Question about Smith Corona Office Equipment & Supplies
SE 100 reset margins
Brother typewriter Model GX-100, how to set up the right and left margin?
Normally, you must set the carrier or scale where you want it set on the left then press the left margin set button. Then move the carrier to the right to where you want the right margin set and then press the right margin set button. You may have to use margin release to bypass the previously set margins. Hopw this helps.
Oct 22, 2013 | Office Equipment & Supplies
How do I reset the right margin in a Brother ML-100 Typewriter?
Go to BROTHER.COM click on support, poke around there and you will find a manual.
DickyO
Oct 12, 2011 | Brother ML-100 Typewriter
I hit my indent key on the right side of mytypewriter and now my margin is lock and I don't know how to get it to release
first, try turning the machine off for about 20 sec. then turn it back on. if that doesn't work hit the indent button once, and try it again. are you trying to reset the margin or just go past it?
Mar 14, 2011 | Smith Corona Wordsmith 100 Typewriter
How to clear margin when in use
Left margin...use the code key (colored)
Move the carriage to where you want the margin, use margin release if you have to go beyond the present margin, and use the margin set key to set.
You have to reset a margin. can't just clear one.
Can set margins at each end of the typing line, then you will have no margins.
Hope this helps!!!
Dec 16, 2009 | Smith Corona Wordsmith 100 Typewriter
Right Margin: I need to move the right margin.
Space bar to where the current right margin is. Press "margin release" key once. Space bar to where you want right margin to be. Press "margin right" once. This should work.
Aug 20, 2009 | Brother ML-100 Typewriter
Margins
I need to reset the left and right margins, i had read to press "code" and "mar rel keys" and backspace to where i want it, same thing for right but it didn't work. Do you have any other suggestions?
Feb 20, 2009 | Brother ML-100 Typewriter
94 nissan pickup se how to reset check engine light
disconnect the negative battery cable re hook it back on.. this is only a temp solution if there is a problem it will come back on in the next 100 miles
Jan 30, 2009 | 2007 Nissan Murano SE
How do I adjust margins on Smith Corona WordSmith 100?
Return to the L. margin Press code and 1 release kets backspace to where you want L. margin press L mar key.
DickyO
Jan 06, 2009 | Smith Corona Wordsmith 100 Typewriter
Good morning. I am using a Brother ML 100 and need help in changing the margins
Return to the L. margin, press code and mar rel keys, release keys backspace or space to the location you want the margin press code and L. mar. keys. Follow the same procedure for the R. margin.
DickyO
Jan 05, 2009 | Brother ML-100 Typewriter
Brother ml 100
when the typewriter is first switched on the typewriter will automatically set a margin 10 or 12 spaces in,depending on which pitch setting you have. To set a margin say on 20,space-bar in to 20 on the spacing scale and then press Margin Set Key. to set a margin on say, 5 first depress the Margin release key and back-space 5 spaces in and then set then margin as before. Remember that the typewriter will "forget" the settings as soon as it is switched off.
Oct 29, 2007 | Brother ML-100 Typewriter
26 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Ron Dufek
Ron Dufek
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
