Question about Sony VAIO VPCS137GX PC Notebook
Screen is not bright
When I install windows 8 the screen is dim
I have a problem starting my Dell Inspiron AIO when i press the start button all i get is a dim plain screen the start button should be bright but stays dim i have tried to install the repair disc al
usually with AIO they have very poor life due to lack of ventilation and heat... if you have done a reset and screen is the same it just means that your screen has been affected by heat and it will no longer work the same. it could had been worse some other pcs the video card just gives out and you have nothing left! hope it helps.. its time for an upgrade!
Sep 17, 2014 | Dell Inspiron 2330 23"" AIO FHD...
How to brighten screen on lenovop500l
Lenovo typically uses F11 (dim) and F12 (Brighten). Or, if you are running Windows 8, move the cursor to the lower right and wait for the menu. Select SETTINGS, and you will see BRIGHTNESS button on the SETTINGS screen. Click it and adjust it.
Aug 03, 2014 | Lenovo Computers & Internet
Nook HD screen went dim
If it connected with Internet? If so, you may try to kill virus.
Feb 14, 2014 | Barnes & Noble Tablets & eReaders
Dim screen (Desktop)
Control Panel\Hardware and Sound\Power Options
at the bottom there is settings for screen brightness.
To get to control panel on 8, (not 8.1) go to desktop, then Winkey+c and click settings then control panel.
Dec 29, 2013 | Compaq Computers & Internet
Monitor is very dim
Just go to windows button search for battery then
you will see like this and check your screen brightness is it full
Dec 04, 2013 | Computers & Internet
Cannot adjust brightness in windows 8
Your laptop button functionality will not work until you install the drivers necessary. Check online for the drivers and make sure that all of your drivers are installed in device manager. To get to device manager, right click computer and click manage. In the sidebar, go to device manager. I'm not quite sure if windows 8 has a software slider... it should be under power options where you can adjust the screen brightness to save battery. Good luck
Mar 23, 2013 | Lenovo IdeaPad Z560 Notebook
My screen is very dim
boot to the BIOS (F2 at boot) and ensure that the LCD brightness is set to 8 and then reboot, if LCD is still dim, then, check the Control point system manager display settings and see if the LCD is dimmed there.
If no change, run diags Power + D at boot to run the LCD BIST test , if the 4 colored screens are DIM during the test, then the LCD has failed and needs repplacement.
Jun 29, 2011 | Dell Latitude E6500 Laptop
The screen is very dim. The brightness is at 100% but it is still dark. What's wrong with the screen? LED backlight panel?
I think its a problem with the backlight, i recommend call lenovo support and have it service.
Dec 29, 2010 | Lenovo IdeaPad S10-3 Netbook
I have a toshiba a45-s250. the screen is dim but
Have you adjusted screen brightness control as I have seen lots of Laptops with the screen brightness control "bumped" to min.!!!
Nov 20, 2009 | Toshiba Satellite A45-S250 Notebook
Screen very dim, but set on 100% brightness.
Good Morning! With the 8 years operations of your emachines monitor, some of its electronic parts might incurred cold solder joint connections from its circuit board & possibly some of its Capacitor parts are already worn-out. please try to get assistance from an electronic service technician which will surely diagnose & repair the problem. best regards.
May 04, 2009 | Computers & Internet
Sony VAIO VPCS137GX PC Notebook Logo
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
