Question about Car Audio & Video
How do i hook up two planet audio bb12dvc subwoofers to a metrix Mab-901monoblock highpower mosfet amp
2 Suggested Answers
pctech1
  • 1940 Answers
SOURCE: MY AMP TURNS ON BUT NO AUDIO OUTPUT TO MY SUBS! I
First, test your sub terminals for an Open connection, or no resistance. This is to test if your sub is blown. This is usually the case.
Double check your wiring, not only to the sub, but from your headunit to your sub. Make sure your headunit is configured to work with your amp, if you have a setting for this (for instance, SUB: ON).
Posted on Jul 14, 2010
Wats the best way to hook up 3 hifonic hfx12d 12s. Dvc 4ohmd to a 2 channel 2600 watt planet audio. Amp is 2 ohm stable.
Wire each sub 8 ohms(sieries) than connect them in parallel, bridged @ amp, final impedence will be 2.6 ohms.
Jan 30, 2014 | Hifonics Car Audio & Video
Planet audio
Sounds like your power supply to the amp. Make sure you location has plenty of air flow around it and use at least 10 gauge wire to the power input. Same size on the ground and make sure all contacts are clean. Your alternator will run hot when the sound is cranked and the car is moving. The heat lowers the amperage output of the alternator and will cause the amp to cut in and out.
Nov 07, 2013 | Planet Audio PX1500M - 1500W MOSFET...
Planet audio px1500m
To many toys not enough power ...... Extra battery or bigger alternator
Nov 07, 2013 | Planet Audio PX1500M Mosfet Monoblock...
Planet Audio PX1500M Amplifier Problem
Check the FUSE to ensure that current is not cut off.
Jul 16, 2013 | Planet Audio PX1500M - 1500W MOSFET...
I have just bought a planet audio ap1500d and when i hooked it up the protection light turns on not the power
disconnect any woofers and retry the ignition sequence (if still in protection get yourself a digital multimeter and check to make sure you have @ least 12volts of power (if under 10 volts the amp will go in protection from under voltage)and good ground as well as remote if you do have all these things return the amp where you bought it or have it checked out) if the amp works you have a blown woofer
Sep 04, 2010 | Car Audio & Video
Kicker subs hook up problems
Connect one to each channel, for the best sound.
Jan 05, 2010 | Kicker Solo-Baric L5 Car Subwoofer
Wiring issues
ok here is how it goes power wire from the battery all the way to amp..then ground wire from amp to a good ground on car then the remote wire which you have to run from the amp to the back of your stereo which in most cases is blue then hook subs from the sub box to the amp
May 30, 2009 | Legacy 2 Channel 1600 Watt Bridgeable...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
