Question about Kubota Garden
Castel garden xe70 clutch cable broken
Cant fit new cable
2 Suggested Answers
  • 252 Answers
SOURCE: I need a diagram for
pauly46_0.gifpauly46_1.gif hi there winger1886
pauly46 here
with 20/122 the blade timming must with one blade vertical and one blade horizontal
doesnt matter which one but as long as there is 90 degrees between blade as the rotate
in the picture the r/h blade rotates anticlockwise and the l/h blade rotates clockwise
the picture for belt / blade timming is straight forward - loosen tensioner rod and back it off completely , loosen 2 x bolts under the two toothed pulleys and remove the 2 belt guide/ stoppers from the l/h side - place both blades in the rqd position ( you may need someone to hold other blade in rqd position - fit the belt onto pulleys as in the diagram- continually check while fitting that timming has not moved from where you placed them ( they have to be 90 degrees from each other ) and then tighten the tensioner rod to hold position - rotate by hand recheck timming - if good loosly fit guide the 2 guide stoppers to l/h side and place 3.5 kg of tension at the middle point of the longest run of timmed belt ( belt should only deflect 10 mm with 3.5 kg of tension )
once tensioned tighten the 2 bolts under the toothed pulleys and tighten loc nut on adjuster
tighten the 2 stopper / guide nuts
in the picture the left hand blade is a l/h thread undo it right and tighten it left
the blade on the right is a normal thread left loose - righty -tighty
cheers hope it helps
Posted on May 23, 2011
I have a Toshiba HDDR500EO3X...nothing to connect it to my computer and the external port is so small I have no idea what I need to connect to my HP computer
Toshiba, for HP forum, OK.
ahhhhhh its and exernal hard disk drive and chassis.
mine has USB cable and Esata cable and power.
yours has 1 cable new. usb.
what HP computer is it , which one. is it model numbers on the service tag. 1000s of pCs made by HP from 1982 to now, endless list.
i cant guess ever.
500mb (tiny) external drive.
by TOShiba.
listed as obsolete at Newegg. so is not new, (NOS?)
i guess you got it for free? and now the USB cable is missing
that it?
here is one cable, this fits the tiny HDD end
and then fits all PC made, (no dont fit cell phones)
try to know there are many classes of USB connectors
(lots) my guess you lost the comes with it cable
or you PC has no standard full size USB jacks.
some super tiny thin notebooks can not have full sizes USB jacks
so need a special USB mini cable, unseen by me, no help.
http://www.ebay.com/itm/USB-Cable-Data-Cord-For-Toshiba-HDD640E04X-HDDR250E03X-HDDR500E03X-Hard-Drive-HD-/272192214668?hash=item3f5feb968c:g:~lgAAOxyaqlSToBi
May 23, 2017 | HP Computers & Internet
My suzui wagon r 2000 I just had new clutch fitted and cable but my pedel is very hard
take it back for rework by the shop that did the job
new cables make the pedal operation very easy and if it is hard , it indicates that the cable has not been fitted without sharp bends or too many bends or incorrectly fitted or ---and this would not be uncommon ---not a new cable at all
In any case the car should not have been handed back with that problem
Mar 03, 2016 | 1999 Suzuki Wagon
The hood release cable broke on a Chrysler New Yorker 1995
may be able to trip it with a metal coat hanger bent to fit up in there..
Jan 08, 2014 | 1995 Chrysler New Yorker
Chevy cavalier transmission cable
Try some cables with quality. I have bought a lot here. Just have a try.
Jul 23, 2012 | Chevrolet Cavalier Cars & Trucks
While under the car checking for a noise I pulled down on the clutch release arm. Now the clutch is completely disenguaged. I cant get it too enguage.
I suggest that the self adjusting clutch cable / mechanism has locked - taking up all the "slack" you gave it.
Check for a ratchet arrangement behind the clutch pedal - or maybe in the cable itself. You may need a new clutch cable fitting.
Aug 04, 2009 | Volkswagen Jetta Cars & Trucks
I cant find a usb cable
what does your cable enfs look like I worked at a new recycle place and have a few cables .send apicture of the hookup on camera to ltljm1946@gmail.com
Jan 14, 2009 | Cameras
IDLE FLUCTUATION
adj idle with cable adj thanks Trevor
Aug 05, 2008 | Ford GT Cars & Trucks
Garden Logo
119 people viewed this question
Top Kubota Garden Experts
Vernon Taylor
Mike Henne
Level 1 Expert
Are you a Kubota Garden Expert? Answer questions, earn points and help others
