Question about Samsung Digimax 430 Digital Camera
Flash Does not work
The flash sign on the viewer has a line thru it.  How do I fix it thru the setup on the camera?
  • 3 Answers
You can`t do it on Set-up.Fix it by pressing the flash icon on the menu button until you reach your desired flash setting.
Posted on Mar 28, 2008
Flash not working on s1000
One thing you could try is telling us the maker of your camera. At least three companies make model S1000 cameras.
Nov 21, 2013 | Cameras
The problem is with one of the capacitors, Sony can replace it for you at a cost of $80. This error can come, if we click photos continuosly, the capacitor may get heated up. We need to give a gap of 3 to 4 seconds. Time to be given for the flash to get recharged after a click.
Just give a call at Sony help line. 800.222.SONY, they will replace the capacitor.
If its worth the cost, go for the repair, or you can use the device without flash by disabling the flash. At setup just disable the flash and this error wont show up again.
Apr 16, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
D80-viewer and display stay black, the flash
If your camera got moisture inside and you turned it on before it had a chance to completely dry (usually takes several days) you may have caused a short circuit.
Dec 20, 2009 | Nikon D80 Digital Camera with 18-135mm...
My flash on my sony cybershot will not turn on. the button doesnt want to work it just beeps, but everything else works fine. Can I fix this?
Set camera on auto (green mark) and turn on flash by pressing flash sign button.
Or initialize camera by going into menu.
Aug 27, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Instruction on zoom operation and also operation of flash on came
u have 3 problems here zoom,the flash and language ,ok to change the language hit menu .button then first word that shall be setup menu then word on the line number 3 and use right and left arrows to change ,the flash .turn the camera lens wheel on the pyramid sign u see on the front of the cam and then use the push button right side with zigzag sign to switch the flash mode ,push the button then up and down to zoom in and out
Mar 21, 2009 | Vivitar ViviCam 3750 Digital Camera
Horizontal Lines Thru Picture on R967 Camera
I suspect it is a problem with CCD sensor. Let me know if HP were willing to repair it for free.
Mar 08, 2009 | HP Photosmart R707 Digital Camera
Camera flash problem (Nikon)
try to set the menu item for Auto FP to ON (it works in P,S, A, and M modes only) that will activate the Highspeed Sync when you are using the SB-600 flash unit, set the flash mode so the indicator shows the off position (the line thru the lightning bolt symbol) on the top inidcator menu in the its next to the red eye redution icon that will keep the built-in flash off even if you need it in low light. hope that works for you.
Jan 07, 2009 | Nikon Cameras
My camera has never been dropped why isn't my flash working?
Hi jlapread
If your camera is giving you a `E91` error on screen it could be a faulty flash module and need replacing at a Sony Service Center. Contact your dealer for info.
But, before you do that try steps 1 and 2 below.
Here is some things you can try:
1. If it is only a setting you can select the `green` camera for auto shooting and then press the `UP arrow key until the flash sign is shown on the screen. The screen will also say `Flash On`. Take a picture to see if it works.
If not proceed to `2` below.
2. Press the `Menu` button.
First select the `Green` camera on the selection knob.
Scroll with the right arrow to the little toolbox picture.
Once in the setup menu scroll down to the toolbox picture with a 1 under neath.
Press the right arrow arrow and then scroll to the `Intialize` option.
Press the right button and select `OK`.
Press the middle button on the arrow selector.
Camera now wants to know if you are sure, select ok.
You will now have to enter the date again and setup any `Program` settings you might want on the camera.
Now take the camera into a dark room - as it is now on `Flash Auto` and test to see if the flash works.
If none of these helped you, you can take the camera to a repair agent and get it fixed. I have replaced numerous of the flash modules at approximately a quarter of the cost of the camera.
Hope this information helps you.
Good luck
Jan 03, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
E91:01 Constant flash sign on Cybershot DSC-W80
Press Menu button
togle across from REC Mode to setup
togle down thrice from camera to setup 1
togle across into sub menu
togle down from four times to Initialize
togle across again to the sub-menu
togle up from cancel to OK
press center button to accept the OK choice
Screen changes and so press okay again
It should restart the camera
Opening on the 'Clock Set' screen
togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
If it is working then don't forget to set your Clock.
Oct 29, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Flash wont work
This error is shown when the camera can not charge the flash compasitor in the camera it can be fixed with a new flash circuit.
Mar 07, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Samsung Digimax 430 Digital Camera Logo
55 people viewed this question
Top Samsung Cameras Experts
Are you a Samsung Camera Expert? Answer questions, earn points and help others
