Question about Radio Communications
Headset to AL14H don't register to base - Radio Communications
2 Suggested Answers
ryanb006
  • 48 Answers
SOURCE: register hend set to base
Try the procedure on page 62 of the following PDF, and post your results.
http://www.conversationpiece.ie/download/KXTCD505.pdf
Posted on Mar 23, 2009
How can i deregister a headset from my vtech phone model#ls6475-3. Also, is there a limited to how many headsets you can register to the base.
You can deregister all of the handsets and then register each one again for the LS6475-3. Make sure that all of the handsets are out of the base and all chargers and that the phone and all handsets are in standby. Then press and hold Find Handset on the base. When the In Use light begins to blink, release the Find Handset button. During the seven seconds that the In Use light is blinking, press and release the Find Handset button. Wait for the deregistration process to complete (about 10 seconds).
If the process fails, you may need to reset the base. You can do this by unplugging the AC power cord to the base or by picking up a registered handset and pressing Talk/Flash. Then you can try again. These directions are on page 5 (page 8 of the PDF) of the manual for the LS6405 handset. The direct link to this manual is https://cdn-media.vtechphones.com/media/p/document2/products/%7BD6DAD9B0-4C1A-4882-93D9-04124A59B629%7D/LS6405_CIB_V5_20160805.pdf . Then check that all of the handsets are in standby and not on any charger before attempting to deregister the handsets again.
You can register 12 handsets to the LS6475 base, according to page 31 of that manual for the main unit: https://cdn-media.vtechphones.com/media/p/document2/products/%7BA37C95FC-053D-4D34-B60A-EA5ED42B056C%7D/LS6475-3_UM_4_925.pdf . If you use the cordless headsets, you can register 10 handsets and 2 headsets.
These manuals can be found through the product page: https://www.vtechphones.com/pd/1603/LS6475-3-2-Handset-Answering-System-with-Cordless-Headset . The base manual is in the section under the Support & Manuals tab. The handset manual can be found from the Accessories tab. Then click on the Support & Manuals tab after clicking the link for the Handset.
I hope this helps.
May 21, 2017 | Vtech Lands Phones
At&t model dect6 troubleshooting
You probably just need to Pair the handset with the base again.
So, you have to set the phone in the main base, not just a charging base.
Some of the AT&T phones need you to disconnect the battery for about a minute to reset (this will not lose you stored numbers). Then pair the phone and base again.
Some models have a PAIR button on the bottom of the base.
Press and hold the PAIR button until the MUTE light on the headset base turns on (about four seconds) and release the button.
Return the headset to the headset base for registration.
Registration may take about 30 seconds to complete. The MUTE light on the headset base turns off. The headset ON/OFF light turns blue
on the first headset registered. The headset ON/OFF light turns orange on the second headset registered.
You should be good to go!
All the best to you,
Kerry Hostetter
May 11, 2014 | Computers & Internet
Base is flashing and cannot dial out
HERE'S THE LINK TO THE MANUAL.
The handset is either too far from the base or it needs to be registered. The instructions are in the manual.
http://m.gigaset.com/medias/sys_master/A31008-M2050-L101-1-7619_30-10-2008_en_GBR.pdf
Dec 25, 2012 | Siemens Gigaset 4010 Cordless Phone
I have a snom 370 voip phone with the plantronics cs70 headset but there's a bad echo on the callers end so i got the snom wireless headset adapter but i don't know how to connect it. i also have...
We've never dealt with snom wireless adapter but the CS70 and HL10 lifter is a popular set for your phone. there are a couple of things you can try to cut down on the echo.
1. Make sure CS70 is proper distance from phone, minimum of 6" (12" from a PC)
2. Make sure round compatibility dial (located on left side of base) is set correctly. Most phones work on setting #1 (never between numbers)
3. Echoing is usually caused by an improper mix of incoming and outgoing volume. With a friend listening in you can make broad and minor adjustments for both (incoming: back of base (1-4) and +/- on headset; outgoing: bottom of base (a-d) and +/- arrows on back of base).
Following these steps should help you out.
Good luck from Headsets Direct - 800-914-7996.
Aug 18, 2011 | Plantronics CS70 Wireless Headset
Only bass set going extra hand set not working
This is because the extra handset might have not been registered with the base unit.The headset should be register to use the headset with that base unit.
To register the handset to base unit please follow the instruction:-
On registration the handset is allocated a handset number for use on the new base unit, the handset numbers are 1-5.
1. Press and hold
d65e3ff.jpgon the base unit until 608a95f.jpgstarts flashing. Registration mode will remain active for approximately 3 minutes.
2.Press and hold both
19efd34.jpg together until you hear a long beep.
3.Select the base unit you wish to register by pressing the corresponding number button 1-4.
4. When PIN is displayed, enter the units PIN number (0000 for this model).
5. If the registration is successful the handset will return to standby mode in a few seconds.
Thanx
Jul 22, 2010 | Doro DECT 540 Cordless Phone
Phones won't Register!!
It is possible that you have maxed all of the headsets that can connect to the base. Yes, the base can support 10 headsets, but there is a small chance that in some way you registered more to the base or you purchased a base that had phone registered to it that are not in your possession. Either way, if the base is maxed out, you will not be able to register any additional headsets to it. The only option is to do a factory reset of the base unit if this happens to be the case. This is done as follows according to Uniden Tech Support:
1. Disconnect the power from the base
2. hold down the following three (3) keys: [dnd] + [middle soft key] + [*]
3. While holding down the keys, plug in the base (hold the keys down until you hear a long beep). This is supposedly all it takes to reset the phone.
The way to determine the number of hand sets tied to the phone is to press the intercom key on the base and scroll through the list of phones. if you see more than the number you anticipate still being tied to the base, you will have to utilize the above procedure.
Jul 27, 2009 | Uniden TCX905 Cordless Accessory Handset...
2nd handset says unavailable and will not work
you have to put the second headset in the main phone charging base( ie the base where the phone line is plugged in) for a while (at least 30 seconds) for it to register to phone then you can go on to use it and charge it in its regular charging base
Dec 12, 2008 | GE Lands Phones
Whole house ringing when cordless phone is used
try deleting all headsets using primary headset (marked with no.1): 4-base/8-deregister/default pin '0000' and register them again using each headset (3-headset/8-register/same pin). it worked for me.
Oct 20, 2008 | Lands Phones
Trying to switch out my base unit on the 9120 I am trying to trouble shoot a loud screeching sound that happens when I hang the phone up cant get my head set to switch to the new base
The loud screeching is probably due to the headset mic volume being too loud, or the campatability setting on the base station is in the wrong position for your phone.
To register a new earpiece to a base station, simply put the headpiece on the charging dock and leave it there while you disconnect the power, wait about 20 seconds and then reconnect the power. All the lights on the base should flash a couple of times and then the green charging light will start fashing as normal. The headset should then be registered.
Aug 20, 2008 | GN Netcom GN 9120 Professional Headset
Radio Communications Logo
12 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
