Question about Electrical Supplies
Mm18039 light - need instructions how to set the knobs underneath
How do I light the heater please
That all depends on what type of heater it is. I'd need more information to give you a more accurate set of instructions, but....
if it's a gas heater...typically, 1. you turn the switch to the 'ignite' or 'light' position, and 2. set your flame, lighter, match, etc, to the pilot and remove it once the flame catches, 3. then adjust the knob knob to the desired setting.
Typically, kerosone heaters work essentially the same way. I hope this helps. :) if not, pleaqse feel free to provide me with more information and ill see what I can do. logan.vzw@gmail.com
May 07, 2016 | Office Equipment & Supplies
2003 Mitsubishi montero sport the shifter is broke and i need to know.removal of center console
you don't need to remove the whole console it is in sections,take a screwdriver and gently pry the front and side of the cup holder releasing the clips then pull strait up, you will see 2 phillips screws underneath remove those and pull up and back on the shifter cover, to remove the shift knob pry the lower part of the knob away from the from the top you will see 2 set screws underneath this cover then pull shifter strait up, don't forget to unplug the light for the gear selector from underside of the cover or the light assembly will break ( glued in place), the boot for the 2wd/4wd selector is held in place by 4 Phillips screws from the underside of the cover remove these and the boot stays on the selector and you can remove the cover
Dec 23, 2013 | 2001 Mitsubishi Montero
The descaling light stays on even though I have gone thru the process of descaling.
You are not completing the descale program. See below.
10.3 DESCALING
Due to the continuous heating of the water used to make the coffee, over
time it is normal for the tubing inside the machine to fill with lime scale.
When the light starts flashing( chap. 12-point 5), it is time to descale
the machine.
NOTE: when the light switches on, the coffee maker can still be used to
prepare coffee.
Proceed as follows:
• Empty the tank and pour in the contents of one bottle (125 ml) of
DURGOL descaler plus one liter of water. For subsequent descaling
operations, descaling solution can be purchased from authorised
technical service centres.
NB: Make sure splashes of descaler do not fall onto surfaces sensitive
to acid such as marble, limestone and glaze.
• place a container with a minimum capacity of 1.5 litres under
the milk frother (Fig. 3);
• turn the machine on by pressing the button (Fig. 4).
• wait for the green and indicator lights to come on steady.
• press and hold the button for at least 5 seconds (Fig.14). The
light inside the button switches on (chap. 11 - point 8) to indicate
the start of the descaling program (the and lights remain
off to indicate that it is not possible to make coffee).
• turn the steam knob half a turn anticlockwise (Fig.5). The
descaling solution will come out of the milk frother and start to
fill the container underneath.
• the descaling program automatically performs a series of deliveries
and pauses, so as to remove the lime scale deposits from
inside the coffee maker.
Fig.32
The two red buttons
have opened
out CORRECTLY
The two red buttons
have not
opened out
CORRECT INCORRECT
33
OPERATING INSTRUCTIONS
• after around 30 minutes, when the light comes on (chap. 12 - GB
point 1), turn the steam knob half a turn clockwise (Fig.6) until it
stops.
The machine must be rinsed so as to eliminate the residues of descaling
solution from inside the machine. Proceed as follows:
• remove the water tank, rinse it and fill it with clean water.
• reposition the tank.
• empty the collection container (located under the milk frother) that is
full of liquid, and then replace it under the milk frother.
• turn the steam knob half a turn anticlockwise (Fig. 5). Hot water will
come out of the milk frother and fill the container underneath.
• when the tank is empty, the light goes off and the light
comes on (chap. 12 - point 1).
• turn the steam knob all the way clockwise (Fig. 6) and fill the water
tank with clean water again.
• the program of descaling is hour terminated and the machine is
ready per do again the coffee.
NOTE: if the descaling procedure is stopped before completion, the
alarm (chap. 12 - point 5) is not deactivated and the procedure
must be started again form the beginning.
IMPORTANT: THE GUARANTEE IS NOT VALID IF THE ABOVE DESCALING OPERATION
IS NOT PERFORMED REGULARLY.
Sep 20, 2011 | DeLonghi Magnifica 3300 Espresso Machine
How do i light the pilot?
Turn the Gas Control Knob inside the heater compartment from OFF to PILOT. Push in the knob and hold it, at the sametime push the ignitor button (will probably be a Red button). Once the pilot lights, continue to hold the Control Knob down for one minute. Then ease off of it. If the pilot stays lit, turn the Control Knob to the ON position. The burner should light, if the Thermostat is set higher than the ambient temperature in the house. If the Ignitor button doesn't work, you can match light the pilot. Just be careful and follow the instructions above, once it's lit.
Hope this helps solve your problem.
Feb 23, 2011 | Williams (5009622) Ceramic Gas Wall...
The gas flamed up on the underneath the knob
It's either blockage or a leak at the valve.. Turn gas ogg and trighten valve, the open gas very slowly. before lighting check connection with soapy water.
May 05, 2010 | Weber Genesis Silver A Grill
Buttonholes!
You may have loaded the bobbin(the wheel over thread in the door underneath) wrong. Make sure to turn the flywheel to make the thread for the bobbin come up throw the throat plate on the machine where hte needle goes in, double it up with the thread for the needle then sew.
Mak sure the machine is threaded correctly and the bobbin loaded, and that all settings are correct. (stitch type,; zig zag, straight, reverse stitch etc.) Make sure the buttonhole knob/setting is correct, and if it's a knob turn the knob clockwise and slowly.
Dec 19, 2009 | Computers & Internet
Lost instructions for sandleford E.S.20 safe
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
References:
1. Operating instructions EA Electronic Safe
2. http://www.secustar.com/products-en/estype-safe.htm
Jan 09, 2009 | Sentry Fireproof Safe
Old Eaton Viking Stove - broil won't turn off.
I have the same stove, and just had the same problem. I looked all over the internet to try to find an answer, and then went back to my stove to check the serial number and where the fuses are was the instructions printed on the stove itself.
SO HERE'S THE SOLUTION
1. The timer start knob (the one with little running guy picture) must NOT be pushed in. If it is, turn it slowly until it snaps out.
2. The timer stop knob (the one with the picture of the stop sign) must be completely pushed in.
I hope that helps everyone out!
Dec 21, 2008 | Viking Stove/Oven/Range Timer Knob -...
Broken Smart Mix Dial-How to replace
You will have to remove the top, the knob screws on but has a stop tab. Is the plastic below the knob ok, if not then you need to replace the top cover. After you replace the knob, then put the piston on from underneath, have it set to water only selection, then put the top cover back on.
Mar 04, 2008 | Bissell 7950 ProHeat Upright Wet/Dry...
CHILDLOCK DOES NOT UNLOCK
all nobs and controls have to be off before the lock can be disengaged and the new knobs might have broken there pins somewhere inside a knob so its kinda permanently locked till the knob can be fixed saftey features
what ever happened to the sliding lock bar in the ovens
Dec 27, 2006 | Neff U1661 Double circotherm super...
Electrical Supplies Logo
32 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
