Question about Avaya DEFINITY EXPANSION INTERFACE CARD (TN570D-001)
TN570 minor alarm - Avaya DEFINITY EXPANSION INTERFACE CARD (TN570D-001)
2002 explorer anti-theft system activates while I'm in house (static). Might anyone have a probable cause ?
The "Proper" way is to use a scan tool with access to body body theft data. Usually alarm events set a code identifying which trigger set the alarm. "IE - B1234 Left Rear Door Alarm trigger Activation.
Since Most people dont HAVE an IDS or NGS or SnapOn...
You can try activating the alarm. all doors closed with windows down. wait 5 minutes. physically grab the top of each door panel thru the open window and shake the door hard like you were trying to pull it open. If its a marginal switch (usually is) the one thats borderline will trigger "open" with minor shaking and the good ones will show fully closed unless the door is in fact fully opened. If the shake test triggers the alarm on 1 door, then you know its either the pin switch (if it has one, not all do) or the door latch out of adjustment or defective.
Nov 12, 2015 | Cars & Trucks
Novi doorbell intercom system won't work. Got it about 8 years ago, worked OK except for minor problems until recently. Now it malfunctions constantly. We finally had to disconnect the wiring o
If you are looking for new intercom system then I would suggest you to buy it from http://www.hulksecurity.com/ .Hulk Security System not only provides intercom systems but they also offer variety of access control system, CCTV and alarm systems. Well, I hope this would help you and have sorted the concern for intercom system.
Oct 24, 2012 | Novi Wireless Doorbell Intercom Security...
Brother multifunction laser printer, model #8220 : can you use color ink cartridges with this model or black /white only?
Welcome to FixYa!
The MFC 8220 is a Laser Printer. It uses Toner Cartridge. Product #TN540 or #TN570. It cannot use the regular ink cartridge.
See full details in this link: http://www.brother-usa.com/MFC/modeldetail.aspx?PRODUCTID=MFC8220&tab=supp
Thank you for using Fixya. Jas247
Apr 03, 2011 | Brother MFC 8220 All-In-One Laser Printer
I need to know the number for the toner cartridge for a DCP 8045D all-in-one laser printer
The OEM number from Brother is TN540 for a standard cartridge and TN570 for a high yield cartridge (more toner)
Jan 04, 2011 | Brother DCP-8045D All-In-One Laser Printer
Is the drum and ink are on the same cartliage?
No they are not. The drum unit (DR510) is a separate cartridge from the TN570 toner cartridge. The toner will last around 6,000 pages while the drum unit is good for 20,000.
Good Luck and Thank You for using Fixya.
Sep 12, 2010 | Brother MFC-8440 All-In-One Laser Printer
We just moved into a house and it has an alarm system that has westinghouse on it. There are sensors on every door and window down stairs. We have no idea how to turn it on and get it set up.
Call an alarm company like ADT. If they can use it they will. it will require some minor reprogramming and they will check all sensors, if the use it. 1-800-ADT-ASAP.
Feb 01, 2010 | GE Security Simon 3 Wireless Home Security...
Alarm goes off for no reason.
this could be a couple of minor things which we can check first, open and close each door to see if they all operate the courtesy lights, open the trunk and push the trunl light button to ensure it is switching off. there may also be a button under the hood. lastly check the glove box button is turning off the glove/jockeybox light when it is closed. if any of these fail, that is the button that needs to be removed and inspected. Good luck
Nov 19, 2009 | 2005 Hyundai Accent
1998 z3 alarm & immobiliser info
Ypu need reprogramming.
Aug 08, 2009 | 1999 BMW Z3
Red light blinks 4 times
That sounds like a fault code coming from your Plasma. Some of them have alarms that go off when say it's overheating, Fans don't turn, the panel has sensed a crack in it. These are random as I don't have the fault code for that particular model. There is a reset sequence of buttons while you turn it on to reset the alarm. I would contact the manufacturer. to see what those fault codes mean. If something minor you can do the reset alarm and watch for a short 2-3 hrs. but will need to be taken in to be serviced. If you can reset it and turns on then you know your power supply is good.
Aug 15, 2008 | Televison & Video
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Lands Phones Logo
22 people viewed this question
Top Avaya Lands Phones Experts
george  peters
george peters
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
