Question about Pyle Audio Players & Recorders
Antenna with Pyle PT260A AM/FM receiver not picking up FM channels
Antenna not picking up FM radio stations
ttech
  • 139 Answers
SOURCE: Radio won't work on my Denon Receiver
Hook up a Small piece of wire Coming off the #00 ohm input for ant also put it in Mono mode first and you should be able to Hear Hiss Then tune Let me Know ttech
Posted on Jul 20, 2007
renosean
  • 492 Answers
SOURCE: Don't receive hardly any FM stations
Well I would consult your manual.  Home receivers usually dont have the same amplification factors that a mobile unit does as far as sensitivity.  But for best results make sure that you are using the supplied antenna, and put aluminum foil over it.  This will help amplify the signal.  Also consult the manual as to weather there is a setting for DX or Local.  If there is, make sure that it is not set to local.
Posted on Jan 03, 2009
  • 362 Answers
SOURCE: Not picking up Digital signal from box but can receive it analog
So many factors could be affecting your reception. Keep in mind that the digital signal is all or nothing, either you have a signal or you don't, with the regular signal you can pull in weak signals but you can't with digital. Your converter box when turned on will probably not pick up the standard signal. The distance from the digital signal and the direction the antenna is facing also will affect your signal.
Ok with that said you will have to clear the path between the broadcast signal and your antenna, I know this will be a chore but take your antanna out of the attic and put it outside as a test only, this dosnt mean you cant have it in the attic it will just be a signal test.
Once the antenna is moved, from the menu scan for channels and see what you get. Let me know and I can help further.
lone99star
Posted on Jan 09, 2009
SOURCE: Cannot Get Antenna To Pick-Up Signal
how do i connect my xm roady sa10035 to my car cd player?
Posted on Feb 02, 2009
  • 14036 Answers
SOURCE: 1999 Mercedes CLK radio antenna
look at antenna wires make sure every thing is in contact.if all is good.sound like problems in the sound amplifier.in radio.
Posted on May 07, 2009
Will not pick up any FM stations
Deploy the antenna and locate the radio near a window.
Jun 25, 2014 | Milwaukee Tool 49-24-0200 AM/FM Radio
My str de 925 will no lock on a radio station
Insure that the antenna is connected securely on their respective antenna
input, Stations will not lock , if the signal is low.
For FM :
• Wire antenna is applicable if your distance to the nearest FM
is about a km or less, other wise use a VHF TV antenna.
for AM :
• These antenna is directional, you may need to extend the wires
so as to receive AM stations.
Jul 31, 2012 | Sony STR-DE925
My Klh r3000 receiver is great for everything except picking up am or fm stations? I had an antenna attached, but the unit is in my basement, and I get no signals at all. What could I be doing wrong?
If the antenna is in a basement that is the problem - the fact that it is below ground means that no signals can get through.
Radio signals are blocked by buildings, large lumps of metal or other solid objects as well as strong magnetic fields (which can include electrical devices within the home).
To pick up good radio reception you will need an external antenna above the ground level - preferably as high as you can get it. Unless you get an omni-directional antenna like this one http://www.maplin.co.uk/vhf-fm-omnidirectional-aerial-874 you will need to point the antenna accurately at the transmitting station (+ or - about 5 degrees) for FM. At a pinch you might get by with an indoor aerial but it needs to be above ground level (inside a roof would be best)
Good external AM Radio aerials are harder to find these days.
Feb 24, 2011 | KLH R3100 Receiver
2007 Camry: I can't receive clear radio channel in camry 2007 ...
if you have a factory radio, then chance are you antenna is amplified (even if you don't have an antenna that goes up in the back). The fuse for the antenna amplifier could have blown or the amplifier itself my have gone bad. It could also be your radio but, i would check those things first... Just a side note: i don't know of any stations that around me that aren't odd numbers 92.3 fm,95.5 fm,100.3 fm. Where you able to tune it to 100 fm before?
Apr 28, 2010 | Cars & Trucks
The FM stations are not playing in my 1996 Nissan Maxima.
make sure the antenna is plugged into the back of the factory radio.
Jan 05, 2010 | Car Audio & Video
2007 Chrysler 300 , AM radio not working , but FM works fine
Usually when you lose only AM it is an antenna issue. Check for a loose antenna plug on the back of the radio or connection to the antenna.
Nov 15, 2008 | JBL - MR4W Am/Fm with CD Player White
Pioneer DEH 1900 MP receiver - cannot pick up AM stations
normally the problem you are describing means that your antenna is bad. typically, if you have no am good fm bad antenna if you had good am and no fm the fm section of your radio would be bad.
you can test this but you will need an antenna (this can be purchased at most car parts stores for about $10.00) pull out the radio unplug the black round plug from the back of the radio and plug in the new one ( the antenna plug is a universal fit) you will probably need to ground the base of the antenna for the test then turn your radio I'm sure this will fix your problem but if not you can e-mail me at merle840@aol.com
good luck'
Merle
Sep 29, 2008 | Car Audio & Video
DOES NOT PICK UP FM CHANNELS CLEARLY
Does the receiver work for AM? I need to isolate the problem circuit. Please try an AM station and update this.
Thanks,
Dan
Jul 29, 2008 | Sony STR-DG510 DTV Receiver
Sony CDX-GT360S NO AM OR SHORTWAVE RECEIVE
am fm receiption not the same most likely antenna make sure the antenna wire fit tightly in radio cheers
Jan 08, 2008 | Sony XPLOD CDX-GT200 CD Player
15 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Gerhardus Stroebel
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
