Question about IBM Wheelwriter 6 Typewriter
My IBM 6783-2 will not print any letters and the hammer is not striking the wheel
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 96 Answers
Your print solenoid probably has a broken cap. There are some companies that sell the "kit" with instructions on how to replace the cap.
Posted on Mar 02, 2015
  • 3594 Answers
SOURCE: IBM Pers. Wheelwriter 2 Ques
Probably the platen isn't fully seated in the side frames. Check to be sure the black latches are lined up with the frames, then press firmly on both ends of the platen.
This should help
DickyO
Posted on May 12, 2008
  • 329 Answers
SOURCE: IBM wheelwriter
Is the hammer moving at all? There is a rubber part on the I think left side of the ribbon hammer, down on the side of the printer. This will adjust the amount of impact. I really doubt if
this is the problem, but worth a try to look at. This part and I think it is a blue slide will move up and down to adjust the impact. Possible lubrication and there is a large spring that actually pulls that hammer forward, check to see if this spring is OK. Other than that electronic problems such as main board, printer motors, etc. Does hammer move freely by hand? Also mechanical binding in the printer... GOOD LUCK.
Posted on Jul 23, 2008
SOURCE: Ibm wheelwriter 5
yes it was true that the cap was broken. temporarily, i just cut a piece of plastic from a spoon, same thickness as the cap then place it between the plunger and the solenoid. and now my wheelwriter is typing great! all letters are clear and much black in color. thanks for pointing where the cap was place. easy to find it.
Posted on Jan 07, 2010
  • 3594 Answers
SOURCE: Our IBM Wheelwriter 3 will no longer type.
The print solenoid cap is probably broken. We sell them for 20.00 including instructions and shipping.
DickyO
Cleveland business Machines
216-241-0027
Posted on May 13, 2010
  • 3594 Answers
SOURCE: When I type or strike
It sounds like the machine is gummed up you probably need a cleanimng and lube..
DickyO
Posted on Aug 16, 2010
The hammer does not strike on the platen
You need a print solenoid cap. We sell them with instructions for 20.00.
DickyO
typewroterguy@att.net
Mar 09, 2015 | IBM Wheelwriter 10 Series II Typewriter...
Hi we have an old ibm typewriter. I changed the ribbon and the wheel. I cleaned everything but still prints half of the letters. The top part to be exact.
There should be an adjustment on the head that sets the angle of the strike for the wheel. Unfortunatley there are no diagrams available for this technology
Jan 06, 2015 | IBM Wheelwriter 1500 by Lexmark Electronic...
I have an eIBM 6783-2 electronic printer but the hammer is not sticking with pattern
If you are trying to say not striking the platen you have a a bad print solenoid cap.
We se4ll them for 20.00 with instructions.
DickyO
216-269-3918
Feb 12, 2014 | Lexmark Wheelwriter 15 Series II...
The striking hammer on my IBM 6783-2 electronic printer not working
It sounds like you have a Wheelwriter 15 Series II based on the model number you gave, but the answer is probably the same for almost any Wheelwriter: There is a small mechanism, I believe called a solenoid, that moves a horseshoe-shaped part that actually "fires" the striking hammer against the individual letter-spokes of the daisywheel print element, to put letters/numbers/symbols on paper. I have posted a close up photo of the left hand side of the carriage that moves back and forth while you type, which holds the ribbon, correction tape, and mechanisms for positioning the daisy wheel print element so that the hammer can strike the correct letter, number, etc. when selected from the keyboard. If you go to your machine and remove the ribbon and correction tape from the carriage, you will see that right in the middle of the picture is the thing I'm talking about. It looks like a small electric motor like you might find in a toy racecar, is about the same diameter as a USA "quarter", and is I think about an inch thick. I've replaced one of those once, using the part from a damaged typewriter to replace the matching part in a typewriter that worked except it wouldn't print, just like the problem you describe. It's been a few years since I did that but it did not require any specialized tools, and I did not have a manual or a video to refer to. I think this mechanism has stayed mostly the same for about 20 years worth of Wheelwriters, though I can't promise that a part from a Wheelwriter 3, for example, would work to replace the seemingly same part in a Wheelwriter 15 Series II like yours. I think there are many places you can buy this part from online, and with the information I've provided here they may better be able to help you trouble shoot your problem. I can't promise that this will fix your problem but there's a pretty good chance that it will. As far as what I do is concerned, I buy, fix where I can, and resell Wheelwriters, mostly on ebay, and some time in the next month or so I'll start selling Wheelwriter parts. I bought a pallet of 20 Wheelwriters a few months ago and it turned out that many of them were damaged from how they were stacked on the pallet (which I kind of expected even though I couldn't look through them all ahead of time). I've sold the undamaged ones and parted together a few more to sell, but soon I'll run out of enough undamaged cases to sell complete units and that's when the parts sale begins. I don't think you'd want to wait until I get around to selling parts, but if you do want to check out what I've listed, I'm on ebay as "greatsurplusbuys". -- Dan93b344b9-a430-4546-b0f8-b34a540d9046.jpg
Feb 12, 2014 | Smith Corona Wordsmith 200 Typewriter
You have a bad print solenoid cap.
We sell them for 20.00 with instructions
.DickyO
216-269-3918
Feb 12, 2014 | IBM Wheelwriter 6 Typewriter
IBM Wheelwriter-3: the hammer that strikes the letters no longer moves. Is there an easy fix?
You probably have a broken print solenoid cap. If you have any apitude for repair we sell the part with instructions and shipping for 40.00.
DickyO
Cleveland Business Machines
216-241-0027
Apr 19, 2012 | IBM Office Equipment & Supplies
The striking hammer does not function
I know this is pretty basic but did you push thelever next to the print hammer to the back to latch the mech. to the rear?
DickyO
Apr 18, 2012 | Smith Corona Wordsmith 200 Typewriter
Letters now well formed
first of all check out replacing the ribbon cartridge.if the cartridge is got torn or over stretched.so replace the ribbon . There is a solenoid down to the left of the horseshoe shaped printwheel mount. If it is gummed up or the nylon hammer plate is broken or missing the hammer will not strike the printwheel and you will not get print out or broken letters on print. Check the solenoid with a thin screwdriver by pulling and pushing the plate and rod in and out as if you were trying to make the solenoid push the hammer toward the type wheel. If the hammer moves when you bush the solenoid then it may be gummed up or not getting electrical impulse. If it moves but the hammer doesn't move then the cushion at the tip of the solenoid is missing and the gap is to great for the solenoid to act upon the hammer.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Jan 12, 2010 | IBM Office Equipment & Supplies
If this is an IBM wheelwriter you need the plastic solenoid cap.
We sell them for 20.00 includes S&H and inst.
216-241-0027
DickyO
Apr 08, 2009 | IBM Office Equipment & Supplies
Brother ML300 Typewriter
Is the hammer striking the paper? What letters print when you press a key? Can you determine if the printwheel is turning?
Dec 28, 2007 | Brother ML-300 Typewriter
IBM Wheelwriter 6 Typewriter Logo
238 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
