Question about Frigidaire FAFW3801LW 3.26 cu. ft. Front-Load Washer in White FAFW3801
Doesnt drain and doesnt spinn in high - Frigidaire FAFW3801LW 3.26 cu. ft. Front-Load Washer in White FAFW3801
  • Frigidaire Master
  • 5,323 Answers
No spin, try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Posted on Apr 01, 2015
My hoover optima washer drains but won't spin. Help
I would suspect the timer contacts are burnt .
Mar 04, 2015 | Hoover Washing Machines
Kenmore model 22432100 wont spinn or release the water
Hi.
Check if there is drain blockage. That will result in cycle not advancing to spin. To check drain system, check first the drain hose at the back and then access the hose connected to the drain pump. The drain pump is accessed from the bottom of the appliance. Disconnect power first.
If there is no drain problem, check pressure switch and lid switch.
Here a general article containing more detail about the no-spin problem: If you have no spin ...
Regards.
Ginko
Apr 18, 2011 | Kenmore 24032\24036 Top Load Washer
Agitates and drains but smokes when it is time for finall spinn....wont spinn
Thanks for choosing FixYa and welcome. You need to make sure you don't have a frozen pulley. The belt may be causing the smoke you are seeing. It may be coming from the motor drive. None the less, it needs checked out.
Jan 09, 2011 | Crosley CAWC529JQ Top Load Washer
The drum will not spinn?
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 20, 2010 | LG WM1814CW Front Load Washer
Water still in machine
Depending on how high your drain hose is some of the water after the final spin can drain back into the outer tube of the machine. This wont hurt anything but when not using the maching, not a bad idea to leave the door ajared to prevent the washer from giving off a bad odour,
Dec 30, 2009 | Maytag Neptune MAH5500B Front Load Washer
Won't spin or drain. Only a hum. Rocky
Ur internal engine if busted u have strap to change for the spinn and chek the outside of ur macine neer her drain to se were is the plug. if not and ur machanie is in the basement see bout the house drain
Nov 19, 2009 | Roper RAS6233KQ Top Load Washer
Kenmore washer 70 series how to replace belt
The belt is replaced by loosening the tensioner.
then slip it off the pulleys.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 09, 2009 | Kenmore 24032\24036 Top Load Washer
It won't drain correctly and doesn't spinn. I think the inside drain is clogged with dog hairs.
sounds like the transmission drive has gone bad in unit it runs pump and spins drum
Jul 06, 2009 | GE WBVH6240F Front Load Washer
Clothes still very wet after spin
Common problem if drain tube goes to laundry tub. Tub drain is slow, so water is siphoned back into washer at end of cycle.
Other solutions: Partial blockage of drain tube before or at water pump. Take off front washer panel, exposing pump and disconnect hoses. Remove obstructions and re-assemble.
Jun 12, 2009 | Maytag PAV2300 Top Load Washer
From agitate to spin and drain it will drain but not spinn unless
Replace the timer to solve this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Kenmore 22422 Top Load Washer
Frigidaire FAFW3801LW 3.26 cu. ft. Front-Load Washer in White FAFW3801 Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
