I have a Velodyne SPL-8R with the exact same problem. it started back
in mid May 2009 intermittently when the subwoofer auto powered on. Hiss
and crackles, then it would clear and behave as normal. Now it does not
clear and it puts out a crackling distorted sound with every bass
signal.
The manufacture date is April 11, 2005, almost 4 years exactly to the date.
I
am not so impressed with Velodyne anymore. It's out of warrantly and
the store I purchased it from (A&B Sound in Canada) went out of
business. Very Disappointing
The first thing to do is unplug it, then pull the sub out of the cabinet, then pull the amp out of the cabinet. If you can take out the amp w/o taking out the sub, great. If there are any exposed printed circuit boards, look for dust buildup. Sounds like you've got alot of static energy built up in the internal electronics. If you have to disassemble the casing to get to the circuitry, do so, just do it carefully. Look at the boards. If there's alot of dust, get some printed circuit board cleaner.(pcb) cleaner found at Radio Shack. Then spray off the boards and the subs volume control as well as the crossover control. This will Not hurt any electronics.Re-assemble and test. If you still have noise: Take a careful look at the input side of the amps circuits and traces, if you have a magnafying glass it helps. What your looking for is a bad solder joint. You will see all the little dimples on the boards from soldering at factory. When you look at the solder point, look for a circular ring generally midpoint on the solder or right at board level. This can take some time, however, it's free and it's more than likely the problem. To fix a cold solder joint you need a fine point solder gun, just touch the point that is bad and it will re-seal, then test. Plug n Play. Hopefully it's just dust and you don't have bad solder joints. Velodyne makes an awesome product!, very rarely do I see problems with them. If you need some more help with this, post a comment and we can dig further. Hope this helps
Comments:
Jun 23, 2009
- One last thing to try. Radio Shack sells "Tuner wash" pull off the crossover and volume knobs and spray a little into the potentiometer, then work the control a few seconds. Turn it on and change the x-over points while its on and volume as well. If it still crackles repeat a couple times. Hope that does it! Best of luck!
my lght904ta home theatre box is turning on with the red power light but the screen is not...
(More)
my lght904ta home theatre box is turning on with the red power light but the screen is not displaying
Harmon Kardon subwoofer popping and crackeling during play and when just sitting while turned on...
(More)
Harmon Kardon subwoofer popping and crackeling during play and when just sitting while turned on (the kind were the speaker is directed to the floor). This started after attaching the sound system to new flat screen TV. I did clean off dust and spider webbing from the speaker prior to set up. There is also a loose screw that holds the wire conection where it attaches from the speaker to the reciever. I removed this but it still pops often and loadly
