Question about Ricoh Aficio Office Equipment & Supplies
Printing dim after toner change - Aficio Ricoh Office Equipment & Supplies
Dim printing
Depends how much you are using it. Typically the printer will warn you when it is low. Also you can print a supplies page from the printer menu to see how much toner you have left.
Jun 11, 2012 | HP LaserJet 2430 Printer
6110- Faint Printing in same spot all the time
Well measure the repair costs agains the cost of a new printer.
so you have printed 15 000 pages? pretty good for 200 usd printer I must say.
Il have a look what xerox says about this.
May 12, 2008 | Xerox Phaser 6110 Laser Printer
Hp laserjet 1160 printing is very dim what is problem.
Hi.do this pull-out toner cartridge then shake it and also cleaning using vacuum to get dust an dirt in censor mechanical area.test and print .if print dim again. need to change or refill that toner cartridge.
Jun 09, 2011 | HP Office Equipment & Supplies
I have HP LaserJet 1160 Printer, moreover it prints dim (light) print on paper. I replace its toner, yet it is printing dim printing..... can you give me reason, what is problem?
Hi, maybe the printer is in EconoMode. To disable EconoMode please open the printig preferences in Windows. On the Paper/Quality tab or the Finishing tab, deselect the EconoMode checkbox.
Jul 19, 2010 | HP LaserJet 1160 Printer
Dim bulb, copies nearly black, but prints fine
The dim bulb is your clue. The more light that is reflected on the Selenium drum, the more the drum is demagnatized and less able to attract the toner. The printer now thinks you're running really dark stuff through it because there is not much light to reflect off of your original documents. See why the bulb is so dim. Good luck.
Jan 06, 2010 | Dell 962 Photo All-In-One InkJet Printer
New toner prints very light. No setting changes on printer.
I had a similar problem, it turned out to be a cheap toner cartridge. Replaced it with an HP cartridge and have had any problem since.
Mar 23, 2009 | HP LaserJet 4p Printer
Changed Toner - Having Printing Problems
try to reset the machine,
by opening and closing the riight side door
hope that help
Nov 14, 2008 | Konica Minolta DiALTA Di200 Copier
Ricoh Aficio CL2000N
You may have to replace the transfer belt or the drum. I would start with the drum first
http://www.websitetoolbox.com/mb/copierquestions
Sep 02, 2008 | Ricoh Aficio CL2000N Laser Printer
Illegal toner
Sorry, this sounds outside my experience.  The only trigger for the 'illegal toner' message that I know is that the cartridge has the wrong plug on it.  A 'proper' Brother cartridge will have the same plug as the rest and be very easy to check.
I have both refilled empty cartridges and used commercially refilled ones. As I said, the only time I have seen this message was with the wrong plug.  When I used non-spec toner I got 'ghosting' as the toner stayed too long on the transfer belt.  No error message, just poor quality printing.
OPC belts appear to need changing fairly often - I am on my third.  Take it out and have a look (note that it is light sensitive, do it quickly in dim light).  If it is not a clear shiny green it may not be up to spec.  As a quick fix you can reset the 'replace OPC belt' message, but they do wear out.  It is used to transfer toner from the cartridge to the paper - so failure means poor quality printing rather than a refusal to print.
Sorry I cannot help further.
May 09, 2008 | Brother HL 2700CN Laser Printer
Lexmark E250dn laser printer
Reinstall the drivers and see if it works.
Otherwise unplug the printer from the power and leave it without power for 10 minutes. Than plug it back in and let me know if it helped.
Feb 08, 2008 | Lexmark E250dn Laser Printer
13 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
