Question about Frigidaire ATF6000ES Front Load Washer
Spinning cycle sounds rough - Frigidaire ATF6000ES Front Load Washer
  • Frigidaire Master
  • 5,323 Answers
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Posted on Apr 01, 2015
Maytag Neptune MAH4000AWQ
If the appliance does not complete the cycle, then it is probably a fault on the control timer, the part should be replaced.
Oct 15, 2008 | Maytag Neptune MAH5500B Front Load Washer
Hi When spin drying or any fast spin cycle it has a very loud rough bearing type of noise
sounds like main tub bearings are gone ..turn the drum by hand if it rumbles its bearing dont use it ... this is not a good job to do.
Feb 27, 2011 | Amana NAV5800AW Top Load Washer
The washing machine makes a lot of noise during the spin cycle , can it be a faulty bearing?
Sounds very much like it could be.
From the front of the washer, spin the drum by hand, if it feels rough or is noisy, then the bearings have failed.
There should be little or no noise.
Jan 26, 2011 | Washing Machines
Sounds louder than normal, in spin cycle.
Could be the drum bearing failure. Turn the inner wash drum by hand. If it feels rough or makes a rumbling sound would mean that the bearing have failed.
Aug 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
Very noisy spin cycle .sounds like a bearing problem
Spin the drum from inside the washer, if it feels rough or is rumbling, then the main drum bearings have failed.
Hope this helps.
Dec 31, 2009 | Hotpoint Washing Machines
In spin cycle, there is a loud metal on metal sound. could it be a bearing going out? the machine still spins but much slower, and the banging sound occurs in one place every revolution during the spin...
Hi
Remove the drum belt, and spin drum by hand.
If it feels rough, or it is noisy, then drum bearigs have failed.
Please rate my solution.
thanks.
Jul 24, 2009 | Whirlpool Washing Machines
Spin cycle shakes the whole house everytime why
check first if any of the legs are not sitting flat on ground,check the roughness of bearings by placing your hand in the drum and rotate slowly back and forth,loose balance weight could also be a cause but id say it sounds like bearings
May 07, 2009 | Washing Machines
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Does not begin cycle
The buzzing noise sounds like the water valve calling for water.. check your water suppy to washer... dont sound like its getting any water or theres a blockage kinked hose ect.
Sep 02, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
