Question about Homedics Health & Beauty
Weight doesn't display - Homedics Health & Beauty
Can't automatic adjust rear shocks
Actually, the Goldwing doesn't have adjustable shocks. What it has is a load levelizer and in order to adjust it for the various weight loads it needs to be on the main stand. Viewing the display will let you know the weight level it is set at. If that doesn't work, you will need to check for a blown fuse.
Sep 26, 2012 | 2008 Honda GL 1800 Gold Wing
Doesn't keep a record of time and distance. shows the letter
1) If your system display has a batteries change it by new ones.
2) Adjust the sensor reed switch, see the diagram by 1/8" or 3mms.
3) Tight the flexible cord from keypanel vs Display board + then tight the connector from Display board vs Lower Board( Main Motor Controller Board)
4) Adjust the speed sensor in according with your manual, but in short must be square one size vs the other side.Touching in same way by each side.
If the problem persist the problem Probably would be the EPROM ,RAM or ROM from the display board.
sincerely.
Good luck, sincerely. G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA
Dec 04, 2011 | HEALTHRIDER Pro H500i Treadmill with...
On my "Ideaworks" wireless electronic display
After playing with the remote on this scale for about 30 minutes, I finally found out how to change this display from kg to pounds or stones. Since this scale doesn't come with an instruction manual, I know a lot of people are totally lost. OK, first click the user button once, so that the weight and goal weight show. Then hold down the clock/set button. After a few seconds the kg on the screen will start blinking. Then use your arrow buttons to switch to stones, then to pounds. The lb will show at the top of the display above where the kg was. You can also set your goal weight by pressing the set button and scanning through after setting the lbs setting. Hope this helps!
Aug 22, 2011 | Jobar International Ideaworks Remote Read...
DOES LENOVO S10-3 HAVE WIFI CONNECTIVITY FEATURES
Yes it does, but it doesn't have a Bluetooth.
  • Intel® Atom™ Processor N455 (1.66GHz, 667MHz FSB, 512KB L2 Cache)
  • Genuine Windows® 7 Starter
  • 1GB DDR3 SDRAM
  • 160GB SATA HDD
  • Intel® Graphics Media Accelerator 3150
  • 10.1? SD LED Display with Camera
  • 3-cell Li-ion Battery
  • 1-year Regional Carry-in Warranty
  • With WIFI / No Bluetooth
  • Weight: 1.15kg
Jul 24, 2011 | Computers & Internet
How do you adjust the tanita 1479 scales
what do you mean by adjust it? to calibrate it follow below
Switch off.
2. Press and hold OFF key.
3. Quickly press ON/ZERO key three times then release both keys together. The timing is rather critical, so if it doesn’t work first time, try again.
4. Display shows [ 0.-0- ], followed by [ 0.-1- ].
5. Place 50gm weight on plate.
6. Display shows [ 0.-2- ].
7. Place 100gm on plate.
8. Display reverts to weighing mode.
Mar 12, 2010 | Tanita Health & Beauty
I need a manual for a Berkley fs50 scale
Operating Instructions1
A. Powering-on the scale
1. Press and hold the POWER button for two seconds. Scale will perform a self-test by displaying four 8s for three seconds. When "0.00 kg" or "0 lb 0 oz" is displayed on the screen, scale is zeroed-out and ready for normal operation.
B. Normal Weighing
1. Hang fish on the attached hook. Weight is displayed in either kilograms or pounds and ounces.
C. Switching between unit weights
1. Press and hold the POWER and CHOOSE button simultaneously for three seconds. Unit will change from weighing pounds and ounces to kilograms and vice versa.
D. Taring Weights
1. Weigh a bag or container till its weight is steadily displayed on the screen.
2. Press the POWER button once. Scale will zero-out and show "0.00 kg" or "0 lb 0 oz" and is ready for weighing multiple fish together.
E. Holding a weight
1. With the weight displayed on the screen, press the CHOOSE button. This will hold the current weight and is indicated by displaying an H to the left of the screen. To unlock the hold, simply press the POWER button.
F. Storing weights into memory
1. With a weight in the hold mode and an H displayed to the left of the screen, enter the memory mode by pressing the CHOOSE button. While in the memory mode, pressing the CHOOSE button will allow you to navigate through ten stored memories. These are indicated on the left and numbered 0 through 9. There are also 4 letters that indicate other options. An A shows the average of all stored weights. An E displays the total and a C resets the memory.
2. To store a weight, simply hold down the CHOOSE button for three seconds. Weights will automatically store into one of the number registers. To see the numbers with their weights, simply scroll through the numbers by pressing the CHOOSE button as described above.
G. Resetting the memory
1. With the unit in the C mode, press and hold the CHOOSE button for six seconds and scale will reset memory and zero out. Press the POWER button and scale is ready to begin weighing again.
H. Powering-off manually
1. Press and hold the POWER button for 6 seconds.
Dec 09, 2009 | Berkley Twist Lock Rod Rack
Weight Watchers bathroom scale, Model WW60X
I got it! Press "set". You should see "start goal" in the bottom right. Press the user # you want to save as and press "set" again. The display will blink then display "0.0". Step on the scale to get your current weight. Once it's read you current weight, press "set". A goal weight will display. Press "User 1" to make your goal weight go up and "User 2" to make it go down. Press "set" when the display shows your goal weight. That's it. Now all you have to do is press your user # and wait for "0.0" to display before stepping on the scale.
Apr 24, 2009 | Conair WW60 Weightwatchers Scale
How do you program users?
Storing and Recalling Weights
1. Your scale can store and recall up to 5 weights. If your scale has one button,
weights can be stored for one user. If your scale has two buttons (User and
Save/Recall buttons), weights can be stored for multiple users.
2. Tap center of scale platform with foot and wait until "00.0" appears.
3. Stand on the platform without shifting or moving until weight is displayed.
4. For single user scale: When weight reading appears on screen, step off the
scale, press Save/Recall button and hold for about 2 seconds to save the
reading.
For multiple user scale: When weight reading appears on screen, step off the
scale, and press User button to select a user number. Then press Save/Recall
button for 2 seconds to save the reading.
5. Weight reading blinks twice, then becomes stable. A small number (1-5)
appears in the upper right hand corner of your display, indicating which of the
5 weights is displayed. (Once you have 5 weights in memory the current weight
always saves as "1" and the oldest reading is eliminated.)
6. Weight reading is saved. Press Save/Recall button to review the last 5 weights or
let the scale shut down automatically. (Note: until you have 5 weights stored in
memory, the display will show the number and "–" for each weight for which
no data point has been stored yet; i.e. "3 –", "4 –", "5 –" if only 2 weights
have been saved.)
Hope this helps!!
Feb 09, 2009 | Precision Camera Weightwatchers WW70 Body...
Can I reset the scale?
This link allows you to ask questions and request a users manual....I hope this helps. http://www.conair-store.com/cc_contactus.asp
Dec 31, 2008 | Conair WW60 Weightwatchers Scale
Health & Beauty Logo
429 people viewed this question
Top Homedics Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
