How to remove front fascia panel on a new world 90dfdo to access timer have removed control knobs 2 screws from side panel and 5 screws from under Neath bottom end is free but too is located under hob too
SOURCE: front panel removal
make and model number would help, post these details and i may be able to help
Posted on Sep 09, 2007
  • 351 Answers
SOURCE: removing front panel on maytag washer
some maytag panel just pull off from the bottom,they are just a tight fit.and some have screws under the hob.
Posted on Mar 21, 2008
jsrock516
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
shaggyrat
  • 1224 Answers
SOURCE: How can I replace a damaged timer control knob?
i was reading up on this item and i came across section where they mentioned you have to purchase 4 complete different replacement knob boxes or panels
heres the link boy this product is having one heck of time
http://www.reviewcentre.com/reviews105062.html
Posted on May 09, 2008
  • 116 Answers
SOURCE: How do I remove the selector knob on washer
The main selector control know spins off by turning the selector inner knob counterclockwise. The outer ring will then pull off. The other knobs are held on with friction and should just pull off.
The best way to get behind the front panel is by removing the top panel of the machine. There should be 2 gray/solver tabs at the back of the machine near the top if you remove the 2/4 screws from the top then the whole top panel will slide forward then lift off.
Be sure to unplug the machine first.
Posted on Aug 02, 2008
How do I remove the lid off of a GE dryer
Try: http://www.appliancerepair.net/clothes-dryer-repair-4.html
They can probably help, especially if you have a reason to take the top off and it is not performing properly.
Apr 01, 2015 | GE Dryers
I have a stoves farmstyle 1100 df cream range cooker. I am having problems with the timer and have bought a new one but I need to know how to remove the top to fit it. The cooker serial number is 050564146
Hi.
To replace the timer control you need to remove the front fascia panel and the hotplate at top.
Before starting disconnect power and move the range forward.
To remove front panel you need to undo the 4 screws at the sides and to remove the knobs, then remove front panel.
To remove the hot plate you need to remove 4 screws at the back. There are also 4 screws at each side of the hot plate. You may need to remove the side panels to reach those screws. There is also an additional screw located behind the control.
Here a service manual for the range Farmstyle 1100E, which is similar to 1100DF. The disassembling instructions for top and front are at pages 62 to 64 of PDF (sections 4 to 6). Control board and touch pad are at page 67-68 (sections C and D of disassembling).
Service manual: Stoves Farmstyle 1100 1st.pub
Regards.
Ginko
Oct 07, 2011 | Stoves 1000DFDLm Gas Kitchen Range
Stoves E2H600- lighting behind fascia panel has gone off so cannot now see what temperature settings are! How do you remove the fascia panel to access and replace defective lighting unit/s? Many thanks,...
A bit involved but quite straightforward.
Open the grill door and you will see 4 screws on the underside of the hob - remove the inner 2.
You can now hinge up the entire hob.
On each side of the hob is a trim piece with 2 screws which retain the glass front panel. Remove these and the end trims.
Carefully pull the timer buttons away from the fascia - the simply click into position.
The glass panel can now be tilted up and removed - it is pocketed at the top.
Each of the control knob assembly can then be easily pulled away from the controls.
The fluorescent tube is situated below the controls in a recess.
Rotate the tube through 90° and lift the tube out.
Refitting is the reverse of the above procedure.
Jun 22, 2011 | Stoves Ovens
I am trying to repalce the drum belt on a Hoover D6530 tumble dryer. What is the easiest way to do this?
here is the procedure to remove the drum:
1) There are 3 screws on the rear at the top that hold a plastic strip, remove the screws and the strip.
2) Slide out the top panel to the rear.
3) In each of the top front corners there is a screw, remove it and slide the top trim bars back and remove.
4) Tilt the machine backwards; remove 3 screws from the front underside.
5) Remove 2 screws from the top panel behind the control panel trim (each one about 2" inboard of the corner screws in step 3.)
6) Take note / photograph the mains switch connections, controller PCB connections and control knob connection. Remove the connectors and the control knob.
7) Slide the control panel to the right and remove.
8) Open the door.There are 2 screws by each hinge on the left.There are another 2 screws to the right.Remove 2 screws on the hinge side that have the same heads and level with the screws on the right.Remove the 2 screws on the right.
9) Pull off the front panel. 10) Remove the lint trap.
11) Remove the 2 screws that secure the lint trap housing to the front support frame. (Look up at the lint trap from the floor, they are under the front edge of the lint trap housing, one on each side.)
12) Support the drum (you can use a solid cardboard box that just fits between the drum and the machine floor.)
13) Remove the 4 M4 head screws (8mm box spanner) that hold the front support frame to the chassis.
14) Lift the front support frame up and pull the lower part forward to release it from the chassis
Mar 06, 2011 | Hoover Dryers
Two questions how do you change a low beam lightbulb in a cadillac srx 2005 and why in early morning starts does the same car hesitate to pull away?
1. Remove front wheel well front half splash guard, each side. There are about 2 screws and the guard pulls forward to seperate from the rear half.
2. After removing the splash guard, you can access one screw that attaches the front fascia, each side.
3. Then about 6 plastic push pin type screws along the bottom, underneath.
4. About 5 push pin type screws on the top.
5. Fascia should then simply pull forward. It is a bit bulky and an extra pair of hands is helpful.
6. Then there are 3 screws to remove the headlamp assembly. Unclip the wiring harness.
7. Then 4 screws to remove the bulb access cover plate.
Dec 24, 2010 | 2005 Cadillac SRX
Washer does not change cycles on its own
timer is most likely bad if it will not move on its own at all..
3951703 - TIMER
you can access the timer by:
remove power from the unit.
remove the philips head screws that should be present in each left and right control panel end cap front.
slide the control panel bottom forward 1/2 inch and lift up.
the entire console will swing up on the hinges in the rear of the console top.
with the console upside down you can see the back of the timer, there is a small brown clip sort of recessed into the back of the timer that is connected to the timer knob/shaft. that clip needs to be pulled out so that the knob can be removed to access the screws on the front to remove the timer assembly.
around $100 new
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Whirlpool Washing Machines
How do I remove the control panel? on the kenmore elite calypso
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 30, 2009 | Kenmore 24082 Top Load Washer
I need to remove the timer from my Kenmore 80 series washer. I'm inside the control panel and have removed the timer knob and the one screw behind it, but it won't come off. I also can't disconnect the...
Mar 22, 2009 | Kenmore Washing Machines
Removing face panel on Kenmore clothes washer 417.40412700
Mar 09, 2009 | Kenmore Washing Machines
Jenn-Air JDS9860AAP Control Panel Problem
Control Panel
1. Remove power from unit.
2. Remove burner switch control knobs.
3. Open oven door and remove screws securing control
panel.
4. Remove screws located on the right and left sides of
the control panel.
5. Grasp control panel on the far left and right sides and
gently pull the control panel out and down.
NOTE: Gently pull control panel out and down.
6. Remove infinite switch control knobs, infinite
switches, indicator lights, rocker switches, and
electronic control/clock (as necessary) and transfer to
the new control panel.
7. Reverse procedure to reinstall control panel.
Electronic Control
1. Remove control panel, see “Control Panel”
procedure, steps 1 through 5.
2. Remove screws securing electronic control bracket to
control panel.
3. Label and disconnect terminal wiring from electronic
control.
4. Reverse procedure to reinstall electronic control.try that
Jan 16, 2008 | Ovens
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
