Question about Hobart D300 Stand Mixer
Dough mixer not working at all
Hi ,i have a seven kg dough mixer 1 year old ,was working perfect ,once i put more than the quantity allowed in the bowl to make a dough since the is not working at all did anny one have an idea a bout the problem and wich part sould be replaced   thx
  • 640 Answers
It sounds like the mixer was overloaded and therefore broke a shaft,gears or sheared keys.
Posted on Nov 02, 2007
  • anthony james
    anthony james Nov 07, 2007
    did you solve your problem?
I have a 40 year old Kitchen Aid mixer, Division/Hobart. I just finished with some dough and the mixer sound like it was growling,slowed down, turned it off, does not work now
There can only be three things:
1. Brushes needs to replaced;
2. Rotor is used out;
3. wheels can be use out;
Open machine and look at these three components. First one is easy fix, you take one out and replace it with another, others two are cul de sac, I am afraid.
Apr 04, 2016 | Food Mixers
I have a 275W Classic Plus, about 5 years old. I've never done any maintenance on it. It gets used several times per week for the basics (banana bread/cake batter, cookie dough) and also at least once a...
There are lots of places to be looking, first thing I would look at would be under the rear cover to make sure the two nuts that hold the rear motor bearing housing in place are nipped up. You don't wring the neck on these nuts, if you over tighten them you will deform the rear bearing housing.
If you can find someone local who has been doing these mixers for a while they will be able to give it a once over. It's unlikely to be expensive. Best people to ask is Kitchen Aid, they should know who does their warranty work in your area. If you are in new Zealand it will be me.
Jun 30, 2017 | KitchenAid K45SS Classic Stand Mixer
The pin that holds the mixer to the stand keep working it's way out when I mix dough.
Hi, Mixing Dough is tough. the neading hook really works hard and the pin will like to wander out on the left side of the mixer "right side if your facing the it". What I did was find an smaller elastic band and with the pin sticking out a 1/3 of an inch from the opposite side from which it wanders out.
loop the band on it as many times as possible so its stays on tight . with this you now have a bumper and as the pin vibrates to wander out the elastic bumper will gently keep pulling it back during the vibration cycle keeping it in check .
Works perfect but still inspect the pin and bumper before each use.
Mike
Aug 13, 2009 | KitchenAid KSM150PS Artisan Series Stand...
MOTOR SPINS ON MY CLASSIC STAND MIXER BUT GEARS DON'T ENGAGE
Hi all. There is damage to the transmission caused by overloading the mixer with bread or cookie dough, or by dropping a spoon or measuring cup into the mixer while it was working.
Go to mendingshed.com and download their free kitchenaid repair manual. This manual has all you, or a repair person will need to repair your model's mixer. Mending Shed also sells needed parts.
If this solution has assisted you, please rate it. ricardok45
Mar 06, 2009 | KitchenAid K45SS Classic Stand Mixer
Dry clumps in pizza dough
Hi. You should consider a few things. They type of hook you use, can greatly affect your end result. If you're making a yeasted dough with a high protein percentage 12-13%, you should be using an "ED" hook, this is a spiral hook that has a sharp turn at the tip. You can find them on eBay for a competitive price. I believe that Hobart also sells them, but for a higher price. They are very good for mixing pizza type doughs, they also do an excellent job kneading the dough.
Have you checked the flour for lumps before it goes into the mixer? Have you tried sifting the flour?
Are you adding all the liquid and flour at once? If so try adding flour in stages to all the liquid. If you find that this solution helps you, please rate it. Good luck! ricardok45
Feb 19, 2009 | Hobart D340-6007 Mixer
Need to Raise the stop height of the bowl on the H600
I should have know this was a scam to sell something.
Thanks, but no thanks.....
Dec 09, 2008 | Hobart HL600 Legacy Stand Mixer
MIxer quit working while mixing 3 batches of oatmeal cookies
Hi. Kitchenaid's warranty is 1 year.
Most likely, the plastic transmission housing has failed, causing damage to the working parts inside your mixer. Take it to a local repair place and have them work up a quote to repair it. It will take at least a month to get the parts.
I
Dec 06, 2007 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Hobart D300 Stand Mixer Logo
100 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
