. I would recommend having a technician come out to the home to properly diagnose and repair your washer. I hope this is helpful. -Matt
Jul 30, 2014 | Frigidaire Washing Machines
Frigidaire Gallery Series GLEH1642FS loud noise on final spin
It sounds like something has come loose or some item was placed in the unit accidentally and it got lodged in the drum. You will need to start by taking the front cover off and looking around the drum.
Jan 27, 2013 | Frigidaire Gallery Series GLEH1642FS
Hope this helps.
Aug 12, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire was tub makes loud thump noise during spin cycle....
Need more information to make an accurate diagnosis, try removing the front panel (two screws at bottom) and visually check first the belt (all the way around) and then the springs that hold the tub suspended.
I would bet on the belt.
Quentin
Jul 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
Drum making intermittent sqeaky noise for 3-4 minutes then stops
heatman101
ytg
Jun 03, 2009 | Frigidaire Electric Dryer
Squealing!!
the noise is coming from the drum axle bushing that allows the drum to spin on it's axle. Gain access to the rear of machine and apply some high temperature grease that is found in automotive parts stores to the bushing. run it while observing spinning drum at rear for any possible other problem where squeal can be found such as drum slides.
Dec 26, 2007 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Nov 20, 2007 | Frigidaire FWS833A Top Load Washer
Frigidaire 27" Electric Stacked Laundry Center - White Logo
13 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
