Question about NRS Fleck 5600 - 64,000 Grain Timer Water Softener
Clean softner tank from brime - NRS Fleck 5600 - 64,000 Grain Timer Water Softener
Waterside water softener model MC250 Dear Sir, Salt level did not go down during regeneration. I poured 2 pints of warm water to break solidified tablet salt, I found moist salt, but very little water in...
the salt in use should water softener salt and nothing else
there is water added to the salt crystals up to the overflow hole
during regeneration that salty water (Brime) is drawn into the unit and upon finishing the process that reserve is refilled for the next time
there is little salt actually used during the regeneration process ( around 4 regenerations to a 25 kg bad )
Apr 13, 2017 | Dishwashers
How do you get the agitator to come out the fabric softner dispenser is filthy and all needs to be cleaned
By grasping just the fabric softner dispenser and wiggling it from side to side while pulling up the softner dispenser will come out to be cleaned.
GENE
Oct 13, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
The softner is no longer been pulled into cycle. We have cleaned the pwder/softner compartment and also followed the service instructions, removed the filter and cleaning that, but the softner is still in...
Mine did this when the filters in the hoses were clogged and it was taking too long for the water to enter the machine. I cleaned the filters and the softener was pulled into the cycle. Hope this helps.
Jun 20, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Dirty Water in water softner tank
Solar salt is full of sediment and even stones at times. Al that white scum on top is the reaction between the salt and sediments in solar salt. All that sediment gets drawn into valve during brining and causes many problems. That stuff is cra***. Use either Dura cube or Hardi cube salt and you will not have this problem again. It is available from most water treatment dealers
RJ
Dec 29, 2009 | Culligan Sediment Water Filter Heavy Duty
Bad oil leak around oil pan, does somebody have an engine diagram for the Dodge 3.0 in this Grand Caravan?
This is what I found on my 1998 with a 3.0 motor Most likely you have a rusted pan with a hole on the passenger side of pan, clean the oil pan real good and inspect it real good and check for small leaks,
Also the transmission pan is also known to rust through on the left side top and bottom, Salt and brime plays heck on all pans and brake lines
Sep 30, 2009 | 1996 Dodge Grand Caravan
FABRIC SOFTNER TRAY STAYS FULL AND IS NOT RINSEING OUT
HiYa dh1200s
The softener tray needs to be cleaned out or the sensor for this replaced.
Yes, not enough water entering machine so not enough water to rinse out the softner
Please leave a good rating before you sign off.
Mar 29, 2009 | Maytag Neptune FAV6800AW Top Load Washer
"fabric softner staining the clothes"
make sure you delute it with water. yes fabric softner will start to stain your clothes if you use too much of it. I would recomend stop useing it for a while. so you can clean the washer out. There is a product called Washer magic or Affresh that cleans out residues built up in your washer. or you can just run several loads of HOT water and bleach to clean it out. The hot water will melt the left over fabric softner in your washer. Fabric softner is kind of like hardend bacon fat thats what it looks like in your washer after time and if you do not clean your washer it builds up and builds up.
Also i do recomend alternating liquid detergent and powdered detergent. The reason why is powder leaves a residue that liquid takes away and vise versa. try this and let me know how it goes
Feb 12, 2009 | Maytag PAV2300 Top Load Washer
Kenmore 44082 washer won't take in fabric softener
Remove hoses from fill valve, clean screens inside fill valve, if this does not fix problem, replace valve.
Jan 17, 2009 | Kenmore 44102 Front Load Washer
Adding Softner
try taking the dispenser off and cleaning it might have a build up of old softner
Oct 15, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
NRS Fleck 5600 - 64,000 Grain Timer Water Softener Logo
Top NRS Home Experts
Donni Steen
john h
Bill Boyd
Are you a NRS Home Expert? Answer questions, earn points and help others
