Question about Brother New-MFC9970CDW - MFC-9970CDW Wireless Laser All-in-One Printer, Duplex Printing - BRTMFC9970CDW
Toner is bleeding on paper
When you print toner on side of copy
2 Suggested Answers
greg_margo
  • 1959 Answers
SOURCE: Sent faxes not printing clear
Per Brother's User manual,
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_4100_4750e_5750e_EN_98.PDF
Clean the machine’s interior and the primary
corona wire of the toner cartridge This is a common cause for your printing/copying problem. This should solve your issue. Best of luck.
Greg
Posted on May 20, 2009
Canon ic-1320 toner rubs off copies
if toner rubs off then fuser unit is not heating paper to fuse toner to paper. You may notice paper printed on is not hot .
Jul 14, 2016 | Canon imageCLASS D1320 Laser Multifunction...
Tip
How to make duplex copies with a Brother MFC-240C printer
The Brother MFC-240C is a well-performing multifunction color printer. There is a lot that it can do, but one limitation it has is the inability to make double-sided copies. If you need to make a duplex copy of something, you can do it manually by re-feeding the paper once you've copied the first side.
After the first side of the page has been printed, let the paper sit for a minute or so to make sure the ink has dried. Then, put it back into the paper tray on the top of the stack. Make sure the back side of the page (the side that has not been printed on yet) is facing down, and the lead edge of the page (the edge that was fed out of the printer first) is facing toward the inside of the printer, rather than toward you.
Once the paper is set, push the tray back in and print the document or image that you want to appear on the back of the page. If you are printing multiple pages, position the paper so that the page you want printed on first is on the top of the stack.
The MFC-240C was not designed for duplex printing, so you may run into some issues with it, especially when you are using very thick or very thin paper. With very thin paper, the ink may bleed through to the other side of the page. With very thick paper, you may have to let the paper sit for a longer time after the first side is printed, because the ink could take longer to set and dry.
on Jul 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
I have e brother 7840w. I changed toner and drum. After that the pages of a copy came out dark in both sides of paper. Who could help?
You may need to pull the toner out and turn it end-to-end several times to distribute the toner evenly. The excess toner on the prints may go away after a few more copies.
Jun 16, 2015 | Brother Office Equipment & Supplies
How do I clean toner from machine?
Probably it's the jammed paper that might caused the error. I suggest have it serviced by the technician. Be aware of the paper handling capacity of your machine to minimize jamming:
3300MFPV_X
Phaser 3300MFPV/X, Copy/Print/Colour Scan/Fax, B&W, 28 ppm, A4, 1200 dpi, 50-sheet ADF, 250-sheet Paper Tray, 50-sheet Multipurpose tray, 150-sheet Output Tray, 96 MB, Automatic 2-sided printing, USB/Ethernet, PCL/PS3, Scanning software, 220 V
Apr 28, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
A copy has toner all over the right side on the paper.
Are you mean that toner isnt baked enough? If yes then you have problem with fixing roller bushings.
But if the toner is like printed, change blade and drum.
If the toner is like spiled on copy, vacume and clean the machine
Jul 01, 2010 | Sharp AL 1631 Copier
Kyocera mita km-1820 not printing clear copies
you have to check the duplex unit on the machine itself.
May 01, 2009 | Kyocera Mita KM-1815 All-In-One Laser...
Ricoh Aficio 1022 Toner Bleeds
I ended up taking out the toner bottle completely and just running copies (with no toner in place) until they came out crisp. This used up the toner that was floating around. I was able to make about 700 copies before I needed to put the toner back in. But a **** of paper is still much cheaper than getting a service tech.
Apr 08, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Poor print quality toner flaking and coming off stock
Have you tried fresh paper directly out of the package? Once you open a package of paper it immediately begins to absorb moisture out of the air.The toner wont bond well to the paper.If you send the same sheet of paper back through themachine(copying the other side of course)and it copies properly then you have moisture in your paper.The final element in the process is the fuser, which operates at about 350 degrees fahrenheit.It literally cooks the moisture out of the paper.when you send it through for the second time the toner will bond properly.
Mar 23, 2009 | Office Equipment & Supplies
Streaks on color copie
You must pull 2 sided glossy from the stack bypass and set on color paper.
Apr 11, 2008 | Canon CLC 1120 Color Copier
Samsung CLP-510 Toner Bleed
The following can cause bands (vertical on a normal page)
Faulty Toner cartridge
Faulty Drum Unit
Faulty Transfer Belt
Contaminated Fuser
Damaged or dirty LSU glass
Jan 09, 2008 | Samsung CLP-510 Laser Printer
Brother New-MFC9970CDW - MFC-9970CDW Wireless Laser All-in-One Printer, Duplex Printing - BRTMFC9970CDW Logo
37 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
