Question about Acer B243W 24 inch LCD Monitor
How do I remove the back from my Acer B243W monitor?
Interested in replacing the capacitor but unable to find the trick to cracking the casing around the monitor without damaging it. Ideas?
5 Suggested Answers
benwabnick
  • 2404 Answers
SOURCE: My Acer AL1711 LCD monitor blacks out every 2 seconds
take a flathead screwdriver and place it anywhere where the front bezel and back, you can start on the top, bottom, or either side of the monitor, place your flathead screwdrier and place it in any part of the **** and twist your screwdriver, this should start releasing some of the clips. I had to do this with several dell lcd monitors to get into them. Keep in mind after this there will be more screws to take out to get the lcd out of there.
Posted on Aug 04, 2009
mace1mace
  • 1138 Answers
SOURCE: Acer X223W power supply
the voltage inverters are the small transformers attached to a small pcb, that is connected to the backlight inverter (cold cathode).
Just in case replacing the capacitors did not work, the second thing to do is to check the backlight inverter. If there is busted light, replace this one too..the last thing to check is the high voltage ballast transformer... if one of these is burnt, it is enough to affect the stability of your supply current. It can also result to a dark portion on your screen or worst , could result to a total black screen..
If you can replace this transformer with the same value, please do so.
If this is a help to you.. please rate this solution...thanks.
Posted on May 28, 2010
Testimonial: "No separate PCB's on power supply, but your advice did make me check out the PCB further, so thank you for your advice. I will be undertaking identification of the inverters. On this model the inverters are built into the PCB, above the power supply input. "
  • 293 Answers
SOURCE: Acer Monitor Lcd 22in B243w
try to turn on again the power button or in the remote then if did not work or power on.Your monitor have problem in power supply.need a technician for repair.If the power on then check the timer settings.
Posted on Oct 05, 2010
budmrtn
  • 11361 Answers
SOURCE: i have an acer b243w
You may have high voltage arcing, bad inverter transformers, bad DC filter caps, bad lamp wires. You will have to open it up and inspect the inside first.
Failed ACER monitors: http://s807.photobucket.com/albums/yy352/budm/Bad%20backlight%20lamp/
Bad lamps: http://s807.photobucket.com/albums/yy352/budm/Bad%20backlight%20lamp/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Jun 09, 2011
Screen has a blue hue...how do I correct his?
choose the menu button on your monitor move over to the picture option and it should display your color option in that menu a long with the hue as well
Sep 10, 2014 | Acer B243W 24 inch LCD Monitor
I have an ACER 1914 LCD. How can I open to change capacitors
You remove the stand and all the screws, then use the flat blade screw driver to crack open the case, srating at the bottom center and work your way around. When you get the bottom side and the left and right side crack open just enough, lay the monitor face down on soft surface then lift up the back cover to release the top side edge.
Be real careful on the cable attached to the front bezel.
See example here; http://s807.photobucket.com/albums/yy352/budm/ACER/
Make sure to replace the caps in a set using low ESR type caps.
Jul 13, 2011 | Acer AL1914 19" LCD Monitor
I have an acer b243w monitor. it powers on for about 2 seconds then goes black. thens it tries a second time and the same thing and making a slight hiss noise and the back of the monitor smells like static...
Jun 08, 2011 | Acer B243W 24 inch LCD Monitor
How do I open this monitor to get inside and see what is wrong Acer AL2016W B
Remove the stand and all the screws in the back, then use thin flat blade screw driver to crack open the case starting at the bottom rdge and work you way around.
Service manual:
http://elektrotanya.com/?q=showresult&megnev=ACER&megnev2=AL2016W&kategoria=&kat2=all
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER (http://s807.photobucket.com/albums/yy352/budm/ACER/) monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
May 13, 2011 | Acer AL2016W 20" LCD Monitor
White display on my lg flatron L192ws
Most common problems with LCD monitors arises due to weak or damaged capacitors. Disconnect the power and signal supply from monitor, then open the case gently. Use a flat screwdriver for pry opening the case, after removal of screws. Here you have to look for faulty capacitors on the circuit. On the PCB of the monitor, check each capacitor for deformation/leakage around it. In case of any doubt, it's better to replace the capacitor, as they are inexpensive. The only thing is that you should use the correct rating capacitor for replacement. You will need a soldering iron, and at best a multimeter for carrying out the job. After doing all this, assemble the monitor back, and your monitor will be working fine.
Caution : If you are finding yourself uncomfortable with all the work doing yourself, then ask for help from a qualified technical person.
Nov 01, 2010 | LG Flatron 563LE 15.1" LCD Monitor
Acer Monitor Lcd 22in B243w Monitor goes black and shuts off
Oct 05, 2010 | Acer B243w 22" LCD Monitor
I have a Acer B243W 24" Monitor. There is a vertical neon green line (1x1200 px) on the screen and i have no idea what it is there for and how i can get rid of it. someone might help? thx!
It's there because the connection inside the LCD panel that commands that column is either busted or inactive - it's a hardware fault that cannot be fixed. If it's too much to bear then the entire monitor must be replaced.
Jun 22, 2010 | Acer B243w 22" LCD Monitor
THE LIGHT COMES ON FOR A FEW SECONDS AMD GOES OUT. THE BACK LIGHT COMES ON FOR A FEW SECONDS DIMLY AND GOES OUT HOW DO YOU OPEN THE MONITOR AND FIX IT?
You need to remove the stand and all the screw, then use very thin flat blade screw driver to crack open the case, starting at the bottom edge of the case then work your way around, just be real careful not to let the screw driver slip on you. You can look for service manual here: www.elektrotanya.com
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps), see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Apr 15, 2010 | Acer AL1917W LCD Monitor
Acer 22'' Graphics too small
Right-mouse-click on your "wallpaper".
Choose Properties.
Click Appearance.
Change to a larger font-size.
Nov 17, 2009 | Acer B243w 22" LCD Monitor
Need to open the case on an ACER 24" LCD Monitor
You are advised to take it in to an authorised technician for repair. Never open the case unless you are qualified and certified.
Jan 02, 2009 | Computers & Internet
Acer B243W 24 inch LCD Monitor Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
