Brother J25DW and unable to print code4f
Our Brother Printer will not print. We ran thru the cleaner for the print heads and the blotter paper. Now it will not print.
  • 215 Answers
SOURCE: Brother DCP 330C 'unable to clean 46' printer will not print
responded to this on a error 46 post by joachim.
hth,
razors
Posted on Mar 30, 2009
  • 583 Answers
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Posted on Jul 13, 2009
  • 73 Answers
SOURCE: Brother Printer is reading ''unable to print 70''
YOu would need to remove jammed paper opening back cover.
Posted on Sep 23, 2009
cene765
  • 787 Answers
SOURCE: unable to clean print heads
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the error is 48 - defective print head cable or circuit board.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Posted on Nov 24, 2009
Semi-Driver
  • 434 Answers
SOURCE: brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
Posted on Jan 21, 2010
Brother unable to print 32
The Error "Print Unable 32" occurs mainly when the paper got stuck in the printer and the print head can't move so as to print on paper.So for resolving this issue you just need to get assistance from expert technicians of Brother Printer Support team and for that you just need to dial 1-800-243-0019 Brother Printer Support Number.
Sep 05, 2017 | Brother Computers & Internet
Unable to print 4f
good day, unable to print 4f is printer head problem...replace new printer head
Apr 09, 2014 | Brother DCPJ125 All-In-One Inkjet Printer
UNABLE TO PRINT 44 - BROTHER MFC-J6510DW
User guide http://download.brother.com/welcome/doc002835/cv_mfc6710dw_use_busr_lx7144001_b.pdf says either a mechanical problem or could be foreign object like paper clip or torn paper inside the machine. Open the scanner cover to check for that.
Oct 15, 2013 | Brother MFC 6490CW InkJet Printer
I have a Brother MFC 240C. After I removed paper from a paper jam the printer reads: Print unable 50. See Trouble Shooting and Routine Maintenance chapter in User's Guide. I tried to look this up on...
You may encounter a paper jam while working with your Brother printer. You need to be cautious while feeding the paper to your printer. Paper jams are often obvious, but you might come across a situation when you do not get any indication that the paper has jammed up the printer. In such cases, you need to open your printer and visually inspect it to search for the jammed paper. If the rollers of your printer are leaving marks on the printouts, then there is a need to clean them. Using chemical cleaners such as benzine, thinner, or alcohol to clean the rollers might prove hazardous to your printer.
Nov 09, 2010 | Brother MFC 240C All-In-One InkJet Printer
Brother DPC-165C has 'Init Unable AF' error
Yup. I suspect the head has been removed from the unit. There are adjustments on some printers. It was assembled wrong. The grating noise is likely the auto cleaner. If it cannot go 'home' the unit will not initialize. Possibly the head detect sensor is broken or covered. If the head will not home (moves out and back more than once or slams home hard), 'Init Unable AF'. You may be able to order a service manual from Brother for this. A repair shop can order the manual as well. (I suspect you need a new print head as well. You might want to replace the printer) see tips on bubblejet printers.
Mar 20, 2010 | Office Equipment & Supplies
Brother 130c print unable 50
Solution #1 is absolutely spot-on from adnanbhatti, copy the link into your browser to be able to see the photos of the printer and how to slide the print head:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000500/000065/faq000565_013.html?reg=us&c=us&lang=en&prod=dcp130c_all&Cat=11
When I slid the print head over as specified, I found a little crumpled paper fragment soaked with ink. Pulled it out.... I turned on the printer, it ran a cleaning cycle automatically, and started printing just fine!
Aug 18, 2009 | Brother DCP 130C All-In-One InkJet Printer
My Brothers MFC 210C All-In-One Inket printer is printing blurry. It has been used in a year. I changed the cartridges and ran the cleaner but it still prints light and blurry. What can I do? Thank you.
keep on printing the catridges will satrt function well after few prints if they have ink and heads are ok , if not take out cartridges shake them well chek head are leaving ink on a tissu paper if not place cartridges under runing water tap clean their heads and dry them with tissue paper and place them again nowi think they will work i
let me know your reply sitehr@gmail.com
Aug 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
PAPER JAM CHANGE UNABLE 34
Usually when it does that, either there is just a small piece of shredded paper still jammed in the sensors, or the sensors are dirty. If you feel up to the task, take it apart and look for the sensors near the print head and near all the rollers and clean them up with either contact cleaner, VCR head cleaner or rubbing alcohol to get dirt and gunk off the sensors. If you don't wanna risk taking your printer apart, take it to you local technician to get it fixed.
Jul 07, 2009 | Brother DCP-130C InkJet Printer
Brother mfc-215c unable to clean?
The ink blotter in the bottom of the machine is full, this is a built-in redundancy. Machine needs to be completely stripped to replace this.
Buy another brand next time.
Oct 01, 2008 | Brother Multi-Function CenterĀ® MFC-215C...
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
37 people viewed this question
jasbo
jasbo
