Question about Sharp AR-161 Laser Printer
Sharpnar-m276 is having paper jam for a3 tray what is the solution
When photocopying a document it jam
jaylex
  • 417 Answers
SOURCE: A3 Printing
Put A3 in the paper tray and select reduce and enlarge and set to 141% this is A4 up to A3 then press start this should help.
Thanks J
Posted on Feb 17, 2008
  • 2976 Answers
SOURCE: sharp 5316 showing paper jam sign at right door but no paper
Shut it off, wait 30 seconds, turn it back on. If the path IS clear, the error will be gone.
Posted on Feb 23, 2009
  • 51 Answers
SOURCE: Paper icon flashes. I have checked tray and
Needs feed rolls.
Posted on Apr 06, 2010
  • 2072 Answers
SOURCE: I got H4-00 problem in my AR -M276 Photocopy
Press # * C *, then enter 14 and press start, then 1 and start, then clear.
Posted on Jul 27, 2010
canontech
  • 1219 Answers
SOURCE: what is sharp photocopier service
Hi don't know for the number, but...
If you want you can remove back cover of the cass. and see if the spring is broken, these is usually main cause for not lifting the paper in cass.
Posted on Dec 28, 2010
Paper jam in tray one after receiving every photocopy in kyocera fs6525 wht's a problem ???
First make sure that tray is set up for correct paper size. That would be first thing. Check for paper dust in paper path blow it out. Really sounds like paper tray not set correctly.
Feb 23, 2014 | Kyocera Fs-6525mfp Copier, Printer,...
I have a Panasonic Workio 1820 photocopier and I can't get it to copy A3 size documents. I have set the copy size to A3 but it will only copy and print an A4 portion of the document.
from where are u using the A3 paper . if ur using the drawer then simply select the original size and copy size as per ur requirement and first change the tray paper size to A3 in operator settings. if ur using by pass tray then be sure to pull the entire tray out as there is a sensor in the last end of the tray that senses A3 and legal paper
Aug 23, 2011 | Panasonic Office Equipment & Supplies
HI MY DESKJET 9800 WILLNOT FEED A3, IT JAMS ON THE LEFTHAND SIDE EVERY TIME, I HAVE LOOKED TO SEE IF ANYTHING IS OBSTRUCTING DUE TO BEING IN STORAGE FOR A WHILE. A4 FEEDS CORRECTLY, BUT CANNOT FIGURE OUT...
If A4 is ok but A3 jams then I would have to say there IS something hitting the paper. Try another A3 sheet and when it jams, pull the paper back out (after the printer is switched off) very slowly. When its out take a look at the leading edge and you will see a kink in the edge of the paper. Now place the paper back in the input tray and look at where the kink is in relation to the machine. That will tell you exactly where the obstruction is.
I hope you understand what i am trying to say.
Jul 10, 2011 | HP DeskJet 9800 InkJet Printer
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
Jul 27, 2010 | Sharp AR-168S Copier
Paper in tray but message says paper tray empty
HP officejets are notorious for problems with paper feeding...
Try the solutions (ignoring the ones about tray #2) from this solution... They're all the same sort of printer feed mechanism.
http://www.fixya.com/support/t878735-printing_error
... also something I noted with the K850 (the earlier model to the K8600).. some papers are less likely to be picked up than others.
I had to get some cheap A3 paper for that unit which worked better than Xerox branded, higher quality photocopier stuff. Sounds strange but if it works...
Hope that lot helps.
Feb 22, 2009 | HP OfficeJet Pro K8600 Printer
Canon Imagerunner 210S - A3 error
A3 is a metric size paper. The document you are trying to print must have been formated for metric size paper. When you print select "Fit to printer margins" De-select "Choose paper source by PDF page size" and select the proper page size and source.
Jun 09, 2008 | Canon imageRUNNER 210S Copier
Problems printing an A4 document in A3
Ensure that the desired paper is set in a paper tray of the printer and select [Auto] in the paper selection of the printer driver. You may need to configure the margins in the sofware you are using. hope this will help you Daniel
Feb 01, 2006 | OKI B8300 Laser Printer
26 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
