Question about GPS
Keypad locked on telephone unable to make calls
When dialing a telephone number the hadset will only allow the 1st 3 numbers to be enetered and then emits a continuos tone every time a key is depressed afterwards.
 I suspect one of my children may have played with the handset and inadvertantly locked the keypad via a menu option.
I have tried accessing several options on the menu that may support this and turning the feature off but with no success
  • Maro80 Jun 04, 2008
    Im using a poivy to call my family so every time i call da thing says your call cannot complette is bcoz of some problem on da sound device but i have no idea what is it...so please help.
Go to settings, and choose keyguard settings. and then set the auto keyguard to off
Posted on Oct 29, 2007
Panasonic phone model kx-ts108w how to change emergency to a new number on this phone
Page 20 in the manual
ftp://ftp.panasonic.com/telephone/om/kx-ts108_en_om.pdf
PDF]Operating Instructions - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/telephone/om/kx-ts108_en_om.pdfIntegrated Telephone System. Model No. KX-TS108W. Pulse-or-tone dialing capability. Operating Instructions. Preparation. Basic Operation. Advanced Operation. Useful Information. PLEASE READ BEFORE USE AND SAVE. Panasonic World Wide Web address: http://www.panasonic.com for customers in the USA or ...
20
Storing Phone Numbers
You can store up to 20 phone numbers in the one-touch auto dial buttons
(10 numbers in UPPER memory locations, 10 numbers in LOWER
memory locations).
Make sure that a call is not put on hold.
To store in an UPPER memory location
It is recommended that you program an emergency number in the
EMERGENCY button.
Press
(PROGRAM)
Enter a phone number, up to 22 digits.
If you enter a wrong number, press
(PROGRAM)
and start again from step 1.
Press one of the one-touch auto dial
buttons.
A long beep sounds.
The unit will return to the standby mode.
If 3 beeps sound, the number entered in step 2 may be over 22 digits.
Press
(PROGRAM)
to return to the standby mode, and start again from
step 1.
If a pause is required for dialing, press
(PAUSE)
where needed. Pressing
(PAUSE)
counts as one digit (p. 24).
When using the Dial Lock (p. 27) or Call Restriction feature
May 01, 2018 | Panasonic Lands Phones
I need instruction manual to program speed dial
I was unable to locate a user manual for that particular device, however the basic instructions for programming speed dial functions are normally very similar between most phones.
Generally there are ONE TOUCH Speed Dial buttons labelled something like M1, M2, and M3 on the dial pad somewhere.
There should also be another button labelled PROG or STORE on the keypad as well.
Normally to program a number into a ONE TOUCH speed dial memory location you carry out the following procedure:
Lift the handset.
Then press the PROG (or STORE) button.
Now just use the number keypad to dial the full telephone number that you want to store in a Speed Dial location.
Once the full telephone number is dialed, then push the M1 button to store that phone number in the M1 One Touch Speed Dial location.
The phone may or may not show some kind of confirmation that the M1 location was just programmed, then just hang up the handset.
Now when you lift the handset and press the M1 button, the phone should automatically dial the phone number you programmed into it.
Now just repeat the same process for the M2 and M3 One Touch Speed Dial buttons with other phone numbers if necessary.
To change one of the Speed Dial numbers, just carry out the normal programming procedure for that location using the new phone number and the old number will simply be overwritten.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Dec 02, 2011 | Southwestern Bell FM-480 Corded Phone
How can I make conference call or joint call fron vtech cordless phone
To make two-party call on your Panasonic phone and ask the person on the other line to wait for a moment.
  • Check to see if your Panasonic phone has a flash key feature. If it does, press the flash key down and wait until you hear the confirmation tone. If the Panasonic phone you're using does not have a flash key, hold down the the hook switch for half a second, then release. Dial the number of the third person in your conference call. If you're inviting someone in-house to be a part of your conference call, dial their extension number instead. If you're dialing an outside line you may need to dial 9 before dialing the number.
  • Wait for the new addition to the conference call to answer and then press the Flash key again. Wait an additional two or three seconds before pressing the number three on your telephone keypad. Start your conference call. Once you've pressed the flash key followed by the number 3, as in Step 4, your conference call is established. If you wish to add additional participants simply repeat Steps 3 and 4.
    Regards
  • Jun 30, 2011 | Vtech Cordless 6041 Phone
    How to private my own number example cell phone
    To withhold your telephone number when making an outgoing call, dial the prefix '141' or *67 (mobile) before the telephone number.
    Apr 13, 2011 | Nokia Lands Phones
    HOW TO SEND A FAX
    You can send a fax in a variety of ways. Using the control panel, you can send a black and white or color fax. You can also send a fax manually from an attached phone. This allows you to speak with the recipient before sending the fax.
    To send a basic fax (single- or multiple-page black-and-white fax) by using the control panel.These features allow you to control the pace of your dialing. They are also useful when you want to use a calling card to charge the call and you have to respond to tone prompts while dialing. NOTE: If you need printed confirmation that your faxes were successfully sent, enable fax confirmation before sending any faxes. TIP: You can also send a fax manually from a phone or by using monitor dialing.
    1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed dial button to select a speed dial, or press Redial/Pause to redial the last number dialed.TIP: To add a pause in the fax number you are entering, press Redial/Pause, or press the Symbols (*) button repeatedly, until a dash (-) appears on the display. 3. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, it sends the document to the number you entered. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure your original is loaded print-side down on the glass, and then select Yes.TIP: If the recipient reports issues with the quality of the fax you sent, you can try changing the resolution or contrast of your fax.
    Send a fax manually from a phone You can send a fax from a telephone on the same phone line if you prefer to use the keypad on your phone, instead of the keypad on the control panel of the device. You can do this by plugging in a phone into the 2-EXT port on the back of the device. When you send a fax manually, you can hear the dial tones, telephone prompts, or other sounds through the handset on your telephone. This makes it easy for you to use a calling card to send your fax. Depending on how the recipient has their fax machine set up, the recipient might answer the phone, or the fax machine might take the call. If a person answers the phone, you can speak with the recipient before sending the fax. If a fax machine answers the call, you can send the fax directly to the fax machine when you hear the fax tones from the receiving fax machine.
    1. Load your originals. NOTE: This feature is not supported if you load your originals on the glass. You must load your originals in the document feeder tray. 2. Dial the number by using the keypad on the phone that is connected to the device. NOTE: Do not use the keypad on the control panel of the device when manually sending a fax. You must use the keypad on your phone to dial the recipient's number. 3. If the recipient answers the telephone, you can engage in a conversation before sending your fax. NOTE: If a fax machine answers the call, you will hear fax tones from the receiving fax machine. Proceed to the next step to transmit the fax. 4. When you are ready to send the fax, press START FAX Black or START FAX Color. NOTE: If prompted, select Send Fax, and then press START FAX Black or START FAX Color again. If you were speaking with the recipient before sending the fax, inform the recipient that they should press Start on their fax machine after they hear fax tones.
    The telephone line is silent while the fax is transmitting. At this point, you can hang up the telephone. If you want to continue speaking with the recipient, remain on the line until the fax transmission is complete.
    Send a fax using monitor dialing Monitor dialing allows you to dial a number from the control panel as you would dial a regular telephone. When you send a fax using monitor dialing, you can hear the dial tones, telephone prompts, or other sounds through the speakers on the device. This enables you to respond to prompts while dialing, as well as control the pace of your dialing. TIP: If you do not enter your calling card PIN fast enough, the device might start sending fax tones too soon and cause your PIN not to be recognized by the calling card service. If this is the case, you can create a speed dial entry to store the PIN for your calling card. NOTE: Make sure the volume is turned on, or you will not hear a dial tone. To send a fax using monitor dialing from the control panel
    1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals print-side up in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, you will hear a dial tone. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure that your original is loaded on the glass, and then select Yes. 3. When you hear the dial tone, enter the number by using the keypad on the control panel. 4. Follow any prompts that might occur. TIP: If you are using a calling card to send a fax and you have your calling card PIN stored as a speed dial, when prompted to enter your PIN, press Speed Dial or a one-touch speed dial button to select the speed dial entry where you have your PIN stored. Your fax is sent when the receiving fax machine answers.
    Apr 01, 2011 | HP Officejet Pro L7680 All-In-One Printer
    LOOKING FOR A MANUAL FOR lucent 9510 WIRLESS TELPHONE
    Hi, Click this link for more data : http://www.vineland.org/tech/phones.pdf Regards, vote please, Jay
    Lucent Telephone User's Guide (All Models) For corrections to this document, contact Steve Dantinne at sdantinne@vineland.org or 856.794.6700 x 2350 VoiceMail Welcome to Audix! The first time you use Audix you must record your name and create a password! To Log In: 1. ON Premise Dial 2099 OFF Premise Dial 856-794-6700 extension 2099 You may also dial the main school number to access the voice mail system 1. The system will ask for your extension number followed by the # sign. Note: Teachers will use their voicemail number followed by the # sign It is not the classroom extension number. 2. Enter First Time Password # sign. Record Name As you use Audix, your name will be heard by you and other Audix users. Press 1 Speak your name Press 1 when finished Press # to approve Create Password You will be required to enter a new password with a minimum of 5 digits followed by the # sign. The maximum length of a password is 15 digits. Reenter your password for confirmation followed by the # sign. To Create a Personal Greeting This is what callers will hear when they reach your mailbox. Press 3 anytime you wish to do anything concerning your greeting Press 1 to create your greeting Press 1 to indicate the greeting number you are going to record then speak your greeting Press 2 then 3 to replay the greeting Press # to approve Press 1 to activate for all calls **X or **9 to hang up. To Get Messages 1. ON Premise Dial 2099 OFF Premise Dial 856-794-6700 extension 2099 You may also dial the main school number to access the voice mail system 2. Enter your extension or voicemail number then press #. Note: Teachers will use their voicemail number followed by the # sign It is not the classroom extension number. 3. Enter your Password then press # You are now Logged in. Press 2 (You will hear the day, date and time the message was left and the length of the message. If the message is from another extension you will also hear the person's name and extension number) This is the header To play the message press 0 To listen to header again Press 2 then Press 3 To listen to message again Press 2 then Press 0 To Delete message Press *D To skip to next message Press # To forward Press 1 then Press 2 (record your comment) Press # when done recording. Enter the extension numbers you are forwarding to followed by #. Press # when done addressing. Press # to send. Call Handling Features Volume Control The volume control button will adjust three items. 1. If you are not using the telephone, it will adjust how loud or how softly the telephone rings. Press the up arrow to make the telephone ring louder. Press the down arrow to make the telephone ring softer. 2. If you are using the handset or receiver, it will adjust the sound of the incoming voice. The up arrow will make the voice louder. The down arrow will soften the voice. 3. If you are using your speakerphone, the volume control will adjust the sound on the speakerphone. The up arrow will make the sound louder. The down arrow will make the sound softer. Each item is independent of the other, depending on the device being used. That it what the volume bar will adjust. Hold The hold feature puts a call on hold until you can return to it. To keep a call on hold while you answer another call or perform another task. Press HOLD. The green light next to held call will blink. To return to the held call Press the call appearance button of the held call. Redial The Redial (or last number dialed), feature automatically redials the last extension or outside number dialed. To redial the last number that you dialed. 1. Press REDIAL. The last number you dialed is automatically redialed. Note: The redialed number can be an outside number, an extension, or a trunk or feature access code. Transfer The Transfer feature allows you to transfer a call from your telephone to another extension or outside number, if allowed. To send the present call to another extension or outside number 1. While on a call, press TRNSFR. (Dial Tone). Present call is put on hold, and the green light next to the held call blinks. You are given a new call appearance. 2. Dial the number to which the call is to be transferred. 3. Remain on the line and announce the call; if the line is busy or if there is no answer, return to the held call by pressing it's call appearance button. 4. Press TRNSFR again. Call is sent to the dialed number. 5. Hang up. ...............
    Jan 21, 2011 | Cell Phones
    I want to find out how to set up our Canon CFX0-L4000 fax Machine
    CANON CFX-L4000 UNOFFICIAL MANUAL
    RIGHT KEYPAD
    FUNCTION
    SET
    01 DATA REGISTRATION
    02 DELAYED TRANSMISSION
    03 POLLING
    04 MEMORY REFERENCE
    09 REPORT
    11 UP
    13 +
    14 LEFT
    15 SPACE
    16 RIGHT
    18 CLEAR
    19 DOWN
    Keys 1-20 are speed dial keys. If speed dial is not set, message is displayed and manually entering the telephone number is prompted. Press STOP to clear.
    Pressing FUNCTION accesses the menus associated with keys 1, 2, 3, and 4. After accessing a menu, the cursor keys, SET, and occasionally the telephone key pad are used for selecting options and setting values.
    EG. Setting a speed dial number:
    FUNCTION - DATA (01) - SET - SET - UP/DOWN to select speed dial number - SET - UP/DOWN to set number/name - SET - UP/DOWN/LEFT/RIGHT/PHONE KEYPAD to enter value - SET
    EG. Setting unit telephone number
    FUNCTION - DATA (01) - DOWN once - SET - DOWN once - SET - PHONE KEYPAD to enter number - SET
    EG. Retransmit from memory (assumes memory light is on)
    FUNCTION - MEM (04) - DOWN once - SET - UP/DOWN to select document number (LEFT/RIGHT to view associated telephone number) - SET
    EG. Delayed transmission
    place document into feed - FUNCTION - TX (02) - SET - PHONE KEYPAD to enter time to send - SET - PHONE KEYPAD to enter phone number - SET - SET - document is scanned and will be transmitted at set time
    for full guide you will have to search and purchase one.
    May 28, 2009 | Canon Office Equipment & Supplies
    How to I forward incoming calls on my phone to a cell phone 3?
    Call forward, off-premise is available on the NEC Electra Professional phone system if you have the Level II system (metal cabinet, not plastic) and you have system software level 700 (7.00) or higher. To get your system software level, press <FNC> - 3 from any display telephone when idle. The procedure to forward is (with phone idle): press <FNC> - dial 60, dial trunk access code (usually - 9), dial telephone number, press <FNC>. Additionally, your station class must be set to allow this feature (by default it is not allowed) and you may need trunk-to-trunk capability turned on in system programming (which is also, by default, not allowed). Hope that all helps.
    Dec 30, 2008 | NEC Electra Professional ETW-16DC-2
    Programming a number for memory
    Memory
    Store up to ten 20-digit numbers in memory for quick dialing.
    Storing a Number in Memory
    1. Make sure the phone is OFF (not in TALK mode).
    2. Press the MEMORY button.
    3. Press a number (0-9) to store the dialed number in that memory location.
    4. Press the MEMORY button again.
    5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm.
    6. To enter another number in a different memory location, return to step 1 and repeat the process.
    Nov 03, 2007 | Uniden Cordless Phone
    ConairPhone SW324WCS
    I just had same problem and went conairphone site and found model sw322 that looked about the same. I downloaded the manuel and it worked for my phone. Here it is. MEMORY FEATURE To Program Your CONAIRPHONETM telephone is equipped with 10 memories for programming your most frequently dialed telephone numbers. You can store up to 16 digits in each of the numeric keys (0 through 9), by following the steps outlined below: 1. Lift handset (releasing hook switch). 2. Press and release STORE key. 3. Press the keys for the telephone number you wish to store. 4. Press and release the STORE key again. 5. Press the keypad number (0-9) you want that telephone number stored in. 6. Your number is now stored. 7. To change a stored number, repeat the same process. The new number will store over the old stored number. A Memory Index card is provided for your use in writing down the person?s name. To Retrieve Memory Numbers Keypad Memories: To retrieve numbers stored in the keypad, pick up the handset and press the MEM (Memory) key. Then press the keypad number (0-9) which stores the telephone number you want to dial. Your call will be automatically dialed.
    Jul 12, 2007 | Conair SW324WCS Corded Phone
    GPS Logo
    493 people viewed this question
    Top GPS Experts
    Marvin
    Marvin
    Will Halftowaite
    Are you a GPS Expert? Answer questions, earn points and help others
