Question about Electrolux ICON Designer Series E36IC80ISS Black 36" Induction Cooktop with Stainless Steel Rim, 5
F7 10 error code Electrolux icon cooktop - Electrolux ICON Designer Series E36IC80ISS Black 36" Induction Cooktop with Stainless Steel Rim, 5
3 Suggested Answers
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: electrolux cooktop was in use and suddenly tripped breaker. When reset, showed error code across control panel. tried sabbath mode unlock, but no success. suggestion?
    What was the error code?
    Posted on Jul 30, 2012
    chrispolkele
    • 4342 Answers
      Verified Fixya Pro
      SOURCE: Electrolux Induction Cooktop E36IC75FSS Error Code 41
      Hi Sue -- when you switched the breaker, how long did you leave it off before switching it back on? Generally, it's a good idea to leave the breaker off (or unplug the unit) for a full 30 seconds before switching the unit back on. If you did have it off for 30 seconds and the error code came on after that point, then it may possibly be a relay isse. That will more than likely require a visit from an authorized servicer to properly diagnose the cooktop. Hopefully the 30-second test prevails and the issue is resolved. Best of luck!
      Posted on Aug 29, 2012
      Electrolux Cooktop Hybrid error E07- sometimes, cooking gets interrupted with E07 code and shuts off the panel. On next turn on, usually works okay. Could you describe me the error code? Thanks!
      I appreciate your post, friend!
      I see that you are having an issue with your Electrolux cooktop displaying a "E07" and shutting off. An "E07" code stands for an issue with your key sensor timer and this could be a potential problem with your right, left, or center board. This may not be a simple DIY job and I would highly recommend having a professional technician come out to diagnosis your cooktop. The technician will have the appropriate tools needed for properly diagnosing your cooktop. This step will help you to avoid any unnecessary part purchases. Hopefully this information is helpful. -Matt
      Feb 19, 2015 | Electrolux Cooktops
      I have a glass cooktop Electrolux which is only 2 years. stopped functioning with a E-11 error code and cannot ulock. what can Ido?
      Hello Gloria Padilla, thank you for your post!
      I understand that your Electrolux cooktop is displaying an error code "E-11" and will not allow you to operate. The "E-11" error code stands for key sensor in cook place four. This could mean a possible issue with your flex cable, right board, or left board. I see you have completed a reset on your cooktop, at this point I would recommend having a professional technician for a proper diagnosis to be completed. I hope this information is helpful. -Matt
      Dec 29, 2014 | Electrolux Cooktops
      Electrolux hybrid cooktop showing flashing 8
      Based off what you are describing your Electrolux cooktop is flashing error code "8". Normally, an "8" error code stands for key sensor for cook place 3. This means you could have a problem with your center board or left board. I would recommend performing a reset on your cooktop which can be done by flipping off the household circuit breaker for ten minutes. If the issue remains I would consult with a professional technician for diagnosis and repair on the cooktop. I hope this helps to some degree. -Matt
      Oct 20, 2014 | Cooktops
      Electralux Surface Cooktop, with code---E----40
      Hi Linda Wallman, thanks for your post!
      I see that your Electrolux cooktop is displaying an "E40" error code. Typically, the "E40" stands for no communications, shorted bus. This could be an internal communication error with your left control board, relay board, or filter board. I would recommend getting a technician out to your home for proper diagnosis and repair. I hope this is helpful. -Matt
      Oct 20, 2014 | Electrolux Cooktops
      Prestige induction cooktop showing error E4
      Good Afternoon friend, I appreciate your inquiry!
      Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
      If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
      Oct 18, 2014 | Electrolux 36" Electric Hybrid Induction...
      Error codes EO 21
      Good Morning sisutl, thank you for your question!
      Could the error code possibly be E-21? If so, this error is commonly referred to an issue with the oven thermal sensor. Typically, the over thermal sensor is in the open position. A professional would need to verify continuity of sensor harness and connections. Depending on an accurate diagnosis the part may need replacing. I hope this information help to some degree.
      Sep 06, 2013 | Electrolux ICON Designer Series E36IC80ISS...
      Error message on my electrolux INDUCTION STOVE TOP
      Hello - Typically error code E on Electrolux induction cook top indicates an error with the user interface board/control board. Contact a professional to move forward accurately and properly diagnose/repair the unit.
      Oct 30, 2012 | Electrolux ICON Designer Series E36IC80ISS...
      Aug 27, 2012 | Electrolux 37 in. Designer Series...
      ERRORS on Electrolux Icon 30'' Induction Cooktop
      Call Electrolux or go to their web site and explain the problem there tech department will be able to tell you if you need a service call or can fix yourself.
      Oct 03, 2017 | Electrolux Cooktops
      Electrolux ICON Designer Series E36IC80ISS Black 36" Induction Cooktop with Stainless Steel Rim, 5 Logo
      97 people viewed this question
      Top Electrolux Cooktops Experts
      Paul Carew
      Lawrence Oravetz
      gbob59
      Are you an Electrolux Cooktop Expert? Answer questions, earn points and help others
