Question about Makita Saws
Recipricating saw lost cutting action
The saw has lost the ability to move forward and backward. There is also a sound of a possible loose part near the shoe end.
  • 2039 Answers
SOURCE: driver side seat 03 ENVOY
the motor make sound disconnect the the cable that goes to the seat if they move you got something blocking the mouvement of the seat check that out pierre
Posted on Jul 13, 2008
  • 75 Answers
SOURCE: 1996 Mercedes SL Power seat problem
hi,seat motor are in maximum length,try to seat,then apply force backward also the switch in backward mode.
Posted on Feb 20, 2009
  • 109 Answers
SOURCE: Hydrostatic Transmission Failure
There is a transmission bypass lever on the back of the mower, if the bypass is moved out of the drive position, it will not drive in either direction, and will be really easy to push.
Posted on May 03, 2009
dmsr63
  • 2050 Answers
SOURCE: gear select lever is very loose. It move forward
There is a pin that goes through the shifter that hold it in place, along with a spring just inside where the end of the shifting lever is, that makes the lever "return" after you pull it back to shift. These springs can break and bind up. Take a look at both.
Posted on Aug 14, 2009
  • 49 Answers
SOURCE: The electric front seats both stopped moving
Check the fuse box for a blown fuse, both seats may operate on one fuse depending on the model of vehicle and the fuse may be located either under the dash on the drivers side or in the engine compartment on the drivers side.
Posted on Aug 21, 2009
Driver side seat will move up and down but want move forward or backwards what can be the problem
It sounds like the motor for the forward/backward motion is out. Or the switch is bad.
Oct 11, 2017 | Seat Cars & Trucks
First use of saw, instructions poor. Cant get the saw to cut more than an inch across one small piece of picket fence. spent 2 hrs getting extremely frustrated. Any tips..please!!!
My guess is that you have the blade in the wrong way round and it is running backwards instead of cutting forwards.
Feb 06, 2016 | Saws
My machine is sewing backward, would go forward what to do
there is normally a small lever on the front of the machine near the drive end that is up to go forward and down to reverse
It is a great help when starting to sew that you sew about 1/2 inch then reverse the direction and then go to forward again and continue sewing
actions anchors the start of the sewing and the thread will not come undone
do the same at the end of the sewing and when you cut off the threads they will not unravel
Apr 12, 2015 | Sewing Machines
Screw loose in securing toilet to flange
Hopefully you can tighten it Sometimes the flange bends up or can break. Many a flange is not held down properly with good enough screws or the plywood has been rotting etc. If you can tighten it or loosen it then it has to be cut off with a recipricating saw or hacksaw and replaced.
Nov 29, 2013 | Kohler Toilet - One Piece with Ingenium...
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
2009 impala driver side power seat won't move up/down, makes whirring sound when attempted. Moves forward backward. Passenger seat works properly.
Before you do any of the expensive things disconnect and reconnect the wiring to the seat I had the same exact problem with my 2009 Chevy Impala and was ready to take it to the dealer when I disconnected the power cables to it and reconnected them I found that one of the Harnesses was loose and the problem was solved
Sep 12, 2012 | 2009 Chevrolet Impala
I was mowing the grass, turned around to go back down to cut a new rpow, and lost all ability to go forward or backwards. Pedals seemed tosink a little lower, and there is a lovely grinding sound...
hydrostatic transmission has reached the end of its life. Call a dealer and get a price to repair, then contrast that amount with the cost of a new mower. Those transmissions are not cheap, you may find folks selling them NOS on eBay, certainly worth a few minutes googling around before you lay down the bucks. Do not buy a used transmission.
May 09, 2011 | John Deere Garden
Won,t move
Check the pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Husqvarna Zero Turn Mower Z5426
How do you install the blade in the craftsman recipricating saw model 320
You need a allen wrench to remove the blade and to reinsall it look at the base of the blade and you will see an allen wrench. If there is no allen wrench then you must pull down on the clap assembly to release the blade. If you still can't figure it out here is sears web site where you can get help for it if you need a picuter.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26128394&sid=PSx20071217x00001a
Sep 17, 2009 | Craftsman 8.0 amp Reciprocating Saw
How to replace chainsaw on blade too much slach in chain
Are you sure you need to replace the saw chain? There should be a screw adjuster near where the bar attaches to the saw which tightens or loosens the chain on the bar... You will have to undo the nuts holding the bar onto the saw body slightly first so thew bar can move forward and backward when adjusted with the tension screw to apply tension to the chain to reduce the slack.
Jun 14, 2009 | Remington Polesaw Wizard
Saws Logo
44 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
