Question about Home
Shower faucet stokkur lm80906b-125
Cant stop the water
  • 68 Answers
SOURCE: Pressure problem with Kohler shower faucet??
Hi pglaw,
My best guess is the supply valve for the hot side isn't open all the way. This valve is right on the valve and is accessed by taking off the front cover plate. This would still allow the pressure balancing valve to let water through but then you would have a small flow on the hot side.
If this isn't it then then cartridge is bad.
Please rate this response and good Luck,, phil
Posted on Dec 31, 2008
  • 297 Answers
SOURCE: No hot water flow from faucet/shower
change the cartridge it is bad or defective.
Posted on Jul 20, 2009
  • 9 Answers
SOURCE: Cold water only from single-arm shower faucet in master bathroom
Yes - This is an easy (though not widely known) diy fix! Remove the cover of the faucet handle (may pop off if crystal type or use a screwdriver to remove the screws) inside there is a scald guard safety mechanism - using a flathead screwdriver, turn the guard some the left. There should be a guide so that you do not turn the water up too hot. If there is not, you may need to consult a plumber or supplier in order to adjust the hot to a moderate temperature.
Hope this helps! ;)
Posted on Aug 28, 2009
  • 82 Answers
SOURCE: moen T2113 shower faucet no hot water
You need to replace the stem. This will not cost you a dime; call MOEN and tell them the issue, with the model number, and they will send the replacement part. Many people don't know that MOEN is guaranteed for life (to the original owner)......another words, say you are the original owner :) They will not ask any questions. Good luck! PS Also works on any MOEN faucets you may have.
Posted on Sep 03, 2009
  • 129 Answers
SOURCE: I have a shower faucet that keeps turning, does't stop.
Yes shut of main water, then remove handle, then take off bonnet, that holds stem in valve. You will have to take stem with you to hardware store to match up. Put it back together in reverse, turn main water back on. Now you tell everyone your a plumber and get much respect.
Posted on Sep 26, 2009
Testimonial: "yes, I did just what you described. Surprisingly, Westlake Ace Hardware had new replacement stems and I didn't have a big plumber expense! "
When shower is in use pipes vibrate and water starts to pulse,when faucet on sink is turned on it stops .What's up?Shower is an Aquasource brand.
You need to install water hammer arrestors in your basement it prevents this, if you have them already there water logged. All u do is shut off your water to your house and drain it down to the lowest point....when its done draining u fill it back up again slowly. Your water hammer arrestors may have become water logged when the new shower was installed
Nov 14, 2012 | Plumbing
The shower does not get hot so i took pressure balance unit apart and cleaned also took hot limit stop off .still not hot rest of sinks in house are hot and furnace right under shower,what do you think it...
When shower faucet apart make sure hot is getting 2 & coming out faucet ***. did you turn off stop integral w/ faucet or outgoing shut off valve on water heater.. May have rust or lime in small orifice leading to faucet ***. does your balancer/ piston move freely..good luck..
Mar 24, 2011 | American Standard Bath Faucet Ceramix...
Delta 1400 tub faucet leaking hot water, how do I stop?
the cartridge inside is bad and needs to be replaced or at least cleaned in order to stop the water
Oct 24, 2010 | Delta Faucet Peerless& Tub And Shower...
Only warm water from the tub/shower
You can cap the lines at the tub faucet to rule out tub faucet. It maybe mixing there.
Faucet may be bad also the safety stop will alow you to change water temp it can be tricky to adjust water temp.
May 02, 2010 | Moen 1 Handle Lever Shower Faucet With...
The temperature in my shower is very luke warm only at the shower
Do you mean the other faucets in the house are hot and only the shower is warm? If so there is an anti-scald adjustment on the faucet that needs to be turned up a few notches. Havent adjusted a Grohe faucet but most faucets you rmove the handle and behind the handle is a nothced adjustment ring that prevents the faucet from getting too hot. This ring, or stop, is pulled out and twisted clockwise(or counter clockwise to set higher or lower max temp, then pushed back. maybe you can look up grohe to see which way ring or stop adjusts for hotter water.
Jan 23, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Jul 20, 2009 | Delta & Single Handle Shower Faucet
No water flow
Did this unit come with water stops built into the faucet body? Some of the newer faucets have stops built in and they need to be turned on. Also if you aren't going to plumb the hot in, you will need to cap it off but it should run without it unless it has some sort of balance in it. I don't think so though.
Apr 09, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
