Question about Canon EOS 600D Rebel T3i Digital Camera
The memory card is not readinng
The camera keep saying their is no card in it whenever i put in the memory card in the slot and it does not come up
    Top Expert:
  • Canon Master
  • 6,702 Answers
Did you put it the right way around? Almost impossible to put it in the wrong way, but I don't know how strong your thumb is.
Then check is all connection points are clean and shiny, and straight. Not one should be bent or out of line. Also check in the camera. Look if perhaps some dust or paper is in the memory card holder. Check is the memory card holder / battery door locks correct.
Posted on Feb 13, 2014
Doodad
  • 64 Answers
SOURCE: locked memory card
There is a tiny switch located on the side of the memory card, might even say lock on it or beside it. Just flick the switch opposite of the way it is now and it should work fine after that. There might even be a small arrow showing which way to switch it. The reason for the lock button is "just" for this, so you don't accidentally erase some wanted pictures or someone else.
Posted on Jan 06, 2008
t00nz
  • 4738 Answers
SOURCE: "memory card locked" error message
First I know you've said you've checked the card's slide switch, but just want to restate this first for others with the same problem who may not know of this switch.
Check to make sure that you didn't accidentally place the tiny locking slide switch on the side of your SD card in the "locked" downward position. The correct "unlocked" position should be slid up toward the direction of the connectors.
If you've tried this, and it's still showing locked, it's likely that the locking switch inside the camera's card slot is stuck. If you look inside the slot on the side of the slot where the SD card slide switch would be, you'll see a glint of gold color on the side. This is the camera's lock/unlock switch. The other glint's of gold that you may see at the far end of the slot are the reader's connectors (ignore those).
Somehow, the locking switch is making contact and has become stuck in the locked position (a single grain of sand can jam it there). With a plastic toothpick, or other skinny NON-METALLIC item, tap and gently push against this switch to see if you can jar open the contact to its normal unlocked position. Also try blowing compressed air at it, to clear out any gunk that may have worked its way in there, jamming it closed. Occasionally, reinsert the SD card to see if the issue has been corrected.
If repeated tries fail, it may be time to consider opening the camera to force open this switch (not recommended unless you have some familiarity with electronics). In this case please see the following (xscrewdriver, hope you don't mind me referencing your blog):
http://www.myfixtips.com/blog/digital-camera/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
Posted on Jul 11, 2009
michel_mmvi
  • 44 Answers
SOURCE: memory card locked
this is from cardrecovery.com... whew a lot of people get this error... hope all of u resolves this..
but before u truobleshoot for recovery of pictures, check first the slide on your memory card (card protection) slide it both ways and check it... someone advices from a thread to use paper clips to pick the slot of the cam where u put the card, it work for him but i think its not a good idea coz it may damage the slot.. okay.. if there is still an error u can bring it to a tech person (canon support service) or just try to recover ur files...
Troubleshoot:
Memory card is used by digital camera to store the photos it takes. Popular memory cards include SD card, CF card, xD-Picture card and Memory stick. For some reasons, memory card may get damaged on power shortage, or removal of memory card on picture shooting or viewing, or other various and unknown reasons. Usually, you will see error message like "memory card error", "card locked", "card error", or an error code on your camera screen and the valuable pictures on the memory card could disappear and be lost. Some cases, your camera or Windows may prompt you to re-format the memory card and refuse to take new pictures or view old pictures.
Solution:
Once you have your memory card damaged, it is highly recommended to stop further operations on the memory card (e.g. taking new pictures, or delete, format the memory card). Data recovery software like "CardRecovery" is able to recover the lost pictures in most cases.
First, you need to confirm your memory card can appear as a drive letter in "My Computer", which will allow recovery software to access and recover the lost photos. You may try to connect your digital camera to your computer, if a new drive letter appears in "My Computer", it is OK. Otherwise, you need to prepare a USB card reader. There are many card readers available in market (e.g. SanDisk and Kingston). You can buy one from Amazon or BestBuy.
Then, you may download and install CardRecovery to your computer. Launch it from Start Menu -> Programs -> CardRecovery. You select the drive letter of your memory card, and destination folder for save the recovered files. CardRecovery will scan your memory card and locate the recoverable pictures. The process is quick and easy. Usually it takes less than 15 minutes.
Can I re-use the corrupted memory card?
For data protection, CardRecovery performs read only operation on your memory card and it does not change the data on the memory card, so it does not repair or fix the memory card. If you need, AFTER you have recovered your lost photos from the card, you may try to format the memory card before re-use. It is suggested to perform enough read/write test before using it again to take new pictures. If you are worrying that the memory card is unstable and may cause further data loss, purchase and use a new memory card. Your valuable and irreplaceable photos are more important than memory card. Memory card is very cheap. A new 2GB SD, CF or xD card is less than $10.
Posted on Sep 13, 2009
Rammsteins
  • 300 Answers
SOURCE: "Card Locked"
Hi!
There's a small switch on the memory card reader inside the camera which detects that the card is locked. Most likely this switch is broken. You can try to point it with needle or something but I'm afraid you will have to give it away for a repair to a local repair shop or Canon service center.
Tom
Posted on Sep 27, 2009
John Conner
  • 30 Answers
SOURCE: Memory card error message
Cards are coming in different formats and it might be possible that you brought a card which is not suitable or functional with your camera. The other reason could be that we are having options to lock our memory card in digital camera and you might have taken out your earlier card without unlocking it. The system might be broken from inside and this could be a reason that you are still getting a message that memory card is locked. It seems possible based on problem you are sharing.
Posted on May 29, 2010
How can i manage my memory card because it damage due to that my camera not working now whenever i start its show that card is locked but another card not insert in camera so can you help me?
sir,
if your memory card is good, then you have to check the M/C slot in the camera, in some cases using the contact cleaner will clear this, just spry in the slot then put a memory card often eject and push several times.
Dec 09, 2015 | Sony Cyber-Shot DSC-H70 Digital Camera
Memory card problem , when I put the memory card in the slot it says to clean it so I did and it keeps saying the same thing.
Have you tried a different card? That particular card may well be damaged and that is why you get the error.
Please rate my help++++Thanks for using FIXYA
Nov 16, 2009 | Olympus FE-370 Digital Camera
Says to reinsert memory card & card is in camera. Try another card & says memory stick formatting error
i have the same problem..
I have a Sony Cybershot DSC T70 and it keeps saying "Reinsert memory stick" whenever I turn on the camera or slide down the camera lid. Also, whenever I try to view the pictures on my laptop it shows "Please reinsert the memory stick" something along those lines. As I have been researching for the solution, I would have to format the memory card. However, I wouldn't want to lose the pictures as I just took many as from the holiday last week. The only problem is the memory card, I tried using another memory card and it works fine with the camera. There is nothing wrong with the camera.\r\nCan someone please help me how to solve the memory stick problem? It would be great. Ty.
Oct 17, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Keep getting message to reinsert memory stick!!!! Help!!!
Oct 16, 2009 | Cameras
When i put card in camera it keeps saying reinsert card
You didn't say what camera you are using, check the specs for the camera and see if it can use a 2GB card. If the camera is not able to use that size card it will not "see" it.
Have you tried putting the card in a reader and formatting it on your computer?
If it the computer can't see it, the card may be bad.
Oct 09, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Are the contacts on the card clean? Is the slide switch on unlocked?
Sep 13, 2009 | Nikon Coolpix 990 Digital Camera
My sandisk memory stick pro duo wont work anymore
Sep 11, 2009 | Sony Cyber-Shot DSC-P92 Digital Camera
My playstation keeps saying to put in a memory card.. even though I have done
did you try reading the memory card without any game discs put in via the ps2 menu?
is your memory card working properly? could be a corrupted memory card or a faulty memory card slot.
try putting a friend's memory card on that same slot.
if it works... then your memory card is gone bad...
if it doesnt work...then your memory card slot has gone bad.
else try putting your memory card in your friend's ps2, see if that ps2 reads your memory card. if it does...then your memory card slot has gone bad.
Sep 07, 2009 | Sony PlayStation 2 (PS2) Console
Problem
Look at the bottom of the memory card slot, you probably bent one or more of the contactor pins. Use a small screwdriver and carefully try to straight the bent pin then carefully put the memory card back in. From now on, use a USB cable for downloading your pictures and don't pull the card out anymore as the pin is probably weaker than before and can break. Good luck
Sep 04, 2007 | Cameras
Canon EOS 600D Rebel T3i Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
