Question about Line 6 FBV Pedal Board Amp Pedal
I have the bad way in taken preset sounds and put in and the fvb . like take for sounds and put them in a bank just 4 this amp is way complicated for the amp just way to menny ajustments just to get a simple sound.Then u have 2 take that and put thatinthe fvb .Just way 2much.I REALLY regret mine is ampif you think you can come up with some kind of answer on paint words please let me know thank you very much
Vox vt40 factory reset
Consider reading the Manual for this amp, it explains how to reset to factory with the VFS5 footpedal. Or with the power off ..hold down CH1 & CH4 then turn power on.. when the Bank & Channel leds start blinking.. then release the Channel buttons. Next press the Tap switch ... the bank & channel leds will change from blinking to lit. with in a few seconds it will enter preset mode.
Apr 12, 2014 | VOX Amplification Vox VT40+ Valvetronix...
Fender mustang noise
This isn't much information to go on. I may can help if you could be more specific. What amp? Presets of what? What software? What noise gate? Where is this noise, amp output or pc input? A computer sound card can do weird things when musical equipment is plugged into it, some mice will do it, making noise when you move the mouse around. I'm guessing how you are set up, if you get back to me, I will try to help you further.
Mar 26, 2014 | Fender Music
Cannot format or reload factory presets after it stopped working
The card that you used to transfer the files HAS to be (1) FORMATTED by the ESX-1 unit FIRST, (2) then put the card into your computer's card reader and download the files. (3) Put the card BACK into the ESX-1 and try reloading the factory presets. Good luck!
Jan 11, 2013 | Korg ESX1 Electribe SX production station...
Can I hook up a monitor to a Harbinger HA120 Portable PA System
Yes you can,you will need 2 run ,1\4 in 2 jack 1\4 in imput too the mic\line imput your chaing your signal so you will need too preset vol levels on the 120 too your desired max peak out put buy first putting you output slide too max on your mixer (running a signal from a cd player or other divice into mixer)then turn vol up 2 disered max loudness you want to run sound at then lower the vol using out put from main power slide on your mixer. Its called chaining your componets .better way of hooking up a band on a small system.ywc Rev bob dj 25yrs exp
Sep 06, 2012 | Harbinger HA120 Portable PA System
Hello Guys my Roland XP50 on power up show the line that the User memory is damaged . When played it is out of tune and off scale . how can this be rectified?
Press Disc Utility > Choose Option 4. SOUND > Press Enter > Choose Option 5. PRESET > Press Enter > Switch off Write Protect if its on & its Done : )
COMPLETE
Jun 20, 2011 | Music
Wheres the preset button on a line 6 spider III 30 WATT
I am guessing that you are trying to replace the presets the amp comes with, with your own. In which case all you do is dial in the sound you want and then hold either the clean,crunch,metal, or insane buttons until you see the light flash. Usually hold it for about four seconds.
Mar 08, 2010 | Line 6 Spider Iii 30
How do i change the settings on my line 6 FBV Express MK11 pedals A B C D to settings that i use?
Hi, befarms. The line 6 FBV Express allows you to select the A B C D in the existing/current bank. You will not be able to change the current bank, disable or enable the effects.
What you can do is, save the preset on the bank number that you desire by holding down the channel button on your amp whether it is A B C or D. Then when the button flashes, you can reinsert or rename the preset and save it to the channel(or bank) that you wish for by scrolling to the bank number and pushing the button on the amp (A B Cor D).
Therefore, you will be able to save your personal setting to a specific bank and channel.
Hope it helps you.
Feb 01, 2010 | Line 6 Music
My 150 w spider III looses power after on for 60minutes. no volume, all preset button lites go off, but preset names stay lit up. Goes off for a few seconds, comes on, goes off. Have to turn amp off and...
Sounds like a power supply problem. Likely have to go to a repair shop unless you are electronically capable.
I would expect either a cracked board or bad solder joint is causing the problem.
Oct 06, 2009 | Line 6 Spider Iii 120 Stereo Guitar Combo...
High pitched squeal when the input jack is used.
Sounds like your master volume is turned up too much. The channel volume will make the squealing go away(caused by high gain and humbuckers). The best thing to do is dial in your favorite presets and change the channel volume to the correct level with the master volume where you usually keep it. I use my Spider Valve at master volume at about noon and the channel volume between nine o'clock and noon. Let me know if this does not solve the problem......
Aug 22, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
FENDER CYBER TWIN AMP SOUNDS GREAT WORKS GREAT BUT WHEN YOU CRANK THE VOLUME A LITTLE LOUDER THAN NORMAL THE AMP GET STATIC OR DISTORTS OR POPS AND CRACKS. COULD THE TUBES DO THIS?
First make sure you have the TRIM knob positioned correctly. When playing loud the Red Led should just blink a bit so you know you're not overloading the preamp and Digital sections. The Twin Reverb Patch is a clean place to start so select that first. On this amp it's a good idea to set the MASTER to 5 and use the VOLUME control at as low a setting as you can. The GAIN control should be set under 4. You better sound crystal clear on this setting. Try turning up the volume to see how loud you can get without breaking up. It's a guitar amp so there will be some grainy distortion but it should be very light. I bet you get through this test without much trouble. After that you need to be very careful about what settings you're using since many of the presets may not mesh with your guitar pickups. You should concentrate on tweaking one highgain setting and learn about how the controls interact. The amp is so much more complicated than a 10 knob standard guitar amp. Most people need to put in some time to get a handle on it.
As far as the tubes go, typically they can get microphonic which was a problem with versions 1.1 and 1.0 of this amp so check that. Fender had a Cyber twin upgrade kit way back to fix this but if you have version 1.2 or 1.3 that's not it. Problems with this amp are typically caused by control setting more often than an electronic problem but this reponse should get you started figuring it out.
MYREL
Jul 13, 2009 | Music
Line 6 FBV Pedal Board Amp Pedal Logo
10 people viewed this question
Top Line 6 Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Line 6 Music Expert? Answer questions, earn points and help others
