Question about Electrolux Refrigerators
Unlock control panel on electrolux beverage centre
Lock control #3 on Electrolux slide in range
I appreciate your post, Billy!
I understand that the lock control will not unlock on your Frigidaire range. I noticed that you have disconnected the electricity and the range is still not unlocking. I would recommend holding down the clear/cancel button for at least 15 seconds. If that does not unlock your range I would suggest that it could be a possible issue with your door lock or control panel. For any repairs to be completed I would recommend having a professional technician out to complete a diagnosis. This will help you avoid any unnecessary part purchases. Hopefully this information is helpful. -Matt
Mar 08, 2015 | Electrolux Kitchen Ranges
Why I only have blank display and only sign "LOCKED" plus blue delay time and little red square on the right.?nothing happens when i push any of these?
Good Morning Eva Ehrlich, thank you for your inquiry!
From what you have described the control panel on your Electrolux dishwasher is locked and will not allow you to operate it. Could you please provide me with your model number? You can locate the serial tag (which lists your model number) on the inside wall of your dishwasher. Once I have that information I can provide you additional assistance in unlocking your control panel. -Matt
Jan 02, 2015 | Electrolux Dishwashers
The timer on my electrolux front load wont go to zero and allow the door to unlock
Good Morning friend, thanks for your inquiry!
Based off the information you have provided your Electrolux frontload washer the door will not open and the timer is stuck. I would recommend performing a reset on your washer and you can do that by unplugging the power cord or flipping the household circuit off for ten minutes. If that does not help to resolve your issue I would suggest consulting with a professional technician for an accurate diagnosis. It could be a potential problem with your control panel or door latch assembly. I hope this information is helpful. -Matt
Oct 21, 2014 | Electrolux Washing Machines
Electrolux oven control lock won't unlock
Good Afternoon Friend,
I see that you are having trouble with the control lock not unlocking on your Electrolux range. I suggest resetting your appliance, by shutting the power off at the circuit breaker, for 3-5 minutes. Once you have restored power, the first thing you will need to do is set the clock. You will do this by entering in the time and pressing the start button. If the door has not unlocked, try pressing and holding down the control lock button for 5-10 seconds. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your range status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 16, 2014 | Electrolux Kitchen Ranges
HBCN05FVS 150-Can Beverage
Perhaps an ornamental lock on the door..keeping key in your possession or hidden
Oct 20, 2013 | HBCN05FVS 150-Can Beverage
I see moisture between the glass panels of the door.
Hello roderick234 - From what you have described it sounds like the beverage center has a poor door seal. When cold air and warm air outside is entering it causes condensation. Try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then I suggest contacting your manufacturer and see who they recommend to repair the unit.
Nov 10, 2012 | Electrolux 6.0 Cu. Ft. Beverage Center -...
Refrigerators Logo
63 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
