Question about Oregon Scientific RM826 Exactset Travel Alarm Clock
Backlight doesn't work
Light is supposed to come on when I press on it. I installed new batteries and it still won't light.
I have the kwikset keypad that is supposed to light up and it did for awhile since I've had it for several months and now all of a sudden it won't light up. The batteries are fine and I tried new batt
"My keypad won't light up when door is locked when you push lock won't light up green."
Try this:
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
Good luck--and please provide feedback if this helps!
Dec 11, 2011 | Kwikset 909 909-L03 Lifetime Polished...
I have a Singer Sewing Machine #9444. There is no electrical getting to my machine since the light doesn't work and the foot pedal doesn't work after I turn on the machine
Try replacing the light bulb or rerouting the wire so it won't be affected by the light bulb or the foot pedle. Becarefull though because if you rerout the the wireing in the foot pedle you're taking away the off/on swich so it'll stay on. You may want to open up the foot pedle and see if there is anything loose, not conected or broken. The pedal is used as an on/off swich so it may just be stuck in the off position and not making contact when you press down on it so it won't turn on.
If you can't fined a blulb for it by the way you can disconect the socket where you screw it in and install a new one. Make sure the new one will fit in the same hole though. Then it should be easy finding a bulb for it. PLEASE MAKE SURE THE MACHINE IS DISCONECTED BEFOR YOU DO ANY OF THESE THINGS. Good luck!
Sep 30, 2011 | Sewing Machines
When i receive a message, my e73 doesn't make any noise. i've taken out the battery several times, turned it off and on, let the battery die, but it's not working. the only thing that indicates...
for it to ring delete all your messages from your inbox and outbox then reboot your phone (turn it off then back off) hope it works for you it did for me:)
Jun 21, 2011 | Nokia E73 Mode Cell Phone
Screen does not light up - stays black
remove charger,
remove battery
press and hold the power on button for 1min
place battery
press power on button,
if it doesnt light up, then check your memories chips. try another one
good luck
Jun 19, 2011 | Sony VAIO Notebook
When I try to turn my computer on, it won't do anything. All I see is the gold light blink in the lower left corner.
Hi mcfarlandger,
If you see power lights but nothing appears on the screen, it could be a "POST" (Power-on Self Test) problem or simply LCD problem.
Here are some steps that you can try.
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left from the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor. You may need to press the Fn + F10 or F6, depends on the key designed on the keyboard to toggle between displays.
3. If you get display from the external monitor, I'm sure your having problem with the LCD components. In this case, check and replace faulty LCD backlight, LCD cable or LCD inverter. The LCD inverter is often a culprit.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the issue not to POST.
5. If reinserting the RAM doesn't help, most likely your motherboard needs to be replaced.
Hope this helps.
Jun 12, 2011 | Acer Aspire 5330-2339 Notebook
I changed the batterys in my 1F78-151 thermostat and now the backlite does not work.....
• Display Backlight - (Not available on earlier models.) The display backlight improves display contrast in low lighting conditions. Selecting backlight ON will turn the light on for a short period of time after any button is pressed. Selecting backlight OFF (default) will keep the light off. Turn the display backlight feature ON as follows: 1. Press TIME and RUN buttons at the same time. The display will show "d-L" and "OFF" alternately
Dec 22, 2010 | Heating & Cooling
Oregon Scientific RM826 Exactset Travel Alarm Clock Logo
32 people viewed this question
Top Oregon Scientific Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Oregon Scientific Audio Player and Recorder Expert? Answer questions, earn points and help others
