Question about Kenmore 72912 / 72914 / 72919 Bottom Freezer Refrigerator
How to set temparture control on kenmore bottom freeze
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: kenmore 253.7787950A keeps freezing up
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Posted on May 08, 2011
Kenmore 253.7787950A keeps freezing up set on normal temp controls top and bottom
heatman101
May 06, 2011 | Kenmore Refrigerators
Kenmore 253 refrigerator/freezer won't stop running on any setting. The food in the top of the refrigerator would freeze unless I partially blocked the vent. I am wondering what the problem could be. i...
I have a Kenmore model 253 freezer/refridgerator upright model. I am getting cold spots in the refridgeration in and near the vegetable drawers on the bottom of the refridgerator. The icemaker works but the water dispensor has stopped working too.
Nov 28, 2010 | Refrigerators
21' bottom freezer kenmore refrigerator-no ice maker-the fridge is super cold and freezes all my vegetables and fruit. We have cleaned the coils, cleaned the fridge, and it just keeps freezing. Fridge is...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 02, 2009 | Kenmore 21.0 cu. ft. Bottom Freezer...
Food at bottom of fridge freezes
Bad cold control switch.
The cold control switch should open when the set temperature has been reached. If the control does not open and turn the compressor off, it will continue to run and freeze items in the refrigerator section.
If the control is not closing, the compressor and all fans will stop operating. Check the control for continuity. If you don't feel comfortable checking this yourself, get a repair person out to check it out.
Hope this helps.
Aug 07, 2009 | Kenmore Refrigerators
Kenmore bottom freezer model freezes veggies in the crisper
i never go by that / just hold my finger over the air port and move it till i feel move air or less to set it the way i need it ,,, less air puts less air into crisper to cut down on freezing
Nov 26, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Crisper produce freezing
are they long times between door openings of the doors, this can cause cold air to migrate to the bottom of the fresh foor area and freeze produce
if this is not the issue, then turn down the fresh food control to a lower number monitor for 24 hrs
if this does not help replace the fresh food thermastat
May 20, 2008 | Kenmore 71812 / 71814 / 71819 Bottom...
Kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Apr 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Dishwasher
Check to see if you have any switches on your dishwasher that could by pass a rinse cycle. Use a hotter temparture when washing, Check your water level,check your filters on your inlet hose top and bottom. When it gets to a rinse cycle you should hear it drain out and bring in fresh water. you could change to a liquid detergent. Dont over load your dishwasher. make sure you are using rinse aid and try adjusting it up one setting. Shiney glasses means your rinse add is working. NZL
Jan 04, 2007 | Kenmore 18 in. 14432 / 14439 Built-in...
Kenmore 72912 / 72914 / 72919 Bottom Freezer Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
