Question about Electrical Supplies
Can a Siemens cashpower run backwards
Pv output is higher than demand
2 Suggested Answers
  • 45649 Answers
SOURCE: siemens cashpower 2000
contact the installing electrician for the code or where you can get the code.
Posted on May 15, 2013
I just bought a property with a Siemens Cashpower 2000 unit. but I don't have the account or meter number. How do I reload electricity to this?
Previous owner info? MFG website, email their customer service. Is this a "subscription" service? Have you talked to your power supplier?
Jun 08, 2015 | Miscellaneous
How do I read the meter reading on a Siemens Cashpower 2000 prepaid meter?
Here is a link to the user manual. Halfway down on the left side toy can see where you are asking for.
http://www.ekurhuleni.gov.za/560-manual-meter-plc/file
Jun 19, 2014 | Electrical Supplies
Alternator is 110 amps or 130 amps
Higher amperage would cope with electrical demand easier so if they both fit and not any difference in price I would go for the higher one. The actual output voltage wise would be the same
Sep 23, 2013 | 1999 Ford Taurus
Siemens cashpower 2000
May 15, 2013 | Electrical Supplies
My peavey amp pv 2600 only plays on channel A. No output on the B side
Check the "BRIDGE" switch position, "IN" for "BRIDGE", "OUT" for "STEREO", and clean ALL back switches with a cleaning spray and then run the amp again, also check the two green lights activation at front, if they activate, then amp is certainly working, let me know further.
Jan 28, 2013 | Peavey Pv 2600 Power Amplifier
Stator and reg keep going out
If your stator and regulator keep failing, it's generally caused by an overload. Have you added any extra lights or electrical gear to your bike? If so, you may be overloading your charging system. If your bike is equipped with a 42 amp system and when you've got all your stuff running it's drawing 38 amps, your charging system is working to almost capacity to provide the current that is being demanded. This causes the components to run hot and they fail. My advice to analyze your current needs on the bike and look for a system with higher output capacity or take some of the current demanding equipment off the bike. Cycle Electrics builds a "three phase" alternator kit that works well. I've installed several of them and never had a problem. http://www.cycleelectricinc.com/
Good Luck
Steve
Jul 16, 2011 | 2000 Harley Davidson FLHTCUI Electra Glide...
Can i connect the pv 112 to the pv 118 subwoofer since the powered mixer i bought it only has 2 main outputs? The powered mixer I bought is the PV XR 8600D powered mixer...
Generally speaking you should only send low frequencies to subs. The highs, while lower in power than the lows, will over time harm the voice coils. The ideal way to do this is to use an external crossover netween the main output and the amp input with the higher range going to a general set of speakers. Send the lows through the second channel of the amp and then to the subs.
In short, while not recommended, yes you can hook them up in parallel.
Dan
Dec 09, 2010 | Peavey Pv118 1x18" Subwoofer Speaker...
What causes "crackling noise" from "A" side banana plug output? I've replaced the banana plug and cable.
check your inputs(mic or dvd or other)for good cables to amplifier and you can apply a contact cleaner with its long pipe to volume control and move it forward and backward(you can get lubricat contact cleaner from radio shack near
Dec 26, 2009 | Peavey PV® 2600 2-Channel Amplifier
Power supply gigaset 8825
The power supply for the 8825 base is to be 13 volts AC, rated at 850 milliamps or higher. You can go anywhere from 13 up to 15 volts without hurting the unit, and a higher current rating is even better. We actually make them ourselves through bulk purchases of varieties of power supplys. Your next delimma will be the plug size, it is a pretty common size, most universal adapters will have the right size of the outer and inner connections.
Nov 16, 2007 | Siemens Gigaset 8825 Cordless Phone
Monitor makes annoying screech noise
Hello.
What you are reporting is a problem in the horizontal section of your CRT monitor. Usually this is from a component that is failing in the Horizontal circuit.
Most CRT monitors use what is called scan rectification to develop the voltages required for the different circuits inside the monitor. This puts a strain on the Horizontal Output circuits that are responsible for not only the voltage to the flyback transformer to allow CRT illumination (40,000 or so volts DC), but some of the flyback secondary power circuits are what runs the rest of the monitor. When the components in the Horizontal output circuit get weak and can no longer support the higher demands of the dependant circuits, the flyback transformer tries to run harder. The more current it tries to draw to continue operating, the louder the whine becomes. Since the flyback operates around 17,000 cycles per second, it is in the audible range. Since you can physically hear it, you can also notice the change as the load demand on it changes.
What happens when you reduce the size of application windows or minimize them entirely is the demand on the power circuits is lessened and the flyback circuit is no longer trying to produce the higher demand that it was with the large application windows.
It is a good bet that it will not be too long before the Horizontal output and/or transformer give out completely and leave you with a dead monitor and a large repair bill.
Since it has not gone completely out yet, I would suggest you consult your local repair shop for an estimate. It may be a simple matter of replacing the high voltage capacitors around the Horizontal output transistor before the other parts in the horizontal circuit are damaged. This would certainly be a less expensive alternative.
If you opt to not get it repaired, new 17 inch LCD flat panel monitors can usually be purchased for around $150 or so.
Only you can decide which choice is right for you. At least now you have a few facts to help make the decision.
(I realize I probably gave you more information than you wanted, but I felt it might make things a bit easier to understand. If not, please forgive the disertation.)
I hope this helps.
Nov 06, 2007 | HP Compaq FS 7550 17" CRT Monitor
Electrical Supplies Logo
64 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
