Question about Sunbeam Digital Blood Pressure Monitor
Bp 100 relion circuit board - Sunbeam Digital Blood Pressure Monitor
My blood pressure is 116/66 I am 63 and I am on blood pressure medication Micardis plus 80 I am due to take my medication tonight
Your bp is absolutely great ..The fact that you are on BP med is fine, even days when it's normal and your taking BP meds it's fine ..But perhaps check in regular for a month on BP and take measurements and notes if it' still between 100/ 60 - 139/89 check in with the doctor he or she might be able to wean you off then wouldn't that be great:)
GOOD LUCK????
Oct 22, 2017 | Health & Beauty
Can I dissasemble a BP-210N battery pack and refill it?
You could do this absolutely, however with the cost of the batteries needed and the knowledge needed to safely solder to batteries terminals it is more cost effective and safer to purchase from Ebay.
$16.99 coming out of Gardena, Ca with free shipping BATTERY FOR ICOM BP 210 BP 222 BP 210N BP 209N BP 222N
Oct 02, 2015 | Radio Communications
I had hypertension in 1982 till I stopped alcohol in 2003.My BP has been 100/60 until yesterday when it became 180/100 without any changes in my food or exercises.i wonder what he reason might be
Not knowing your age and circumstances makes this question a bit 'hit-and-miss'. As we get older, many people start to get a higher BP reading - thought of trying enalapril?
Nov 22, 2013 | Ultraviolet Heat Shield Covers For Causes...
RCA Projection TV : D52W27D Connector BP120 on Power Board ?
BP120 is not used in that model its simply a empty socket that board is used in other versions of the ITC222 chassis in which some use that plug . But your model doesnt use it. Check the fuse on the AC main board which is right next to where the power cord plugs into that board. If the fuse is blown its most likely the flyback and HOT which are causing the blown fuse. If the fuse is good then the deflection board will need replacement. www.tvrepairworld.com has replacement parts and circuit boards for that chassis and also free tech support is available.
Feb 23, 2012 | Televison & Video
Driver relion A-DL71
Try this located link download
http://www.microexpress.net/dl71download.asp
or this link
http://www.lamsystems.com/drivers/notebook/dl71.asp
Coz i don't know the type, it's a laptop or PC.
If you give me the Device ID of your spec (Device ID of the Main board, sound card, etc..), i will give you the driver.
May 08, 2009 | Computers & Internet
I NEED CIRCUIT BOARDS FOR ERICSSON BP 250 PABX CARDS
Hi Rone... Very urgently i need programing manual for EPABX Ericsson BP 250, can u help me pleeeeez.
Nov 17, 2008 | Ericsson &M/A COM Radio LPE 200&KPC...
Sunbeam Digital Blood Pressure Monitor Logo
57 people viewed this question
Top Sunbeam Health & Beauty Experts
Kevin Hill
Level 1 Expert
musquodoboit
musquodoboit
Level 1 Expert
Are you a Sunbeam Health and Beauty Expert? Answer questions, earn points and help others
