Question about Ironman 220t Programmable Treadmill (225 HP)
How does one lubricate the ironman treadmill - Ironman 220t Programmable Treadmill (225 HP)
Why does my ironman 220t treadmill say si2 and give off a burnt scent after replacing a motor control board?
If you wish to get some details About treadmill repair and service; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 12, 2016 | Ironman 220t Motor Control Board Part...
Ironman treadmill repair
Sears sells this unit has the manual and repair parts available as well as will service it for you , if you wish.
Sep 06, 2014 | Ironman Edge Treadmill - Console Control...
How do you lubricate the belt on a treadmill
use a good silicon spray. it goes under the walking belt between the belt and deck. spray in a "s" pattern to cover entire area under the belt. this keeps the friction down when using and keeps the belt from drying out and overheating the motor
Apr 17, 2014 | Ironman 320T.1 Treadmill
I have an IRONMAN 220T treadmill and have a code # E11 and I do not know what it mean, can anyone help me with this.
E11 Means that deck bel or walk belt is slower speed that speed window .
2 possible causes:a) Locked rotor from main motor b) High friction from deck or walk belt.
3) Use the calibration software from your equipment for easy diagnostic and correction.
4)Use the owner manual or your step under the Hood ,and proceed with the steps indicated.
5) You can lubricate the Deck or Walk belt. please see your owner manual section: Maintenance.http://www.youtube.com/watch?v=f7IZWMMrCM0 please see this videos for easy help in lubricating. and adjusting deck belt treadmill.
http://www.youtube.com/watch?v=AZSMLpXm-tA
sincerely. Merry Chrstmas.
ernesto cuadramanagua, nicaragua.c.a.
Dec 22, 2011 | Ironman 220t Programmable Treadmill (225...
Missing manual for Ironman 320T.Where can I find or download one?
Hi
Click the follwing link for ironman 320T manual
Ironman 320T
I hope this helps.
Dec 10, 2011 | Ironman 320T.1 Treadmill
What is it when display reading SI 2?
SI 2 - Over voltage protection trip.
Just check if there is any resettable breaker located underneath it. You also may have a cable connection loose.
if it doesn't works for you
You may need to notify Ironman Fitness Customer Service Call Ironman Fitness Customer Service at (800) 750-4766
Mar 14, 2011 | Ironman 220t Programmable Treadmill (225...
Why does my Ironman Triad treadmill motor slow when people try to run on it, the belt completely stops
When running or walking on my Ironman Triad Treadmill it jerks like it is going to stop every once in a while not all the time. Do you have any idea what makes it do this. I have had this Treadmill for 5 years and never had a problem before.
Dec 19, 2009 | Ironman Exercise & Fitness
Ironman 220t Programmable Treadmill (225 HP) Logo
18 people viewed this question
Top Ironman Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Tony Crow
Are you an Ironman Exercise and Fitnes Expert? Answer questions, earn points and help others
