Question about Goodman GDS80703ANA Open Flame Mid-Size Heater
It unit cuts off as the gas is coming through it clicks as it shuts off
  • 148 Answers
Flame sensor may need clean
Posted on Feb 14, 2014
Kenmore oven shuts off before preheated
On any gas appliance there is a high and a low limit temp stat which could be indipendant or on the gas valve it's self, that is faulty.
When the oven reaches temp, it cuts out. sounds like faulty over heat stat.
Mar 21, 2014 | Ovens
Gas burner wont come on ,it just keeps making a clicking sound but doesn`t come on fridgidair
Is the gas shut-off on? (If the problem is with all burners this is the first place to check.) Usually the shut-off is at the back of the unit and you can reach it after removing the bottom storage drawer. Make sure the burner parts are put together properly (some sealed burner units only fit one way). Check that there are no clogs in the burner slits. The clicking is the ignitor trying to ignite the gas, btw.
Additional problems are recommended for professionals. However you can look for a clogged orifice when you disassemble the burner for cleaning.
I hope this helps.
(I don't know of any range that has a separate burner shut-off (just oven shut-offs) but you might check your range.)
Jun 25, 2010 | Frigidaire FGFB75D Gas Kitchen Range
RM2652 runs a short while on gas then gas shuts off.
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
Jun 01, 2009 | Dometic RM2652 Refrigerator
That was my same problem. I posted yesterday but I don't think I did it right! Anyway I had stated I thought it was the thermocouple and that's what it was. The millivolts while connected were down around 13.5 or so and that low of a voltage is not enough for the control board to verify there is a flame present. I replaced the thermocouple and it now reads 33.5 millivolts while the flame is on. So before you buy a new control board, make sure it's not something less expensive. I paid almost $40 for the replacement, but I am in a hurry to get this unit repaired. You can find them on-line for about half that.
Furnace runs about 1 minute, then total shutdown
What type of gas supply line do you have? Is it black pipe or copper? If it is copper, there can be a film like substance that builds up on the inside of the copper. The debris will the get caught in a pre screen where the supply enters the valve thus cutting the supply of gas to the unit. Also, the thermocouple may be bad. You didn't say that you replaced it. Try replacing it as well. Also, you could have a limit switch turning the system off and thus cutting the gas off completely but it is highly unusual for the pilot to be cut off as well unless the pilot is being blown out when the gas is shut off. Also, turn the unit to fan only without calling for heat. Using a flame of some sort, put it into each baffle of the heat exchanger. If your flame is being blown around in one of the baffles, then you have a hole in the heat exchanger and what is happening is that the roll out switch is cutting the unit off and the air still moving through the heat exchanger is blowing the pilot out. I have seen this actually happen. If your furnace is in excess of 15 years old, it does need to be checked for possible holes. If it is in excess of 25 years old, it is a huge possibility that the unit has already developed a hole. If you feel hair coming out of one of the baffles, then shut the unit down immediately and have it replaced!
Apr 05, 2009 | Heating & Cooling
Unit will try three times to start then shut down
Make sure the exhaust fan is running.You say it fires up and then cut off.Does the main burner come on just the pilot?If it's just the pilot then I would say you need to replace sense that senser the pilot lite.Because onces that senser the flame the main gas vavle should open.for give me for my mis spelling.
Mar 26, 2009 | Heating & Cooling
Honeywell propane furnace. Ran out of propane last night. Refilled this morning. Has automatic pilot. Heat will not go on. Is there air in my lines? How would I purge the lines??
You will need to cut off power
find the gas shut off at your unit and cut off.
Loosen the fitting after the cut off and open the cut off slowly until you smell gas. re tighten and turn gas and power back on.
Nov 29, 2008 | Heating & Cooling
Kenmore 90 series gas dryer
possible motor overheat ..if unit has a lot of lint or has had vent problems now or in past lint may have accumilated around motor and caused it to overheat and shut off.. probably to late to save motor
Sep 29, 2008 | Kenmore 73952 Gas Dryer
Heating & Cooling Logo
35 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
