Question about Panasonic Office Equipment & Supplies
Need fuse for panasonic pencil sharpener KP 88 A
5 Suggested Answers
SOURCE: Boston pencil sharpener part
Try here:
http://www.spodaco.com/xactoland.html
Posted on Feb 21, 2009
SOURCE: I cannot figure out how
You put your fingers around the edges of the black "wheel" in the front, get a good grip, then pull toward you. What you've pulled out is the shavings tray. I'm not mechanical at all; it took me a while to figure this out. The first time you try, it takes some effort.
Posted on Jul 14, 2009
SOURCE: pencil sharpener fuse 400ma, 125V,
where do i buy a 400 mA 125 v fuse from?
Posted on Dec 17, 2009
dleemacc
  • 281 Answers
SOURCE: How do I Empty the
Sounds like a good place to start and it won't hurt any thing.
Posted on May 11, 2011
Tip
How to sharpen a pencil so the tip doesn't break
When I was in school it would always frustrate me that the tips of the pencil were always breaking in the sharpener. It took many tries of turning the pencil and turning the sharpener, different amounts of pressure and I finally found the secret.
Sharpening a pencil is a very easy thing to do. When you are using a hand sharpener, either a small plastic one with a cartridge to catch the shavings or the really small ones that don't catch the shaving, your put the utencile end of the pencil into the sharpener keeping it has straight as possible.
Applying a little pressure turn the pencil in the clockwise motion (you can turn either the pencil or the sharpener both will work). The shavings will begin to fall off and you keep turning until either you are satisfied with the sharpness of the tip or the shavings stop coming off. Make sure that you don't put more pressure on the pencil to make the shaving keep coming off because that will make the tip break and get stuck in the sharpener.
Pull the pencil out and clean the sharpener, it should be good to go. What I discovered was that if I had dropped a pencil a few times then the lead inside the pencil would be broken and this would cause the tip to break after sharpening. Treating your pencils nicely will keep them from breaking tips when you sharpen.
on Jan 30, 2014 | Office Equipment & Supplies
When was the pencil sharpener invented?
Before the pencil sharpener was invented, pencils were sharpened by shaving away the wood with a knife. The first pencil sharpener was invented by Therry des Estwaux in 1847.
Oct 06, 2013 | Office Equipment & Supplies
What is a pencil sharpener?
A pencil sharpener is "a device for sharpening a pencil's writing point by shaving away its worn surface. Pencil sharpeners may be operated manually or by an electric motor." (wikipedia)
How do I open and empty the shavings from the Panasonic Auto-stop Electric Pencil Sharpener model # KP-350
I don't have solution advice, I'm searching for it. How do you open it/the device?
Jun 29, 2013 | Garden
Is there a pencil sharpener that I can sharpen several pencils at once?
I don't think there is, but there's a sharpener with different size holes for different types of pencils: http://www.officedepot.com/a/products/744792/Stanley-Bostitch-Classroom-Electric-Pencil-Sharpener/?cm_cat=2000000361
Jan 24, 2013 | Office Equipment & Supplies
Crayon stuck inside pencil sharpener
use a tooth pick from the inside to push it out
Aug 10, 2012 | Panasonic Kp 410A Standard Electric Pencil...
Stopped working
This happens with a lot of pencil sharpeners for various reasons, from the sensor going bad, to the motor going bad, or even the circuit shorting out. If you are a tinkerer you could probably open the pencil sharpener, by removing the screws, and look to see the problem. If not, I would advise sending it in for warranty repair, Panasonic is usually pretty good with this process. If you need help with the Warranty repair process I would advise calling them at 800-211-726.
Mar 22, 2011 | Panasonic Kp 410A Standard Electric Pencil...
49 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
