Question about HP Deskjet 3512 Inkjet Multifunction Printer/Copier/Scanner
I have lost the instruction disc and am trying to scan. It says to insert disk. Is there anything I can do? MIT prints, but no scan
I lost my recovery disk or restore disk for my sony vaio VGN-FE660G. If anyone could direct me in the right direction to get them.
There are no System Recovery CDs included with the computer. The recovery data required to return the computer to the original, factory-installed condition is included on a special partition of the hard drive. Follow this procedure to create the Recovery Media Kit (a set of Recovery Discs), which can be used to restore the recovery partition and return the computer to the original, factory-installed condition.
  1. Ensure all open programs are closed.
  2. Ensure all network connections are disconnected.
  3. Ensure all peripheral devices are disconnected.
  4. From within the VAIO Recovery Wizard application, in the Create Recovery Discs window, click Next.
  5. Under Create Recovery Discs (Step 1 of 3), click to select the option to use either DVD or CD media.
  6. Click the Next button.
  7. At the Insert a blank... dialog box, insert the appropriate disc.
  8. Click the OK button.
  9. Insert a new disc when necessary as instructed.
  10. When all the disks have been created, click the Finish button.
Dec 30, 2013 | Computers & Internet
Can not get the OCR to work
Try to reinstall the OCR scan software by inserting the Lexmark installation disc that came with your printer into the computer hard drive. If you have a firewall enabled, make sure to allow all Lexmark scan and print processes in the program rules or permission.
If you lost the disc, please contact Lexmark Technical Support Center to request one for free.
Sep 28, 2011 | Lexmark X5070 ALL-IN-ONE InkJet Printer
My lexmark x2670 prints copys but it will not scan a document ocr it scans but will not process it .,then tells me it needs a program that has been deleated or lost i am using vista 32bit noel
You will need to update the printer software installed on your computer to install the OCR scan software. The Lexmark OCR scan software is available only on the installation disc that came with your printer. Just re-insert the install disc into the computer hard drive and run the installation setup.
If you lost the disc, please contact Lexmark Technical Support Center for assistance.
Aug 10, 2011 | Lexmark X2670 All-In-One Printer
I have a lexmark pro 205 all in one printer. It prints fine but I can't seem to scan a document and put in word. How do I do it and where can I get a manual for this product?
You will need to install the Lexmark OCR scan software to scan documents and edit it. Re-insert the installation disk in your computer to install the Lexmark OCR scan software. If you continue to experience scanning problem or you lost the disk, contact Lexmark technical support. Thank you for choosing Lexmark.
Oct 10, 2010 | Lexmark Prospect Pro205 Wireless...
Please guide the steps to install the norton antivirus 360 latest version one user
The easiest way, open your CD drive and with that open shut down your computer. Insert the Disk in the drive and close it then restart the computer. The installation program should start auto automatically as windows starts. The reason I said to shut down then reboot with the disk in the drive is to allow the program to scan your system before windows starts to speed up the install process. If you insert the Disk and close the drive while the computer is on it will auto start and scan the system anyway but it takes longer. Make sure you stop and uninstall any other anti virus programs or Anti Adware programs, such as Spy Bot, you may have running, the Adware programs only need to be closed.
Jul 22, 2010 | Symantec Norton 360 Version 3.0 Full...
I can't get my hp 6110 to scan to my computer
GO to add scanner utility and try to add the scanner if it ask for the driver insert the disk.
May 07, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I have got a 2gb scan disk memory card i cant access it or format
Hello Friend,
Here is a method to try:
  1. Backup all data from your hard drive to another hard drive or CDs or DVDs.
  2. Turn off your computer.
  3. Insert the USB drive to a USB port.
  4. Turn on your computer.
  5. Hit the F8 key when prompted to get to your system bios. Some computers required the Delete key or F2 instead of F8. There should be a note on the screen that specifies the key.
  6. Navigate your bios (usually using your cursor keys) to boot from CD drive first. Save and exit.
  7. Insert your operating system disc aka Operating System Restore disc. Your computer should restart. If not, restart it yourself.
  8. Follow the instructions for installing your operating system. When the option to select which drives to format comes, you should be able to see your USB disk in the list.
  9. Format the disk with FAT32 for Win98 or previous. Format with NTFS for anything after e.g. NT, 2000, XP etc.
  10. Depending on your options, you may be able to opt out of the operating system install at this point. If it was running well beforehand and you can, leave your other drives alone and quit the re-installation.
  11. Reset the computer to boot from the disc drive the operating system is on instead of the CD drive as before. You should have your working flash drive detecting and usable now in windows.
  12. If you didn't get the option to opt out of the re-installation, continue to follow the instructions onscreen and complete the re-installation, formatting whatever drives are required. Note: Do not try to install your operating system onto your USB disk drive. Also be cautious when formatting to keep in mind all data could be lost.
Best Regards,
Oct 29, 2009 | Electronics - Others
Single blank disk inserting wont work (Mircoboards PF2)
You may have a disc loading error. To correct this follow these instructions:
Disk Loading error:
If a disc is not loaded correctly, it could cause the out of paper indicator to come on. Press the out of paper button on the interface. The printer will attempt to load another disc. If this does not clear the error, remove the discs from the input bin. Check to see if there are any discs on the belt. Remove any discs that are left on the belt.
Lift the cover and check for any discs on the front part of the printer. Remove any discs found on the belts. Close the cover.
Next, reload the input bin and press the out of paper button. The system will load the next disc and continue printing the remaining discs for that job.
If that doesn't work, and there are no obvious jams in the transport system, I'd call support and see if they can walk you through a fix. They can be reached at:
For technical questions or support issues, please contact Microboards Technology technical support at PH: 952-556-1639, FAX: 952-556-1628, by email at support@microboards.com or on the web at http://www.microboards.net.
Mar 19, 2009 | Microsoft Windows XP Home Edition
I've lost my disc :(
you can download all the required software/driver and manual from the following link and burn it to a disk to create a disk of your own again
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=16981
Feb 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Lost disc want to install printer scanner 6300
May i please know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
Apr 16, 2008 | Dell A920 InkJet Printer
HP Deskjet 3512 Inkjet Multifunction Printer/Copier/Scanner Logo
16 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
