Lenovo G580 Laptop Logo
A
Anonymous Posted on Feb 13, 2014
Lenovo G580 , won't boot
Has error that startup repair cannot automatically fix the problem
1 Related Answer
Anonymous
  • 229 Answers
  • Posted on Feb 26, 2013
SOURCE: I have lenovo g580 lap. i have installed easy camera but couldn't able to chat in gmail through video
You're going to have to make sure you have the drivers installed for the webcam that's on your computer as well as you have the software for it.
You also need to have Adobe flash updated all the way and enable the webcam device through properties.
You can download the drivers and such through the manufacture's website under support and drivers.
2answers
How do i remove or reset the bios password on a Lenovo G580 laptop?
First of all, you need the present password. Then straight after turning the computer on you press F12 or insert multiple times after each other. That way you will stop the normal boot and enter the BIOS settings. There you most likely will be prompted for the password and then under security you can disable or change it.
My lenovo laptop g580 wont boot even if camera and indicator lights are on
Sounds like a bad monitor or ram. Does the hard drive, fan etc make noise when first turning it on?
If there's noises indicating it's working, it's probably a hardware issue.
I can't startup my computer due to hardware is corrupted
of course window has not the function to fix such an issue, you can get it on work again by restore your system, or download a tool like Windows Boot Genius to fix the issue,it is effective.
2answers
Lenovo a310 screen won't boot up and turn on
This could be a case of overheating.
First question, did the no signals sign appear out of the blue?
Check inside for melted components.
Clean your computer, remove all dust.
Check back with me.
T61 won't go past the Microsoft loading screen
Press F8 during boot, and load Safe Mode. A program may be preventing a proper startup.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig > Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running.
This just disables them in startup. Programs will still load, but when you initiate.
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
