Question about Mattel Barbie 3-story Dream Townhouse House
Dismantle barbie house
How do I remove the posts on the barbie house for dismantleing
How do you dismantle the treadmill to move house?
If you wish to get some details about treadmill repair ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 27, 2016 | Avanti Fitness AT480 Treadmill
How to dismantle Motor housing for a makita cordless circular saw for diagnoses
The replacement part will cost about as much as a new saw. The housing and case is probably warped and deformed enough that it would nearly impossible to get the old one out and a new one in.. Get a new saw.
Aug 19, 2014 | Saws
How do I dismantle it?
a) Remove the water tank and the coffee bean container cover.
b) Remove the three fixing screws of the coffee bean container.
c) Remove the three fixing screws of the powder compartment.
d) Remove the two fixing screws of the front operating panel.
e) Remove the rear housing screws
f) Remove the two bottom housing screws
g) Turn steam dial to the right and remove the housing by pulling upwards.
Apr 28, 2014 | Starbucks Saeco Italia Digital Barista...
How to replace my ac expansion valve on my bmw e39 540i?
YOU NEED TO HAVE AC SYSTEM DISCHARGED AT DEALERSHIP.REMOVE MOST OF THE DASH TO REMOVE THE EVAPORATOR HOUSING TO GET TO REMOVE EXPANSION VALVE.BEST TO LET DEALERSHIP FIX.YOU HAVE TO DISMANTLE MOST OF THE DASH TO REMOVE EVAPORATOR HOUSING TO FIX EXPANSION VALVE THIS JOB VERY HARD.
Jul 01, 2011 | BMW 545 Cars & Trucks
Where is the voltage regulator located on a 1991 lexus ls 400
The voltage regulator for the alternator is located inside the rear housing of the alternator. It can only be accessed by removing the alternator and dismantling it. If the regulator is faulty it is repair by replacement usually by swapping for an exchange unit from an auto electrician. If the alternator is not charging it may just be a case of the brushes inside the alternator being worn out and requiring replacement.It will still be required to remove and dismantle to carry out their replacement.
Oct 17, 2010 | Lexus LS 400 Cars & Trucks
How to dismantle the housing of my P910i without damaging it?
On your flip top key pad, you can remove first the middle cover, it is clip type so no need to un scew, but just be very carefull.
after removing it, you'll see to set of screw, remove it so that you can take out the flip key pad,
turn your unit back, near the camera , there are two small cover there , remove it and you will see two screw, take it out
open the battery cover, remove the battery and sim card and the memory card, inside you will see, again two set of screw, take it out,
now all the screw has been removed
on the side oy your unit where you ca find the scroll, try to plip out the cover usig a twizzer or any pointd object, just flip the cover easily until you where able to remove the topcover completely
now just support the LCD, be very carefull so that may never damaged the flex of your screen
at the back of the screen, there are again another set of screw, remove it slowly, make sure that you supported the screen properly
then you can remove the lcd after taking out the stainless cover protection
removing the board is very simple, just lift the board a little higher enough for you to see the back of the board, there is another flex wire attached to the board and the scroll switch, remove it carefully.
then thats it, you had dismantle your unit
Nov 01, 2009 | Sony Ericsson P910i Cellular Phone
Amilo m1451g the power socket gets very hot
Of all laptops I have dismantled I have found the power socket on the motherboard, although I have not yet dismantled a Fujitsu Amilo.
To get at the power socket, it requires dismantling the laptop completely.
Jul 16, 2009 | Fujitsu AMILO PC Laptops
Need a drwaing of how to dismantel the printer hp photosmart 7450
I posted some help on separating the 2 covers. I didn't do any further dismantling than that ..
Cheers,
Paul.
Nov 08, 2008 | HP Photosmart 7450 InkJet Printer
Ignition replacement
1)First dismantle the batteryleads to avoid electric hazard.
2)Dismantle the steering wheel by taking the centre cover of with a screwdriver carefully,and then take the wires of the centre cover to the horn, loosen the nut 24mm in the middle but dont at first take it off, then wobble,and pull the steering wheel towards your self till it loosens, then dismantle the nut and take the steering wheel off.
3)Unsrew the 2 srews in the undercover and take the upper and undercover off.
4)dismantle the 2 or 3 screws (depending on model) pointing towards you, holding the wiper and blink contacts, dismantle the electric cable connections from the contacts and then remove the contacts from the casing.
5) remove the bolt in the housing (aluminium) holding the ignitionswitch, located from down without a head, needs a hammer and a chisel, can be hard to loosen.
6) turn the key clockwise so it pulls back the slot from the steering axel.
7) remove the electrical cables from the ignition switch.
8) pull the aluminium housing toward yourself sliding it upwards
9) exchange the lock,casing and electrical bottom piece all together and insert a new bolt in the aluminium housing
10) reverse to install
Jul 20, 2008 | 1991 Volkswagen Cabriolet
Dismantle
I have the same need, and I need to take it completly apart, i got 2 screws but cant figure the rest
Apr 13, 2008 | Motorola Mobility TracFone C139-4 Cellular...
Mattel Barbie 3-story Dream Townhouse House Logo
214 people viewed this question
Top Mattel Toys Experts
Nikki  Mclean
Nikki Mclean
ray gallant
Are you a Mattel Toy Expert? Answer questions, earn points and help others
